Question about Panasonic KX-T7730 Corded Phone
I need to have our Panasonic KXT7730 to ring at reception but instead one of our lines rings on another phone in another room. How can I change it to ring at reception.
  • 113 Answers
Hello, I presume that you are using this phone on a 308 or 824 system. You will have to check which line is ringing at the other phone. Is it line 1,2 or 3 ? Say for example it is line 2 you need to do the following: From the main phone / switchboard usually ext 101 press PROGRAM * # and your system password ( default is 1234 ). Now enter 408 and press SP-PHONE. The system now asks you to enter the line and in this example we use line 2 - so enter 2. The display now looks like this CO 2:#01: with ENABLE or DISABLE flickering. (CO 2 is the line number. #01 means extension 101, #02 means ext 102 and soforth.) To enable the line to ring at ext 101 choose ENABLE by pressing the AUTO ANS / MUTE button. Now press AUTO DIAL / STORE to save your changes. Now use the right arrow key ( located at the right bottom corner of the phone ) to move to the extension that you don't want to ring - say for example 106. Your diplay should now look like this CO 2:#06 with ENABLE flickering. Now use the AUTO ANS / MUTE button to set it to DISABLE and press AUTO DIAL / STORE to save your changes. Press PROGRAM to exit program mode.
PLEASE VOTE / RATE MY ANSWER IF THIS WA HELPFUL - THANK YOU.
Posted on Mar 24, 2010
How to stop / edit all incoming calls ringing to other 2 extensions at the same time?
What phone system are you using?
I will gladly show you how
KX-TEA/TES/TA series or KX-TDA/TDE/NCP series
Oct 25, 2015 | Panasonic KX-T7633 Corded Phone
CO problems
Check your Phone if connected to Jack 01 to do programming below:
on KX-T7730 phone Press Program *# (enter Password) default is 1234
Press 400 SP-Phone(CO NO.? will be displayed) Press *(Mixed or Connect will be displayed), Press AUTO ANS/MUTE untill (NOT Connect will be displayed) Press AUTO/STORE. Press HOLD(SYS PGM will be displayed) Press 400 (CO Connection will be displayed) Press SP- Phone(CO NO.?) Press SP-Phone (Not Connect will be displayed) Press AUTO ANS/Mute until (Connect will be displayed)Press AUTO/STORE PRESS PROGRAM to return to NORMAL Display.
For the incoming Calls PRESS Program *#1234 (ENter Sys PGM will be displayed) PRESS 408(Day IN CO will be displayed) Press SP Phone (CO No? will be displayed) Press SP Phone (CO1:#01:DISABLED if this is displayed PRESS AUTO ANS/MUte the Enabled will be displayed) Press AUTO/STORE. Press Program to return to normal display. In this Manner All Calls will ring to extension which is connected to Jack 01. you dont need to press the button anytime there is an incoming call.
Dec 04, 2013 | Panasonic KX-T7730 Corded Phone
How can i pick up the call from my office phone when reception phone rings
Hello,Looks like you'll need to re-program your PBX unit. I would suggest looking up: 1.5.3.3 Outside (CO) Line Access 2.2.4 Operator/Manager Featuresin the Programming manual found here:
http://www.tongxun.com.cn/data/download/Feature_Guide.pdf
Hope this helps
Nov 27, 2012 | Panasonic KX-T7730 Corded Phone
How do i program the panasonic kxt-7731 so when a call is coming in i can just lift the handset to answer instead of pushing the co line
You have to do 2 things: Make it ring and turn on Line Preference-Incoming Ringing line. The first is done from SYSTEM programming in programs 408/409/410 for DAY/NIGHT/LUNCH. The second is defaulted to Ringing so if the phone rings, it's supposed to work. If you've changed it, then from your idle phone you press PROGRAM and dial 22 STORE. (21 is no preference and 23 plus a number is a specific line).
Carl
Apr 26, 2011 | Panasonic KX-T7731 Corded Phone
I want to see the phone number of prson that called me and i answer him. KXT7730
Your Panasonic System display phone is capable of showing CID if you have a CID card in your TA/TD/TAW or higher series phone system and have done some programming. The card part number ends in 93 and installs inside the cabinet for the particular system. After the card is installed, programming turns it on to tell the line to wait for the CID string before ringing the phone.
Your phone also has to be ringing or you won't see CID until you answer the call.
Carl
Apr 03, 2011 | Panasonic KX-T7730 Corded Phone
Need all incoming calls to ring on preferred phone
Depending on how the private lines were programmed, you need to pull the ringing out of DIL 1:1 if it was assigned and put it into DIL 1:N. Look at programs 407-8 and 603-4.
Carl
Feb 18, 2009 | Panasonic KX-T7425 Corded Phone
Why is my phone ringing?
Your Handset has been programmed i guess by mistake to be in the same ring group as the main receptionist for C0-01 . Use Google for programming manual to make changes.
www.heymot.co.uk
Oct 17, 2008 | Panasonic KX-T7633 Corded Phone
Panasonic KX-T7730 Corded Phone Logo
328 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
