Question about Canon imagePROGRAF® iPF8100 InkJet Printer
Canon iPF8100 Error message E03130031-2F1F - Canon imagePROGRAF® iPF8100 InkJet Printer
    Sniper:
  • 79 Answers
Check under the purge unit there is a gear that is out of his position.
you have to track it down by moving with your hand the right wheel.
Posted on Aug 11, 2010
  • 4 Answers
Hardware error 03130031-2f1f in IPF8300 printer we replace the pumping system of the printer
Posted on Apr 21, 2013
  • Soccer Photos Aug 14, 2013
    how much was it to fix (parts and labor).
3 Suggested Answers
  • 79 Answers
SOURCE: canon iPF8100
that indicates poor connection of the hard disk connection.
you have to remove and put back the disk and if the problem remains then you have to buy one from your local market and put it.
That might solve your problem
Posted on Dec 29, 2009
SOURCE: canon iPF8100 Error message E602 401b
Our Canon iPF810 recently had the error message "E602-401B" while it was still under warranty. At that time the hard drive was replaced, but it didn't solve the problem so the original hard drive was put back in and the firmware was updated and the machine worked fine for about 9 months.
We got the same message again and the machine was not under warranty so repair would be quite expensive ($1000.00 flat rate fee). After making calls to repair places, one place gave me some valuable information.
They suggested that if I could get into "Service Mode", select "System Setup" and then "Erase HDD". They said the hard drive probably needed to be defragmented. Amazingly enough, it worked! The hardest part was figuring out how to get into "Service Mode".
With the machine switchoff OFF, hold down the "sheet or roll feed button" and the "information button". Keep these pressed and switch the machine on, keeping the buttons pressed until you see an "S" in the top right-hand corner of the display, then let go of the buttons. You should now be in "Service Mode". Then go to "System Setup" and then "Erase HDD". Your machine should work after following these procedures.
It seems like the plotter stores every plot in its memory. After a period of time, the plotter's memory gets filled up and the "E602-401B" error message occurs. To prevent this from happening, periodically erase all the old plots. The procedure for doing this is as follows:
On the plotter "Main Menu" choose: "Job Management", "Stored Job", "Common Box", "Job List". Then delete each drawing/plot.
Posted on Jun 10, 2011
Print head error
i have downGrade firmwares for IPF8100,IPF9100,IPF8000, IPF605,IPF700 UNLOCKS PRINT HEADS WHEN THE PLOTTER ASK YOU TO CHANGE THE HEADS. mail- a.louloudis1@gmail.com for questions and support
Jul 03, 2015 | Canon imagePROGRAF iPF8000 Printer
Canon IPF8100 error code 03130031-2F3A can you please help vicki@westcountry.com.au Thanks
Same error in my ipf755. Canon suggests replacement of carriage (700 eur)...
Feb 16, 2011 | Canon imagePROGRAF iPF8000 Printer
I have a problem with canon the code is like 03130031-2f26
the 031300312f26 error alot upon warm up. We have found to fix this problem the best option is to push the print head back to its home position (far right) and unplugging the printer for 1 min or so (just to make sure its memory has lost all awarness we messed with it). Then plug it in and it goes fine... The problem we used to have is the same many of you are complaining about it drains ink like a vampire whenever you have to restart it. To cope with this we have upgraded our firmware which has drastically decreased the amount of ink we waist due to less cleaning and agitating functions. Hope this helps out someone it took us a while to get back any love for the canon but we are comming round again
or
replaced the ribbon cables from the controller to the carriage unit. Also had 03130031-2f26 intermitently. This is not a fun job but the problem has not returned
Feb 14, 2011 | Canon imagePROGRAF® iPF8100 InkJet Printer
How to start in service mode for Canon IPF8100?
We have a Canon iPF810 plotter and to enter SERVICE MODE the machine has to be switched OFF. While the machine is off, hold down the sheet or roll feed button and the information button. Keep these pressed and switch the machine on, keeping the buttons pressed until you see an S in the top right-hand corner of the display, then let go of the buttons. You should now be in SERVICE MODE.
Apr 13, 2010 | Canon imagePROGRAF® iPF8100 InkJet Printer
Moving a canon ipf8100
normally you have to perform move printer level 2 to avoid damage to the printer. But, if you move the printer without taking any dangerous angle then you don;t have to choose level 2, level 1 or no move is OK
Mar 08, 2010 | Canon imagePROGRAF® iPF8100 InkJet Printer
Canon iPF8100 Error message E602 401b
Nov 27, 2009 | Canon imagePROGRAF® iPF8100 InkJet Printer
Canon iPF8100 Error message E602-401b
(iPF9000 Only) Confirm the connection of the HDD, and if it is the HDD failure, replace the HDD
Aug 08, 2009 | Office Equipment & Supplies
Canon iPF8100
Aug 02, 2009 | Canon imagePROGRAF® iPF8100 InkJet Printer
Canon ipf8000s can not cat the paper also gives hardware error 03800500-2f2f
Check your cutting wheel is in properly, have had a similar problem on a IPF8100, sometimes the wheel/cartridge just pops out
Jul 24, 2008 | Canon Office Equipment & Supplies
Canon imagePROGRAF® iPF8100 InkJet Printer Logo
2,632 people viewed this question
old marine
old marine
