Question about Marantz CD-5000 CD Player
Marantz CD-5000 CD player
My Marantz CD-5000 worked satisfactorily for some seven years. Now it will play 2 or 3 tracks, then gradually grind to a halt. I have tried running a lens cleaning disk but it didn't want to run and didn't make any difference when it did.
    Brigadier General:
  • 6,966 Answers
If I may add to XX's post and with his indulgence...
It may also be worth your while to check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track. Please refer to the image below.
Image was adapted from How CD Works.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Feb 22, 2008
  • Louie  Role
    Louie Role Feb 22, 2008
    Ooops, templating again, sorry coolguy008, the XX was supposed to be you. Cheers.
  • Louie  Role
    Louie Role Feb 23, 2008
    Hi Compurepair,
    Guess we're on the same track. Regards.
    Genius:
  • 1,019 Answers
i,d suggest that if it only plays the first 2 or 3 tracks, then the laser mechanism isn,t travelling to the outer edge of the disk.
this can sometimes be remeded by applying a small amount of vaseline ( petroleum jelly ) to the spindle(s).
also check that the ribbon cable isn,t snagged, which will not allow the laser head to move completely from the inner, to the outer edge of the disk.
Mike @ Compurepair.
    Genius:
  • 3,422 Answers
See if the player tries to read the disc. Load a disc and listen.
Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
If still ur problem is not solved then i am sad to say you have to get it repaired and thats the only solution..
Good luck..
  • Priya darshan Feb 22, 2008
    Click HERE for the user guide.
    Here is the main support no. (630) 741-0300
I have Marantz Sa7s1 cd player it plays cd for a couple of tracks & then it stops & distorted noise comes into player it skips sometimes
If it does all that stuff then, you need to take it back or exchange it. If you like the company just exchange it, if not buy from some other company.
Oct 27, 2016 | Marantz Audio Players & Recorders
Hi _ I have a Marantz CD player a littl;e over 6 years old. Performed perfectly until today, when it started inserting brief gaps in the music, approx 1-2 seconds; at the same time the track / time...
laser cleaning cd's very rarely work. the only thing they are good for is if there is a build-up of dust on the lens. Sounds like you most likely need to have the laser replaced.
Feb 11, 2014 | Marantz CD5001 CD Player
Marantz CD5003 CD Player pauses
Not may be! It is. Check and replace it.
Aug 10, 2012 | Marantz CD5003 CD Player
I just bougth a marantz cdr 300 cd recorder,everything seems to be working fine, but I'm not able to listen what I just recordered on any other cd player.Marantz cd 72 mr 2020.Thanks
It sounds like you haven't followed the last step to the burning procedure. All you need to do once you've completed burning your disc is to Finalize the disc. Read below why you need to finalize as well as the steps to follow in order to finalize the disc.
Hope this helps ;)
How to Finalize Finalizing is writing the TOC (table of contents) on a disc so a CD player can recognize the number of tracks, the total time for each track, and their location on the disc. A recorded disc must be finalized to playback on a standard CD player. Once finalized a CD-R disc can be played on CD players that support CD-R playback. CD-RW discs can only be played on CD players that support CD-RW playback. Consult your CD player owner's manual to confirm supported formats. Finalizing is necessary to: • be able to play a recorded CD-R or CD-RW disc on a CD player • prevent further recording on a disc • avoid erasing tracks on a CD-RW disc • record text information onto a disc you record Notes: • A finalized CD-R disc can never be recorded onto again. • A finalized CD-RW disc can be unfinalized for more recording. • The CDR300 can play back unfinalized CD-R or CD-RW discs. • SYNC REC+FINAL mode automatically finalizes.
Here are the steps in order to Finalize your disk
1 Push Stop. The display shows the number of tracks and their total playing time. 2 Push FINALIZE. FINALIZE is displayed for about 3 seconds.
Jul 27, 2011 | Audio Players & Recorders
Remote not working on Marantz 63cd. Tried
check the back of your marantz player, some old marantz products have a buttom at the back saying system or intermal, if it is on the system side, the remote will never works.
May 06, 2010 | Marantz CD-67 SE CD Player
My Marantz CD63SE SPECIAL EDITION CD PLAYER won't read discs
Most likely, new optical (lazer) pick up required to solve this issue.
Nov 30, 2009 | Marantz Audio Players & Recorders
My one-year old Marantz CD5001 CD player
these models use the 12.1 philips laser mechanism and it is a very common problem for failing to read discs.
various technics / marantz / philips / cyrus cd players etc also use it and are plagued with the same fault.
it's a 90% chance the laser is dead!
philips realised the unreliability of this laser and uprated it to the identical looking VAM-12.
do not dismiss the spindle motor as these also fail quite alot on this mechanism.
hope this helps.
Dec 20, 2008 | Marantz CD5001 CD Player
NAD 5000 CD player
I FIX MY NAD 5000 CLEANING THE LASER LENS USING COMPRESS AIR
Nov 06, 2007 | Audio Players & Recorders
Marantz CD-5000 CD Player Logo
816 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
