Question about E-Machines T2862 PC Desktop
New motherboard for the T2862
I have a buddy with the "no power" problem. He tried a new power supply, but still gets nothing, no lights, no fan etc. So, he purchased a new motherboard and memory. I don't know the model # for the new mobo, but I believe the original one was called "Seabreeze". Here's my question: Once we install the new motherboard and memory, how do we get it to boot off the original hard drive? Do we just go into the bios on power up and change some settings? Or do we have to reload XP? Any help would be appreciated.
  • stanley08 Feb 25, 2008
    O.K., I installed a new power supply, (300 watts), a new mobo, (non-emachines), and new memory. The pc powers up fine now, and sees all of the devices - 2) drives on IDE bus 0, and 2) drives on IDE bus 1, (a CDROM and a DVD). However, when it tries to boot, it shows the Windows screen briefly, (maybe a second at the most), and then tries to boot the other devices and fails. I don't know what type of recovery cd's were provided with the system, but my friend could find none of them. So, I told him he would either have to borrow an XP cd from someone, or buy a new one and reload it. Does that make sense? As I said, he has 2 hard drives on Bus 0, so I assume that the original mobo was set up to boot drive 0 (the master). If that is the case, will windows give us the option to try to "repair" the boot image on drive 0?
  • DrDirty75 Jun 15, 2008
    Im having the same problem with my T2862 emachines desktop. I replaced the power supply but still the computer wont boot. How do I determine if I have to replace the mother board. And how much will a new one cost me if it needs replaced? Thanks
  • 28 Answers
Just plug the old hard drive into the new motherboard. 99% of the time the new mother board will automatically detect the hard drive that is connected. So there really isn't anything you have to do accept plug it in.
Posted on Feb 22, 2008
    Genius:
  • 1,019 Answers
you probably won,t get it to boot off the original hard-drive. As that will be mated up to the old motherboard.
i,d suggest putting a new hard-drive in, then transfering any required data to the new drive, you should be able to transfer most of your files accross, but will have conflicts trying to copy some windows files. as they,ll be in use by the system.
Mike @ Compurepair.
  • Mike Waldron Feb 25, 2008
    i,d suggest getting rid of 1 of the hard-drives On Bus0.
    That will be causing your conflicts.
    set 1 hard drive, to slave lower part of the 2 part IDE ribbon Cable.
    Set 1 DVD rom to the upper part of the IDE Ribbon Cable.
    Ensure that it is set As A Master Drive.
    Remove everything from The other Bus, you can install those, once you,ve setup the main system.
    if by chance the 2 hard drives on the same Bus, are both slave Or Master.
    Thats where your Problem Lies.
    Mike @ compurepair.
My computer won't start. Power supply (ttgi 450ss) has a blinking green light and the power supply fan starts when plugged in. Motherboard (asus m2npv-vm) has a green light illuminated between the pci...
See if you plugged in the 4 pin power connector on the motherboard besides the main power connection on the power supply (usually black colored and its a plastic 4 pin connector)
Try another power supply if all else fails. If new power supply does not work with this unit then its a motherboard which is blown and motherboard needs replacing.
Hope this helps
Mar 16, 2010 | TTGI SUPER FLOWER 450W quad fan switching...
Blue light on power button on, but Monitor shows "no signal"
If you tried replacing your power supply but still cannot put your PC to turn on, you should try checking your memory or your RAM. try reconnecting it, clean the lids of the RAM using an eraser, make sure you erase the lids on one direction and try reconnecting it again.
1. After reconnecting the RAM, try to unplug any hard disks connected to your motherboard, remove external PCI cards or if you have external video card remove it and use the built-in video card.
2. Make sure that the connectors from your power supply going through your motherboard is not loose, dont overtighten as it may possible that you can damage your motherboard from pushing through it.
3. Now turn on your computer, if it works, then your RAM must have been faulty or you have loose connections. Try to plug the hard disks and turn on again your computer, if you tried plugging in every devices and if theres an instance that your computer didnt turn on after you have plugged in that device, then the problem will be on that device that you have just plugged, and that made the computer from not responding.
