Question about Motorola Mobility Mobile PhoneTools 3.0 (98654H) for PC
About motorola v3 flash file help
Hows u
when i download the motorola v3 it come with shx extention but i need mfw extention so plz help me about this problem. because the customer is getting angry on me.
thanx in advance
My mobile is say contec cervice provider
Posted on Feb 27, 2008
I cannot download MFW files.
you need MFW player. Google for it
Mar 29, 2015 | HP Computers & Internet
Tip
How to mod your motorola Razr
Requirements: windows xp, Vista, or higher
a computer with enough space for the below programs, and a USB cable
Motorola Flash and back up
Motorola RSD Light
Motorola drivers
Flash (*.shx) file
find the flash file you would like on your phone (I had used the I-Phone shx file)
Plug your phone into the computer
Start Flash and backup
this step is EXTREMELY IMPORTANT incase you BRICK your phone:
Back up your phone (boot loader and phone)
Start RSD Light (after back up is completed)
click show device
click the 3 dots next to the file name entry field
browse to the file you would like on your phone
select it
hold down control key
select the new firmware (can keep the old firmware if you would like)
click start.
Your phone is now being flashed to your desired system that you selected.
depending on the shx file, this may take some time. once this step has been completed, you have a completely modified phone. if you want to modify the phone further, there are some seem editors that can be used (I tried p2k seem editor, that didn't work very well) and I had found another one, but I dont remember it's name.
Good luck, and as always, be careful.
thank you for taking the time to view this post. I hope it was helpful. email me if you would like more information (guest.user73 at gmail.com).
by:
The new Motorola I-phone.
on Mar 15, 2010 | Cell Phones
Blue screen, says Bootloader USB Init at bottom, won't restart with power key
1.go to http://www.modmymobile.com
2.download p2ktools zip file
3.extract zip file
4.down firmware for motorola razr v3 zip file
5.extract razr v3 zip file
6.open p2ktools extracted folder open p2ktools exe file
7.read help how to flash your motorola razr v3
Aug 24, 2011 | Motorola Mobility RAZR V3
Unlock code 4 free
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
First of all, if you have a Razr v3 phone and would like to unlock it, I would recommend reading this thread: http://forums.afterdawn.com/thread_view.cfm/18/283892 by scabbins, which I think was originated from: http://forums.mobiledia.com/topic43620.html or perhaps from http://forums.mobiledia.com/cgi-bin/redirect.cgi?http://www.motox...
1. CellPhones have something like a Operating System, and also a BootLoader, which loads the Operating System. You can view the version of the Bootloader and the software(Operating System) of the phone by holding down * # and pressing Power button when the phone is turned OFF.
2. You will often hear terms "Put the phone in Flash" or "Flash the Phone". When they say put the phone in Flash, it means, turn it off, hold down * # and press Power button. What happens is that you will see text displaied on screen with the version of bootloader and version of software( SW ).
3. After you read the above mentioned tutorials keep some points in mind: First, If your Bootloader version ends on 26, and you use the "Downgrader" software mentioned in tutorial, there will be a point while running downgrader, when it will stop and tell you it is waiting for phone. (This happened only once, when it was waiting for a while) what I did is put the phone in flash mode manualy, that is I pressed * # and Power. After doing so Downgrader continued working and finished sucessfully. After putting the phone in Flash mode again, you will notice that now the Bootloader version is 7D0.
*Note: Flashing a phone means reinstalling the System software on it. "Flash the phone with "somefilename.shx" means taking "somefilename.shx" file and using smartmoto(software) or RSD Lite(software) to rewrite the system software with a new one contained in "somefilename.shx".
Now, If you did everything the way tutorial suggested, but The phone still tells you to "Contact Service Operator" be calm, and dont start shooting neighnpours. I will consider you as an experienced user from now on, and read how to make it work in next section:
Note:
If you tried all that is saied in tutorial, and phone is still locked, then you are in the same situation that I was. Here's what you need to do: (by the way I found solution by reading all messages in http://forums.mobiledia.com/topic43620.html so credit goes to guys there)
you will need to do this:
1. Downgrde bootloader if you have 26 version.
2. Install OLDER version of software(SW) on phone. ( Dummies, this means Flushing the phone with old version of .SHX file) I found those files on this site: http://www.planetmotox.net/monster_packs.php and for the old version I used: R374_G_0E.40.79R_MOTOX.shx .
(Dummies notice, put the phone in flash mode, connect the usb cable and flash the phone using smartmoto or any other software that you prefer with the above mentioned file).
Important Note 1: After this phone might not reload (dummies, I mean by this that you will not be able to start the phone as you did, you will see a blank dark screen.
Do not panic, put the phone in flash mode again and run the Unlocker mentioned in tutorial. This time it will work, but you still will not be able to start(reload) phone.
what you need now is to flush newer version of System software on phone, I used R374_G_0E.42.10R.shx from here: http://www.planetmotox.net/monster_packs.php
now the phone will reboot, and will be unlocked!
Note, flushing deleted all my data and phonebook entries, you might want to back them up using Motorola phone tools before you flash the phone.
