Question about Dualit 25375 2-Slice Toaster
The lever will not work. It is as if a spring or catch to hold the lever down has broken. Fuse is fine, already checked.
How do i install a replacement spring in a tool catch
it isn't obvious from the pics but if I had to guess u need to get both the catch and the spring (if u lost it) b/c the reason the spring came out is that the catch is already broken.
Once u get it, it simply pops into place.
look at this page - may help
http://www.vacpartswarehouse.com/Dyson-Silver-Tool-Catch-DC25-DC33-DC35-DC44-DC56-p/dy-911523-03.htm
Sep 21, 2014 | Dyson DC35 Handheld Vacuum
Auger clutch lever disengages even though drive clutch lever is squeezed
On mine (Honda HS55) it turned out to be gummy old grease on the shaft and the lever that are supposed to lock the auger lever down. The spring couldn't overpower the sticky old grease. If nudged or given enough time, it would slowly turn and lock, but not instantaneously, as it should.
10 mm wrench to remove the nut (bottom left) and bolt (under handle) holding on the metal cover.
Once cover was off I could see the locking lever, spring, and the shaft that had the gummy grease on it.
The third photo shows the locking lever as it should be engaged. I had to push it to engage it, due to the spring not being strong enough for the gummy grease on the shaft.
There are flat sides on the shaft, behind the threads for the nut that has already been removed. Use a wrench on those to turn the shaft out. Disassemble. Clean. Oil. Reassemble. Works great now.
Another possibility is that your locking lever or spring are broken.
Dec 17, 2013 | Honda Snowblower Cover Silver Hs928,...
Toastmaster toaster only works if i hold lever down
There is a catch on the lever that is loose or broken. You may have to dissemble it to find out. If broken, just order the part. It is pretty easy to put on.
Jan 20, 2013 | Kitchen Appliances - Others
Pfaff 6091 Presser foot won't go all the way down
HAVE THE 6091 MACHINE AND THE FOOT IS NOT FROZEN BUT WON'T GO DOWN. OILING THE MACHINE DID NOT HELP AT ALL. HAD A REPAIR MAN COME TO THE HOME AND CLEAN THE MACHINE. STILL THE FOOT WILL NOT GO DOWN.
Nov 21, 2011 | Sewing Machines
My boyfiend slammed the door shut and it has not worked since then
The door latch (on the door) or the door catch (on the oven) have most likely broken. The oven will not operate if the door is open or if it is not correctly closed.
Check the door latch. On most microwave ovens there will be one or two prongs. Make sure that they're not broken and that if neither of them is loose. Often one or both are designed to move upwards against spring pressure so if they move loosely with no spring pressure then the door must be dismantled to find out why. Often it's a broken spring anchor and sometimes it can be repaired, but the official fix is to replace the entire door assembly.
If the latch seems fine then it's almost certainly the door catch unit which must be repaired or replaced. They're not officially repairable, but sometimes all that has actually broken is a cheap and easily obtainable microswitch. If the catch has actually broken then there is no point in gluing it together as it won't hold. If the door catch assembly looks fine and the microswitch appears to be operable then use a continuity meter on the switch to confirm correct electrical function as the switch is pressed and released.
If that fails, then look for any fuses on the circuit board, the filament inside can break if they're subjected to too much physical impact. Test and replace any failed ones, but it's vital to use the correct type, the casing will indicate whether they're slow blow or fast blow fuses. These properties are independent of the voltage and current rating and simply regulate how quickly or slowly a fuse will fail if the limits are exceeeded. using a slow blow in the place of a fast blow is dangerous, but using a fast blow or a regular fuse where a slow blow goes will just mean that the fuse blows more often or even immediately in normal use, often when the door is opened.
If you need any spare parts then you'll have to find suppliers yourself, sorry. I don't know which country/state you're in and I'm based in London, England, where Emerson is not a known brand.
I hope that my answer helps you to either repair your oven or to decide whether to replace it. Please take a moment to rate my reply.
Sep 23, 2010 | Emerson Black Microwave Oven
Kitchenaid stand mixer will not stay in the off position.
There is a spring, item #4, which hooks on to the bottom of the control plate, item # 25, and pulls it back when you move the lever to off. Remove the rear cover and see if that spring is still connected to the control plate and to the lever arm, Item # 3. Here is the diagram:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212369.pdf
Mar 31, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Indesit IDL500 door wont close properly, catch appears to be the problem?
A lever inside the door lock is attached to a spring. If the lever or spring is broken, it wont lock.
Jul 21, 2009 | Dishwashers
Belling SGE12X broken door handlw
it's not an easy job to replace a door handle, but to release it for the door to open, turn off the machine at the outlet and unplug. Take the top of the machine off and slide your hand down to the door catch. Depending which type of catch it is, you should either be able to push down a small lever on top or push up a small lever on the bottom or the door catch.
I hope this helps
Oct 25, 2008 | Belling SGE12X Front Load Washer / Dryer
Toaster lever
I have sunbeam model AGW toaster level is not staying down and no power. the spring work, i want to know what part hold it down. please help or there any repair company i can take it (s. california) thanks
Dec 17, 2007 | Kenmore KTES4 4-Slice Toaster
Lever on taoster will not stay down
Black & Decker T4050 OptiToast 4-Slice and it will not stay down and heat either. However you can hold it down and then it will heat. I apparently has an electromagnet that is supposed to hold it down and it's not working. Any Suggestions?
Oct 30, 2007 | Cuisinart CPT-140 Cool Touch 4-Slice...
Dualit 25375 2-Slice Toaster Logo
71 people viewed this question
Top Dualit Kitchen Appliances - Others Experts
Herve Boissonnault
Herve Boissonnault
Mack Baxter
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Dualit Kitchen Appliances - Other Expert? Answer questions, earn points and help others
