Question about ASUS P5KPL-AM SE Motherboard
I have windows 7 32 bit when i shut duwn the computer he didnt shutdown the moterboard(computer), but only the monitor. i look to bios but there is every thing okey. help
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 61 Answers
Ur not actually shutting it down , you're ,aking it go to the sleep state. this is a common confusion with vista and 7 users bcz the default operation for alt+f4 on desktop is sleep . so make sure u select shut down from the drop down list menu there.....
Posted on Feb 08, 2010
When i shutdown my computer after that when lcd goes black then at that time a message shown on the black screen that "no input signal" and also glows little bit light with this message continuously.
Your monitor may have an option to set it as "manual" or "auto". If set in manual, you will have to turn off the monitor power switch each time. If it has the "auto" setting , it should shut off or "go to sleep" when it detects no input signal.
Oct 18, 2014 | Samsung SyncMaster 713BM 17" LCD Monitor
Dell 4700 bios a06 2.8 ghz 64 bit bus=800mhz pentium 4 2.8 ghz microsoft xp pak 2 moterboard light= green abcd lights=green reset bios to factory settings computer keep shutting down.. windows dialog box...
You have a rootkit virus, the only answer is reformat the drive and start fresh, sorry.
After a fresh install is done immediately install service(can be downloaded free from microsoft.com) pack 3, because sp2 is vulnerable to a host of trouble.
Apr 17, 2010 | Dell Dimension 4700 PC Desktop
About 10 seconds after i turn on my aspire 3690 the fan shuts down. the laptop will run for several minutes and then it shuts down also probibly from overheating. The fan starts each time i start but shuts...
First thing I'd check is for a BIOS update for your computer under the Acer support pages (acer.com). In some cases, thermal control updates are included in newer version of the BIOS, if it is a manufacturing problem.
Goto http://www.cpuid.com/hwmonitor.php and download Hardware Monitor, start the computer and immediately run the hardware monitor app to check how high the temperature on the CPU gets before it shuts down.
Continuing use under this condition may damage your Windows installation because of the sudden shutdown.
Mar 21, 2010 | Acer Aspire 3690-2196 Notebook
When I turn on my computer the monitor remains dark unit after about 10 mins then I get the windows desk top. If I shut down the computer (normal shutdown)then restart I get the normal startup...
Try connect your monitor to some other box and try if it works the same way or as a normal pc boot. If it works well with other box, the issue is with the BIOS. Get the BIOS flashed with the latest version of flash program for the Bios chipset which your board is using. If the monitor shows the same symptom on a different box too.. you may need to get your monitor repaired. Good Luck
Feb 14, 2010 | ASUS P5PE-VM Motherboard
Monitor indicates no signal shuts off
try checking your windows monitor settings and disable the windows monitor shutdown timer. also, check the cables and try to keep them firmly in place (duct-tape would be useful for that). if the problem is related to windows settings, then ok. if not, use the second resolution. I'm glad if could help!
Feb 06, 2010 | Gateway FPD2275W LCD Monitor
Unable to shutdown the computer
it is the problem your computer operating system or motherboard bios setup problem . You restart your pc after restart then press dell key then prevew your bios setup option then choice bios defalt setup then press F10 press Y restart your pc .
Jul 21, 2009 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
My screen is blank. The computer appears to be
Sounds like a driver problem. Hold F8 when it's booting and try Safe Mode
Jun 29, 2009 | Toshiba Satellite A135-S4527 Notebook
Shutdown
There could be any number of reasons for this to happen. However, the most likey reason - assuming that it runs for a bit, and then shuts down - is that the heatsink/fan on the CPU is not working, or not installed properly. Once the CPU heats up to a certain point, it will shut down to prevent damage. Perhaps the CPU fan as gone bad, or is completely clogged with dust.
Feb 03, 2008 | Computers & Internet
Can not save to bios
windows and the bios needs to know that the operating system can be shut down through windows, so when you go into the F2 or Del on boot up, go into advanced cmos setings and look for ACPI and make sure it is enabled. This sets the motherboard to support shutdown. Save and exit settings and reboot. Now go to control panel>performance and maintanance>power options and set the correct instruction for shutdown to shut the pc down. Remember evertime you remove the cmos battery or reset with jumpers you have to reset date and time and anything else you have changed to suit your set up
May 06, 2007 | Abit KN8 SLi Motherboard
ASUS P5KPL-AM SE Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
