Question about NEC VT37 Multimedia Projector
NEC VT37 I am having problems with the focus ring (possible jammed). Is there a way to fix this problem or is it worth fixing? The machine will not focus.
  • nfpaezinvest Sep 30, 2008
    It does not turn at all... It worked fine last week, but now it seemes jammed.
You auto focus or you can manually rotate the lens for focus
Posted on Feb 23, 2008
How can I adjust focus?
Turn the grey ring around the lens (where the light comes from) until the image is sharp.
Apr 11, 2016 | NEC VT595 Projector
Change bulb in NEC 47 projector
Original lamp USD100
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Aug 16, 2014 | NEC Projector Lamp for VT37 47 570 575
My camera won't focus anymore. Any thing i can do?
Inside the lens assembly is the focusing ring. When dirt, dust, lint, or sand work their way inside it can jam the circular geared movement necessary to focus the camera. The ring has two electromagnets on it, controlled by signals and feedback from the main board, to achieve focusing. To try to fix this, try to spray some compressed air into the lens assembly, holding the camera upside down. If that doesn't help, try different points around the lens. After trying that, you can try to bump the camera slightly, to try and dislodge a stubborn jam. sometimes the ring has sprung off its track, and you can reseat it by gently knocking it back into place. Hold the camera with the lens facing up when you do this. Otherwise, it's not a cheap fix, so get an estimate before you have it serviced. You can do it yourself, if you're inclined, and there are a lot of videos and information on YouTube. Good luck, and hope this helps.
Jul 26, 2010 | Canon PowerShot SD600 Digital Camera
Dropped lense, hit the outer ring, now won't
No quick or cheap fix, but definately a lens worth fixing- send it to Canon
May 11, 2010 | Canon EF 70-200mm f/2.8L USM Lens
Vt37 will not focus
if the focus ring and zoom does not work, make sure you are within the designed throw distance (2-24 feet). if you are, you have a lens issue and will need to send it in for repair.
Jan 12, 2010 | NEC VT37 Multimedia Projector
How do I focus the NEC VT47 projector? I have tried to rotate the focus ring and it won't move
I eventually fixed it; just a mechanical problem;I had to use strength to make the ring move again; 5586904.jpg
The arrow shows the direction of my movement; I had to use both hands; be very careful but also be aware that I had to put a lot of strength to manage to unlock it; good luck!
Jan 08, 2010 | NEC VT47 Multimedia Projector
Screen not clear
first the obvious, clean the lens with a soft, cotton cloth. next, use the focus ring on the lens. if it's motor driven, use the buttons on the top.
Jul 24, 2009 | NEC VT37 Multimedia Projector
Nec projector
go into menu, under image, and chose ceiling.
Apr 08, 2008 | NEC VT37 Multimedia Projector
Status indicator blinks RED, not starting.
There are different rates at which the status light will blink to indicate various errors. See manual (link below) page 49 http://www.support.nec-display.com/dl_service/data/user_manual/ENGLISH/VT37/vt37_manual_e.pdf
Jul 29, 2007 | NEC VT37 Multimedia Projector
NEC VT37 Multimedia Projector Logo
688 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
