Question about Jl Audio Stealthbox Single 10" VW Passat 98-05 Speckled Gray
Problems with my car doors ,not closeing ,not locking.not unlocking,all intermitantly.????
    Problem Solver:
  • 10 Answers
Your subs beat your **** up? so if u want to fix it turn the **** down or buy a old beatr like a buick lesabre they hit good and the metal dont fall apart
Posted on Feb 08, 2010
Central locking cycling intermitantly when driving
There is probably an intermittent short in the switch that unlocks the doors. Maybe something go spilled on the button that unlocks the doors. The doors automatically lock after the car reaches a certain speed, but the unlock button may unlock them when you go over a bump or lean on the area around the switch.
Dec 22, 2014 | Cars & Trucks
When I use the door lock on my 2001 Santa Fe, the doors automatically unlock
Switch could be faulty.Use diagnostic equipment to read and erase fault codes.INTERMITENT CODES WILL CLEAR, PERMANENT CODES WILL REQUIRE PART REPLACEMENT,possible malfunction
Dec 07, 2014 | 2001 Hyundai Santa Fe
Remote locking system is erratic
You may have a dodgy door light switch or the doors are not closing completely. Does the courtesy (interior) light work? Does it extinguish when operating the remote?
Mar 04, 2014 | 2003 Toyota Camry
2006 KIA.DOOR LOCKS; When you unlock the doors with remote, the doors immediately lock again. With the key, door unlocks and stays unlocked. however, the feature when you turn key to the right two times...
intermittant is spelled intermittent. .... Ah, locking system. ... You will find a broken wire in one of the doors that are used to set the door lock.
Probably the drivers door return wire.
Oct 26, 2013 | 1998 Honda Civic
Mazda 6 2005 driver door jammed
if you talking about door latch wont let door close.try to reset all door locks.first if you cant get door close.work unlock button with remote or door switch.then hold open door handle while you flat screw driver pull up latch in door latch should stay up so door will close.once get door close.try resetting all door locks by sitting inside vechicle with all doors close.remove key from ignition.open drivers door.wait 24 seconds.turn ignition switch on and back to lock position 3 times.press and release drivers door courtesy light 3 times.ensure doors lock and unlock.if not wait 40 seconds and repeat procedure.if this procedure fails. you have problem in the door latch and lock mechanism inside the door itself.
Jan 04, 2013 | 2004 Mazda 6 Sport
Replaced battery and now the parking and dash lights blink a few times repeatedly and intermitently whenever I open and close the door. What is it trying to tell me?
you may have a factory alarm system that has enabled when power was lost. Try unlock and lock using the pwr lock switch...it may or may not work!!
May 25, 2010 | 1993 Nissan Pathfinder
My bmw316 year 1999 has a problem in key failing to recharge therefore unable to unlock car,when done manually with key cannot get into other doors? works intermitently help needed to sort out this...
sound like the micro switch on top of lock inside the drivers door may be faulty or displaced by slamming door this results in no unlock signal being sent to other doors and boots locks!
May 01, 2010 | 2000 BMW 3 Series
Hazard light and interior lights problem on 2001 A3
the indicator lights flashing constantly might be a warning from the car that all the doors have not been closed properly
after writing this ^^ i think that the system that tells the car if the door is open or closed it damaged or broken
and needs replacing
try leaving all the doors open and lock the car do the indicator lights flash contantly?
you need to get a dianostics done but due to the reson that it is intermmitant the problem will not exist when you get to the garage
check all the sensors that tell the car if the door is open firstly
Dec 31, 2009 | 2007 Audi A3
Jl Audio Stealthbox Single 10" VW Passat  98-05 Speckled Gray Logo
66 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
Matthew Spark
Matthew Spark
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
