Question about Hotpoint First Edition WMA12 Front Load Washer
How to fit a new double valve on hotpoint first edition washer
I have got down to the last screw holding the old valve in place but cant remove it because of the housing .The new valve does not appear to be attached by screws Help!
    Genius:
  • Hotpoint Master
  • 1,474 Answers
Some valves are held by screws some twist on ,if the valve its self is okay you can Gently remove the Coil and fit the new one as its normally the coil that goes. It pull off with a srewdriver Gently otherwise valve may suffer damage...
Posted on Feb 08, 2010
H20 symbol on display of hotpoint wf 860 washing machine
Pull off your washer mains cord from the wall. Turn off your wall faucet,, the valve on wall which allows water into the washer. (h2o means your washer is not receiving the most importing thing - water). Disconnect the pipes of the water from the wall. Check by opening the wall valve to see if the water flow is gud. Next fit back carefully. Then unscrew the other end of the hose/hoses at the entry point of your washer - remove the fine filters and clean out with an old tooth brush; clean inside the opening of inlet valve too carefully, check. Now re-fit the filters carefully and screw back the hoses. You are done now. It is advisable to close the wall valve when your washing is done, takes pressure off the machine valve.
Pl click if helped.....
Apr 05, 2013 | Hotpoint Ultima WF860 Front Load Washer
Do you have to take the motor out to fit new brushes on a hotpoint wma64
Remove lower rear panel of washer.
Remove drum drive belt.
Unplug lead to motor, remove earth wire.to motor.
Locate and undo 2 screws securing motor to drum chassis.
Lever motor backwards to remove from mountings, keeping hold of the motor so it does not drop.
Remove old carbons at opp end to motor pulley.
Mar 13, 2010 | Hotpoint WMA64 Front Load Washer
How do we fit a new hinge to a Hotpoint WM64P washing machine
Remove the wire clamp that secures the door seal to the front of the washer.
Pull the seal of the front. and double it back inside the washer.
Undo the 2 screws that secure the door hinge to the front of the cabinet, keeping hold of the hinge support plate behind the cabinet front.
Remove the door, and undo all the scews that hold the 2 halves of the door together, then prise apart the the 2 halves..
Replace the door hinge.
Reassemble in reverse order.
Please rate my solution.
Thanks.
Nov 24, 2009 | Hotpoint Washing Machines
How do I change the door boot seal on a Hotpoint Aquarius WMA31N?
Ok - I will answer my own problem seeing as though I have now fitted it!
1. remove door (2 screws)
2. There is a tensioned wire loop holding the front part of the boot seal in position. - prize off the plastic cap at the 11 o'clock position, all will become clear and you will be able to remove the wire loop.
3. Remove top of washing machine (2 allen screws behind caps at the front.
4. Remove soap dispenser draw and any screws holding the front control panel and top of the door.
5. Remove bottom front plinth (just pull it off) underneath are a couple of screws holding the front panel part of the machine, remove these.
6. Remove front of machine giving you access to the steel band which locks the other end of the boot seal in position. Slacken this band right back using a nut-spinner screwdriver. Pull off the old boot and clean the lip ready for fitting of the new boot.
7. Fit new boot seal using a squirt of washing up liquid as lubricant if needed (mine didn't) to reseat the seal.
8. Refit and tension steel band.
9. Re-assemble front panel, ease boot back into front lip position then refit wire loop using a suitable pair of pliers/molegrips to crimp the retaining plastic cap back in situ.
Oct 05, 2009 | Hotpoint WMA31 Front Load Washer
Drive belt came off spindle on Hotpoint First Edition Washing Machine.Have tried to replace but back of machine does not remove, just a small access hole. How can I refit a new belt please??? John Bennett...
Remove rear panel, remove top cover,.tilt washer forwards, get someone to hold it for you, and fit belt round motor pulley first, then start feeding it round drum pulley, easing drum round at same time, it will be tight, so watch you fingers,
Thanks.
Sep 13, 2009 | Hotpoint First Edition FEW12 Front Load...
Cold tap doesnt work
Is it a single handle or double handle faucet?
If it is a single:    1.  Remove handle via setscrew the side of the handle          (possibly under a decorative cap with the company name)    2.  Unscrew the packing nut holding the valve cartridge in    3.  Remove cartridge and access washers
For double handle    1.  Remove decorative cap on top of handle with a think screw driver.    2.  Remove handle and packing nut holding the valve stem in place    3.  Remove valve stem and body to access washers and o-rings.
Remember to turn water off at the source prior to doing any work. Replacement is just reverse of removal and don't forget to use a washer grease on all washers/o-rings when reassembling.
Apr 14, 2009 | Swan Home
Does water continusly pour on clothes when it dries them ?
The inlet valve is where the water comes into your machine, top behind. The cold water valve is probably stuck open. It should open only when there is voltage across the valve. Check if wires are fitted tight. It could just be clogged inside. If you can remove it, you might be able to take it apart and clean it. Just make a note of how parts fit together as you are taking it apart. Clean all parts with old toothbrush and reassemble. Before you reinstall, connect it to a garden hose outside. No water should come out when you turn the hose on. If it still fails, just buy a new valve.
  1. Unplug washer, turn off water supply and remove hoses from the back of the washer.
  2. Remove the top panel by removing the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, then lift off.
  3. The water inlet valve will be located at the left rear of the washer (as viewed from the front).
  4. Remove the dispenser hose, electrical connections and mounting screws and the valve is removed.
  5. Install new valve by following these steps in reverse order. NOTE: When reinstalling top panel, make sure you lay panel on top of washer, leaving a couple of inches of room from the front panel. Then, slide panel towards you (front of washer) so that the top panel slides into the mounting clips.
Try these sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Apr 14, 2009 | Frigidaire Washing Machines
How to remove hot water inlet valve
In ost cases there is a scerw on the outide of the machine which holds the bracket that holds the valve. Go ahead and get the valve and look over the new one, it will tell you volumes about how to install it. Like where that screw would be, Good Luck!
Mar 12, 2009 | Hotpoint First Edition WMA20 Front Load...
How do i fit the door seal
hi the door seal is held in place by two large clips wjth screw tightening best access is to remove the top row screws on rear panel these also hold the top panel then lift top panel at rear and pull top backwards and clear of front facia then lift top off ok ? now you have access to the door seals clips which secure seal to front panel and the outer drum loosen screws fully this releases clips enough to gently remove seal clean surfaces of seal to drum and front panel then fit new seal as previouse one resecure clips then re assemble covers hope this helps and clear enough ?
Mar 09, 2009 | Hotpoint BWM12 Front Load Washer
Fitting new brushes on a hotpoint washing machine
Remove lower rear panel.remove drive belt, undo screws that secure motor. unplug motor lead, noting which way it is fitted.,lever motor back and remove, replace brushes and refit motor and belt.
Mar 30, 2008 | Hotpoint First Edition FEW10P Front Load...
Hotpoint First Edition WMA12 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