It really helps alot if you have a spare device because you can test if, the one youre using works well by replacing it with a device that in no doubt that works well.
These are just basics on troubleshooting, and i hope it will helped you troubleshoot your PC or more computers in the future.
Any clarifications or future problems, i would be happy to help you. =)
Jan 02, 2010 | E-Machines T2862 PC Desktop
Presario f700 no fan/lights = nothing at all. The charger works
try to jump green and any black wire from the power supply...if the fan dont work..power supply is damage..need to change..
Jul 14, 2009 | HP Compaq Presario F500 F700 and G6000...
Cannot get new Motherboard to boot up in Normal Mode
what u may have done is wwhen u were installing the new board, gave a static shock to the system...that will cause only the fans to come on and nothing more...this is a bad problem bc u cannot fix it...if u figure out something else is wrong, and it gets fixed, let me know
Jun 20, 2009 | Gateway Computers & Internet
Emachine will not power up
By nothing else, from a technical standpoint this would mean literally nothing, the CPU fan, power supply fan, aux fan, disk drive not spinning up, etc. My experience with EMachines is their motherboards aint the best, have been known to take out hard drives and other peripherals to the mother board. If you are technically inclined the first thing to do is to bare out the system, Power Supply attached to the Mother Board w/ Cpu Monitor and Keyboard no Hard Drive and no Non esential boards installed, very carefully remove the memory and start it up all should be fine except it should give you a long beep from the PC Speaker indicating the Mother Board is aware there is no memory installed if it will not do this most basic of tests this is not good. If it does give you a health beep continue to install one item at a time, first the memory, the display should, if working, tell you there is a boot failure, of course, the hard drive is not connected, do so and keep on testing. Without knowing what type of mother board you have, most likely an AT with integrated peripherials the process to determine exactly what the problem is would take hands on trouble shooting. If you dont get the beep indicating the mother board cant determine if memory is installed and truley nothing else is on it is more likely the mother board. There are several good ones online that will fit your case if you want to go this route. Or is it time to upgrade ?
Jun 04, 2009 | E-Machines eMachines Desktop PC
Power supply not working?
To see if power supply works
unplug the psu from the motherboard and drives
then plug the power cord into psu and wall
the fan should come on letting you know that it works.
you can also get a multimeter and check each individual connector on the 20/24 pin connector to motherboard.
check the psu docs for the correct voltages to each pin
If you smelled smoke then chances are that something may have gotten toasted.
remove all expansion cards and try to turn on computer if nothing happens then the motherboard may have gotten toasted.
Check the motherboard and expansion cards along with memory for shorts and burn spots.
A+ Technician
Apr 02, 2009 | HP HEC HP485D 485W ORION HP485D ATX 12V...
Can not find heat sink switches on motherboard emachine t2862
Heat sink switches? I have to assume that you're talking about a dead mother board but the fans and the LED on the mother board are OK? This is a classic eMachines problem. Their power supplies glitch and take out the mother board sometimes the power supply goes bad too.
Mar 24, 2009 | E-Machines eMachines Desktop PC
No boot, New PS, Green light on MB lights, No Fans running
Bottom line: Either your power supply or (hopefully not) the mother board has gone bad.
Replace power supply (remove old one), take to local independent computer shop, ask them for new unit. Should be around $50.00. - no more. After reinstall, if still no fans, boot, etc. Replace motherboard or buy a new machine. MB's installed probably will run you around $250.00-ish.
Good luck.
gurutim
Mar 21, 2009 | E-Machines eMachines Desktop PC
Emachine T2862
have you try to test your power supply if it actually works? try 2 remove it from your pc plug the power chord on it and short the GREEN and BLACK wires using a pin or any conductor u can use. see if it turn on lights and fan turns on when you do that.
Feb 01, 2009 | E-Machines eMachines Desktop PC
E-machine will not power up even after replacing the power supply
If power does not come to hard disk, cd/dvd etc. then replace the mother board. And if you can put on the cpu and there is no display, then replace the RAM module.
Dec 17, 2008 | E-Machines eMachines Desktop PC
E-Machines T2862 PC Desktop Logo
543 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
