Portable Televisions
Problem for Portable Televisions
Generic problem for all Portable Televisions
Switch to antenna mode without a remote
By smithd74 on Feb 22, 2008
I do not have a remote and have recently switched from cable to satellite and need to get to the menu options to change over to antenna so the dish works. can this be done? and how?
Solution #1
posted on Feb 29, 2008
Not Rated)
team tech
Rank: Guru
Rating: 86%, 91 votes
Can you access the menu on the front of the tv? Is so go into the menu setup and switch from cable to air then run the autoprogram to search your channels. If you cannot access the menu on the front of the tv then a remote will be required . Also if if your tv has audio/video jacks in the back of the set and you are not using them hook it up with those inputs for a better picture . Your have to push the input button to select that a/v input you used . Good luck
Was this helpful?
Yes
No
Popular Solutions for Portable Televisions
Questions and Unsolved Problems for Portable Televisions
Answer
when playing dvd, closed caption is on. have setting for cc off in menu???
Answer
My brother has the Realdigital 8.5'' tv, model # ATSC 850. The red light stays on even when pushing... (More)
Answer
change from dvd to tv -would like to watch satellite tv but do not know how to change source
Answer
no picture or sound coming from my television in my conversion van
Answer
need to convert settings in to english
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Portable Televisions:
Top Portable Television Experts
Rank: Guru Guru
Solutions: 727
Experience: 30 Years of professional repair and design.
Ask Me
Find more Portable Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
