Trying to find internal 12v to high v PU board E134893 for Alba TV ALCD 15TV2 J Gray
2 Suggested Answers
  • 69 Answers
SOURCE: Picture but no sound on Alba ALCD 1 5TV
on the remote you should have a button wth system if not go into the menu and look for system and change to auto or change to PAL I
SAVE AND EXIT
Posted on Jun 24, 2013
Testimonial: "Sadly, there's no system button on the remote control and if you go into system via the menu, it doesn;t offer you any option to change is from BG... Thanks anyway..."
Alba AELKDVD2288 screen pixelates like its poor reception but all other tvs work in the house and even plugged it into a different jack in the house where another tv works fine. any suggestions please?
Your Alba TV may have lower input sensitivity than the others but there also could be a poor connection internally such as a cold solder joint or a cracked connection.
Jan 29, 2015 | Alba Televison & Video
I have aLCD HDTV-LC-332D4OU TV
Hi-
Try taking cables from the back of television and turn it off and unplug it for an hour and try turning it back on. is there any lights blinking or flashing in the control panel? try resetting the settings to default as well. Keep us posted. Thanks for using fixya!
Aug 17, 2008 | Sharp Televison & Video
My Alba TV won't turn on and the light at the bottom is just flashing?
I the LED flashers when switched on it means there is an internal fault and it will be need of repair Do not take the back of unless you know what you are doing as the are very high voltages in side. If you are asking this question it would seem you do not know what the LED flashing means?
Oct 05, 2014 | Alba Televison & Video
Alba 32inch hd lcd tv
The internal power supply may have failed.
Nov 14, 2013 | Televison & Video
SAVE AND EXIT
Jun 24, 2013 | Televison & Video
Alba tv blowing the 12v dc adaptor
Check the adapter itself bow out, when it is plugged to Wall AC socket. Do not load it to TV, and check this. If it blows up, the fault is with the adapter itself. If it don't, the fault must be within the TV circuit.
Jun 18, 2013 | Televison & Video
Hi. I have an ALBA LCD32880HDF television which I purchased in August 2009 so just outside warrenty. I have been on holiday for a week and had switched the television off at the wall and returned home...
hi all the black screen solution for me was this (this is assuming you have alba brand tvs and have the black screen BUT can still hear the sound) i after much fekkin around with it eventually found the solution in it (its the bloody backlight brightness in the settings you need to turn it from high TO LOW) ....... now this can be a bit tricky because usually when you have the black screen problem if u unplug the tv for a few hours and plug it back in you only get or should get probably like 30-1min of picture time before the picture goes black so u have to be reallllly fast with the menu button to get into settings before the picture dies (i learned the sequence for my alba lcd32880hdf) it was the following (for this part use the remotes arrows the one with the ok button usually in the centre of them) turn the tv on then click menu then press the up key 2 times then press ok then use the right arrow/button twice (although u cant see what ur doing ur navigating the menu hehe) then press the down arrow/button seven times before finally pressing the left arrow/button (once) <-- (now this bit may need to be done twice if you can remember setting ur backlight to max use it twice it will put it on minimum if in doubt only press it the once remember to totally power the tv off before repeating the steps to reset menus default posistions) remember thats the solution i found for my tv stands to reason (since i did infact buy another tv same brand different model which got the same problem) that this could be a solution for all alba tv users try it worked for me 2 times if ur not sure of the menu look up you tv models menu navigation online to find out the buttons you press gl hopefully it works for you too
Oct 24, 2010 | Televison & Video
Remote code for commtel control freak remote.
I can help you with your URC-3021 Universal Remote Control issues.
I do not see a listing for Alba TVs in the Urc-3021 Code List.
But don't give up; many manufacturer's re-use other's control codes.
Therefore, I recommend using the One For All URC-3021 Code Search, feature to find the compatible codes to control your device.
I hope that helps.
_______________________________________________
Reassign URC-3021 Device Key
Urc-3021 Code List Download
Apr 17, 2010 | One For All URC-3021 Remote Control
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
Electro Med Services...
