Question about HP PSC 1315 All-In-One InkJet Printer
Jam CAN;T GET RID OF A PHANTOM PAPER JAM
  • 10 more comments
  • Al Belle Feb 22, 2008
    I've the same phantom paper jam,I can't get it to go away & I can't see where's the paper jam.
  • rcanela Feb 26, 2008
    Hi! I have a psc 750 (HP) and it has had a phantom print jam. I tried cleaning the rollers, unplugging it... and I can't use any other of the functions either because of this message.
  • fjmustak Feb 29, 2008
    My 3930 Jammed twice in a row, I pulled the paper out, and restarted it, but the status in the Printer Control Panel says 'Paper Jam'. I turned it on and off, and unplugged it and plugged it back in to no avail.
  • Anonymous Mar 03, 2008
    Samsung CLP-500 Laser printer keeps showing an error message ''Paper Empty Custom in MP'' even though there is paper in the tray.
    It also indicates a paper jam in the top right hand compartment but I have checked all roller feeds and ther is no paper jammed .
    Any ideas
  • jackwjwang Mar 07, 2008
    I have the same problem.
  • Diddlydi Mar 12, 2008
    As much as every other print job, we get the phantom paper jam message.... and once we restart the machine, it works fine! It is a Kyocera FS 4000DN-help!
  • Samthesham Mar 15, 2008
    Paper jams inside the printer when ever I print in color. I replaced the fuser, but I still have the same problem.
  • nayeem001 Mar 24, 2008
    It says PAPER JAM, but I am positive there isn't any paper jammed anywhere... How do I fix this Brother MFC-8840D??? Please email me Texas83@gmail.com
  • Anonymous Mar 25, 2008
    Repeatedly says paper jam. I have checked everythig there is no jam not even a tiny bit.
  • AVDCSG Mar 27, 2008
    I have a MFC 410CN printer which is giving the same paper jam message, there are no bits of paper in it and the message appeared halfway through printing a page which didn't jam.
  • Cate McDonald Mar 28, 2008
    I have the same problem...the machine is a HP Photosmart 2575 All-in-One (printer/scanner/copier). Each time I try and print it doesn't work as the printer thinks it has a paper jam. There is no paper jammed! Hope someone can help I am getting desperate...and need to print an assignment now :) Cate
  • Thomas Christopher
    Thomas Christopher May 11, 2010
    Printer manufacturer and model please,,,,,,,,,,,,,,,
    President:
  • 2,072 Answers
Exactly what does it do? If the paper is not leaving the tray, then most likely the feed rolls need either cleaned or replaced.
Try taking a cloth with some alcohol, or soapy cleaner such as fantastic and clean the rollers throughly. If that works for a while then the problem returns, the rollers are worn and in need of replacement,
If that's not what kind of jam you are experiencing, please provide more detail and I will pursue it further with you.
Phantom jam makes me think its just not feeding out of the tray, and there is a lot of slipping with those feed components
Posted on Feb 22, 2008
I had the same problem however; none of the suggested solutions helped. I solved the problem by- uninstalling the printer and then reinstalling it again.
It is now working like a charm!
Posted on Mar 30, 2008
It says there is a paper jam. There was a paper jam. I took the pape out and now there is no jam but the machine will not reset. This is a HP PSC 1315
Posted on Mar 29, 2008
How to clean the rollers of epson photo R230? th
anks
Posted on Mar 14, 2008
There is an orange roller that falls apart. you have to have it repaired or buy a new printer
Posted on Mar 07, 2008
I had a phantom paper jam on my Canon Imageclass MF5550. I looked at the rollers and they looked brand new, no gunk, nothing. So, I tried more paper, then barely any paper in the tray. Neither one of those worked. THEN I noticed that the edge of the stack of paper was about 1/2 inch back from the normal front edge of the tray, but still being held down by the tabs on either side. I looked at the blue sliding plate that moves depending on how large your paper is and it was set to a slightly larger size paper, so the whole stack had been shifted back just a smidge so that the roller that picks up the paper was unable to grab the edge of the top sheet. I moved the slider back to 81/2 x 11 size paper and made sure the stack was all the way to the front of the tray and PRESTO!!! Geez, I felt kind of dumb, but maybe other people's size plate has been jostled out of position as well. Hope this helps SOMEONE!
Posted on Mar 03, 2008
    Genius:
  • 1,601 Answers
Did you get this working?
Posted on Mar 02, 2008
How do I fix the "phantom" paper jam on HP P3015?
Just had one today that would throw a open rear door error. Turned out that the flag in the back of the fuser was dislodged.
Sep 29, 2014 | HP Office Equipment & Supplies
Phaser 860 Phantom Jam Won't print until jam in
There is a solenoid on the transfix assembly that has a tendency to "stick" in the open position, causing paper jams at the exit. The Solenoid is located on the right side of the machine, at the top area in the middle. You can test it with your fingers to see if it sticks in the up position. If it is, simply clean the sticky residue off both metal surfaces with alcohol and it should return to normal operations.
Aug 26, 2013 | Xerox Phaser Office Equipment & Supplies
Hp laserjet m3035 mfp does not take up the paper squeaks and reports paper jam - no papaer is jammed
The most common cause of this type of Phantom paper jam is worn pickup rollers and separation pads in the paper trays. When these rollers get worn the gripping surface can not grab the paper correctly so no paper is fed into the printer and the printer gives the paper jam error. The rollers are very easy to replace, it takes about 20 minutes total. Here is a link to more information about the roller maint kit:
www.ccl-la.com/catalog/product_info.php?products_id=172
Mar 18, 2013 | HP LaserJet M3035 MFP Printer
How do I clear a "phantom" paper jam?
Are you a techy person? The reason I ask is sometimes these phantom jams are caused
by a sensor that is not seated properly and may require disassembly. Anyhow, if you have tried
to blow can air and tried reseated the paper then maybe its the sensor. Usually a disassembly
is required to reseat the sensor assembly is required. Get your hands on a schematics for
your model before attempting.
Jan 23, 2011 | HP PSC 1210 All-In-One InkJet Printer
Can I get any technical info on the sensors related to paper jams?
what info are you looking for? these usually jam in the fuser, or the jams happen when the feed sections are not working and the paper never makes it out of the tray, then it will seem to be "phantom jams" but the jam sensors rarely go bad.
Oct 04, 2010 | Toshiba e-Studio 202L Copier
Rear Paper Jam - No paper present.
Look for a small piece of paper that may be stuck in the switch indicating a paper jam.
Jun 01, 2009 | Canon PIXMA MP610 InkJet Printer
Phantom Paper jam
Pull out the paper tray, shut off the printer.
check all paper path.
turn on the printer
inser the paper tray.
Aug 23, 2008 | Brother MFC 8500 All-In-One Laser Printer
Paper jam lexmark x3470
#2 works for an x3470, but jostling the small cylinder that accepts the paper (nudge it gently toward the printer) seems to be what pulls back the microswitch...
Oct 16, 2007 | Lexmark X3470 All-In-One InkJet Printer
Phantom paper jam
Same problem here. I'm googling around looking for ideas.
Sep 07, 2007 | Brother MFC-8640D Printer
HP PSC 1315 All-In-One InkJet Printer Logo
341 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
