Question about Car Audio & Video
I need to remove the driver's door trim to replace the speaker in my VW Touran. Can you tell me how I go about this?
  • iankr Feb 11, 2010
    Thanks a lot Scotty. I think the Touran door layout is similar, so it gives me a good start.
  • 37 Answers
Go to this web site and it will show you step by step on how to take it apart http://forums.vwvortex.com/zerothread?id=961163
Posted on Feb 10, 2010
How to remove VW Touran boot door panel
Google search "How to remove 2007 VW Touran boot door panel".
Do a Google search before going to Fixya; it's faster and you won't have to wait for someone to answer your question.
Feb 08, 2014 | Volkswagen Touran Cars & Trucks
Young son has pushed 2 cd's into single loading cd player in my 2005 VW Touran. It obviously won't eject any of the cd's. Any ideas
you need radio clips to remove radio and then you will have to remove cove of radio to remove cds
Apr 23, 2011 | Car Audio & Video
Need instructions to replace the passenger side mirror and the driver side tail light on a 1999 Ford Taurus 4-door sedan. Thank you, Gary S.
Section 01-09: Mirrors, Rear View 1999 Taurus/Sable Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 06/25/1998 Mirror, Power-Outside Rear View Removal
  1. Disconnect battery ground cable (14301).
  1. Remove front door trim panel (23942). Refer to Section 01-05.
  1. Remove radio speaker grille from cover assembly by squeezing or pinching between thumb and index finger.
  1. Remove two screws from cover assembly.
  1. Disconnect outside rearview mirror wiring connector (C515-LH; C615-RH). Remove wiring guides as necessary.
  1. Remove three outside rear view mirror retaining nuts. Remove outside rear view mirror (17682) while guiding wiring and connector through hole in door.
Item Part Number Description 1 17682 Outside Rear View Mirror 2 N621906-S36 Nut (3 Req'd) 3 F8DB-17D699-
AAW Cover Assembly Rear Substrate-LH 3 F8DB-17D698-
AAW Cover Assembly Rear Substrate-RH 4 N808968 Screw 5 F8DB-18B984-
AAW Speaker Grille-Standard (No Badge)-LH 5 F8DB-18985-
AAW Speaker Grille-Standard (No Badge)-RH 5 F8DB-18K901-
BAW Speaker Grille-Mach-LH 5 F8DB-18978-
BAW Speaker Grille-Mach-RH 5 F8DB-238A35-
AAW Speaker Grille-Blank (No Speaker)-LH 5 F8DB-238A34-
AAW Speaker Grille-Blank (No Speaker)-RH A - Tighten to 6-8 Nm (54-70 lb-in) ------------------
Trim Panel, Door Front
Removal
  1. Remove cover behind inside door handle.
  1. Remove screw from bottom of pull cup retaining front door trim panel to front door (20124).
  1. Remove three screws retaining front door trim panel to front door.
  1. NOTE: Do not attempt to remove more than one pushpin at a time.
    Using Rotunda Windshield and Molding Trim Removal Kit 107-R0401 or equivalent, remove the door trim panel by pulling one door trim panel pushpin at a time from the inner door skin.
  1. Disconnect electrical connectors as necessary. Refer to Section 01-14A.
Installation
  1. Follow removal procedure in reverse order.
  1. Replace all pushpins with new pushpins (N808994-S).
Front Door Trim Panel
Jan 14, 2011 | 1999 Ford Taurus
We have the Rosen A7 all in one system, dvd player for VW Touran, we don't seem to be able to get sound through the stereo only the headphones is there anything we can do ourselves to change this? Thanks...
there is an addendum in the owners manual of ours on page two saying only with VWs the A7 is not configured to provide speaker sound through the vehicle speakers. helpline number is 019332 732 331. We have a VW touran also and can't get it to work :(
Dec 24, 2010 | Rosen A7 Car DVD Player
Power window failure, 1998 jetta vr6 glx, driver side does not work and passenger side only goes down from drivers switch. also how does the trim panel come off to work on the door
Remove the little door nob thingy for lock and unlock it just screws off,, Then you have 6 Allen key bolts around the door trim, remove those. Then remove the door handle cover just pops off you may need a small flat blade screw driver. you have two big screws Philips head screws in there... Then remove your speaker cover then the speaker, then remove the speaker, then remove the speaker bracket, then lift the door panel out. The motors and the regulators for your windows are **** door man makes a good unit for them i replace all 4 of mine... They are expensive Partsgeek.com is the best price i could fine. Looked for 2 years in junk yards and posted adds for replacement parts don't wast your time its damn near impossible. cost me about 500 for the 2 front window motors and regulators and I only replaced the regulators on the back windows I think they were about 50 a peace.
Jun 28, 2010 | 1998 Volkswagen Jetta
How to dismantle vw touran wing mirror
3598458-2hnw5qnnlcuxxqdipdrh2pk0-1-0.png FIRST U MUST REMOVE THE MIRROR.BE CAREFULL THEY TEND TO CRACK.THEN UNBOLT THE 2 TORX N8 .NO 8 AT THE ILLUSTRATION.REMOVE THE COVER GENTLY UPWARDS.UNCLIP THE INDICATOR PLUG WITH THE COVER OUT U MUST SEE ONE MORE TORX NO8 UNBOLT AND REPLACE THE INDICATOR.REPEAT THE PROCEDURE BACKWARDS TO ASSEMBLE THE MIRROR.CLICK IF U FIND THIS HELPULL.LET ME KNOW IF U NEED MORE INFO...GOOD LUCK!!
Dec 08, 2009 | 2009 Volkswagen Tiguan
Front passenger door of VW Touran 2005 model will not open
a clip or retainer for the actuating rod has broken or popped off,you need to remove the door trim to get to it and that could be hard seeing you cant open the door but it can be done,fairly straight foward once the door trim is off
Sep 30, 2009 | 2005 Volkswagen Passat
Reset the service light on a vw touran 2005
Look in owners manual you can do this yourself very easily using ignition,milage reset button and clock reset button it's in the book cant remember which page
May 30, 2009 | 2005 Volkswagen Touareg
My driver side door handle is broken on a 2003 VW new beetle. How can I fix it?
remove the inside door trim and remove the weatherproof plastic that covers the holes in the door behind the trim.
You should have access to the door handle nuts and rods to remove the handle.
re assemble in the reverse order and make sure the weatherproof plastic is put back on and sealed or your door may let water enter the car via the door
May 12, 2009 | 2000 Volkswagen Passat 4Motion
1999 Econoline E150 Van mirror replacement
Remove the door handle bezel.Remove the power window/door lock switch bezel.Remove the rearview mirror fastener trim cover.Remove the 4 door trim panel retaining screws.One that was behind the mirror trim cover,behind the switch panel,behind the door handle bezel,and one at the bottom corner.Lift the door trim panel up from the door to disengage the trim panel clips.Remove the front radio speaker. Disconnect the power mirror wiring connector.Remove the 3 bolts to the mirror.
Feb 08, 2009 | Ford E-150 Cars & Trucks
Car Audio & Video Logo
496 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