Thats it.And remember, always read threads carefuly before asking questions
Apr 18, 2010 | Motorola Mobility RAZR V3
No. i need to unlock my motorola razor v3 for
My friend gave me a razor to unlock last night that he just bought from a long time user on Cingular network. Since I unlocked without trouble I thought I would help someone out. Basically you need to flash one software into your phone, then you need to run another program and unlock it. Here is how I did it. Download and install EMULE, a free program. Run EMULE and select edonkey network only and forget KAD network during setup. Don't upload with emule in chunks as I believe it takes more processing power from the PC. Now run EMULE and click Connect. After it connects search for a program called P2K.EASY.TOOL. It will be around 6.2MB file. Extract all the files and look for a file called P2K_Easy_Tool_v39 and extract this also. Next, you need to get the program called RSD Lite 3.0. Again get this file by searching emule for this and downloading. Then install the program by double clicking on .msi or right click and click install. Now get the program Motorola_Unlocker_2005.zip. This can be found quicker at themotoguide.com/unlocking.php. This file may not be necessary or this step! CHARGE the phone to full charge. I forgot two more file are needed! You'll need to USB drivers for the phone. The ones I used were v3_drivers.exe (search yahoo) and always click continue anyways. Finally, you will need bl_826-828_to_07d0_ for_V3_by_Archy.V2.shx (no space between 07d0_for_) and this file can be gotten at themotoguide.com/unlocking.php. If you attempt to communicate with the phone it may want to install drivers and you may have to do the operation again. When installing drivers, just specify the folder where you extracted USB drivers. Now lets get started. Plug the phone into USB cable and turn on. Run the program called RSD Lite 3.0 and then it should say connected and show your phones IMEI #. If not, you could restart phone, but press # and * with one hand then start up. Now it should say in RSD LIte 3.0 something different. You can leave it like that or restart phone and then you should definitely see IMEI #. Now click on FILE in RSD Lite 3.0 and search for the file bl_826-828_to_07d0_for_V3_by_Archy.V2.sh… and click OK. Now lets downgrade the bootloader, click START. Wait tell it is done and finished at 100%. Don't even mess with the computer during this time or any cables. Turn phone off and hold down * and # on phone again and turn phone on into Flash mode again. It should say 07d0 now or be a blank screen, which is fine. Now run the program Motorola_Unlocker_2005, click send to phone. It will do something and your phone will reboot. If it is unlocked then you are done. If it didn't work as mine didn't with this step then turn phone off for third time. Again boot up in flash mode by holding down both * and # and turn on with other hand. It will be in flash mode with black screen. Now run the program called P2K_Easy_Tool_v39.exe and there is one other file in this folder called winscard.dll. Click on LOCKS and then select your phone model. Now select Unlock SP. Click on DO SELECTED JOBS. It should show the status above and will do some work, then reboot phone do some more work and power off, I remember. That is it turn it on and you are done. Lets sum this up on what is needed. EMULE, P2K.EASY.TOOL, RSD Lite 3.0, Motorola_Unlocker_2005.zip, bl_826-828_to_07d0_ for_V3_by_Archy.V2.shx. You could probably skip the Motorola_Unlocker_2005.zip step. If for some reason you destroy your phone! You have a 80% chance of recovering it by going to www.themotoguide.com/downloadfirmware.ph… and getting one of these three files, extracting it. Then flash it into your phone with RSD LITE 3.0. Do not do any of these steps if it is illegal in your country or you don't deserve to use your phone yet or buy talk time from a network!!
http://www.themotoguide.com/unlocking.ph…
Hoped it Help.....
Aug 01, 2009 | Motorola Mobility RAZR V3i Cellular Phone
MY RAZR WONT UNLOCK
I had the same problem with a phone that was donated -- user forgot the pin to unlock the phone. There is a way around this. You will need to reflash the phone. I used RSD Lite, which is a Motorola Utility for flashing their devices.
But first, you will need a flash file to overwrite the one on your phone that is associated with the pini code. To find an appropriate flash file, search for "ModMyMobile" which is a forum that has various Razr flash files. You will need to enroll, but its free.
Locate and download the appropriate .shx file and unzip to a directory on your computer that you can easily find.
Run RSD Lite and connect your Razr with a USB cable. The program should locate your phone and put it into bootloader mode... don't panic, it is supposed to. Now click on the "..." button up top, locate the unzipped .shx file and hit "Start".
It takes about 5 minutes to reflash and presto - you phone is working again! :-)
Jul 02, 2009 | Motorola Mobility RAZR V3
After Flash for new firmware button can't use
did you remove the battery?wait for a minute and try again.
Oct 23, 2008 | Motorola Mobility RAZR V3
How to? plz help
Hello!
Simply download .jar (java executable) files from PC to Mobile's KJAVA folder & install it afterwards. It's seems easy & it is too!
Otherwise go to
http://gallery.mobile9.com/c/motorola-razr-v3-themes/1/
Download themes on your pc
And then transfer then to your phone threw data cable or directly download then to ur phone via GPRS.
Find out all you want to know about your cell
http://www.techbaba.com/faqs/cell+phone+question+answers.aspx
May 08, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Phone set up
You need to flash a different language pack to the phone.
Look at this online manual on how to hack and upgrade the V3
http://v3x.themotoguide.com/index.php?PID=1&PGID=433#
Then:
Get language pack here:
http://www.planetmotox.net/language_packs.php
I have used this one. It is a modified language pack with only english.
R374_G_0E.41.C0R_MXLP0001_reflash_MOTOX.shx
now flash to your phone and you will have only english
Oct 20, 2007 | Motorola Mobility RAZR V3
Motorola v3 free software upgeade
you can get updates and installations for your phone software here, they automatically load the drivers when you connect the phone to a usb port via the cable. http://direct.motorola.com/ENG/SoftwareUpdateSummary.asp?country=GBR&language=ENG&web_page_name=SUPPORT&strCarrierId=&strPhone=RAZR%20V3&strCable=Mini%20USB%20Data%20Cable
Jun 08, 2007 | Motorola Mobility OEM Bluetooth USB PC...
Motorola Mobility Mobile PhoneTools 3.0 (98654H) for PC Logo
101 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
