Question about Maytag Neptune MDE5500AY Electric Dryer
Dryer has developed a noise (clunk) as it turns
  • 10,319 Answers
The clunk is from a worn bearing on the belt tensioner that the drums belt goes through. If the bearing freezes up the rubber layered roller will get out of round and sound like a drummer beating on a drum
Posted on Feb 08, 2010
5 Suggested Answers
  • 489 Answers
SOURCE: clunking noise
The clunking noise may be a broken weld on the drum.  Every time it turns and passes through the guide wheel supports, it makes a thunk thunk noise.  You will need to have a qualified LG technician diagnose the problem correctly but that's what it sounds like.
Posted on Jun 11, 2008
ginko
  • 19396 Answers
SOURCE: Our Whirlpool dryer is Wed530sqo
Probably the belt has broken.
The technician will gain access to the back of the dryer to replace the belt.
You can find replacement parts and assembling diagrams on website here.
Posted on Feb 02, 2009
SOURCE: Maytag Dryer clunking noise
may 26 2009
My maytag dryer is making a very loud squelling sounds in some of it cycles. still drying ok
gmalcom
Posted on May 26, 2009
hunter19_46m
  • 7482 Answers
SOURCE: Dryer is making a clunking noise, even when empty
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication. If you have a front loading machine, Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor. Now is a good time to check the belt condition for wear. Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt. Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps Please rate me, Thank You
Posted on Dec 28, 2009
Got clothes out my dryer and turned the drum clockwise to get a lint. Heard a loud clunk noise and now it wont spin. Please help
check for a broken drive belt for the drum
the clunk may have been from the belt as it broke and hit the cabinet
Apr 07, 2015 | Dryers
My stackable dryer (417.94702300) makes a clunking noise. We just got it (craigslist) and it happened the 1st time we turned it on. Sounds like we're trying to dry a shoe in there - it clunks in rhythm...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 16, 2011 | Kenmore Washing Machines
Washer makes loud clunking noise &so does dryer when moving around, you can turn the basket by hand to make it clunk.
heatman101
ghgf
Sep 03, 2010 | Splendide 2100 Vented Washer-Dryer
Our drier is making a clunking noise, and the barrel has developed a small crack at the front.
your door seal, front drum bushing needs to be replaced it is a felt type soft unit that is installed directly at the front of the drum just behind the front cover
Apr 28, 2010 | Maytag Neptune MDE6700A Electric Dryer
Sounds like you need a blower wheel.you will need to remove the front panel and the houseing under the front panel.It is located on the bottom front laft side. if you need help on assembly or disassembly let me know hope i fixya :)
May 20, 2009 | Dryers
Dryer works fine just makes this real loud clunking noise when i
I have seen this before. One of your wheels has developed a flat spot or has seperated from the bearing.
Dec 27, 2008 | Kenmore 84052 Dryer
Clicking and clunking
most dryers suspend the drum on felt glides, nylon glides and rubber tired rollers, if these are worn or locked up, there are regular clunk noises.
Aug 18, 2008 | Whirlpool LER4634J Electric Dryer
Clunking noise
Jun 07, 2008 | LG DLG5988 Stainless Steel Gas Dryer
Dryer
Hi Kyboy49,
The drum rolls on idler wheels. Sometimes the lint and stuff clings to these wheels and causes the cluncking noise you speak of. You will have to pop up the lid and see if you can reach the wheels for cleaning. You may have to pull the front panel off.
Oct 23, 2007 | Whirlpool LGR7646E Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
244 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
