Question about Clarity C4210 Amplified Digital Crodless Caller ID Phone
Voice mail flashing blue light
Flash for voice mail doesn't work
Forgrt it! Our problem is the flashing blue light works and keeps us awake making it necessary to hide the phones in drawers! We can't turn off the flashing blue lights and can't find an answer to this problem.
Posted on Apr 18, 2008
  • 3 Answers
SOURCE: New Voice Mail flashing light
What worked for me was to call my phone from another phone and leave myself a voicemail. I then called into my voicemail, listened to and deleted the message. This reset my handsets so the New Voicemail indicator is no longer flashing.
Hope that helps!
Posted on Jun 05, 2008
  • 3 Answers
What worked for me was to call my phone from another phone and leave myself a voicemail. I then went in and retrieved and deleted that voicemail. Once I hung up from my voicemail service my handsets reset about 10 seconds later.
I hope this helps!
SOURCE: voice mail indicator light is always on
I have 6 of these phones. No problem for a year or so, then one phone got the message light stuck on. Tried some online suggestions without success. Powering down etc. failed to fix it so I stuck a piece of tape over the led.
A couple of weeks ago line 2 failed (externally) and ATT sent a tech out who repaired it and also cleaned up the line. When the line came back, all 6 phones had the message light stuck on!
Talked with the tech here and with the ATT support and nothing worked. Eventually the tech here left as it was not a line fault - but he said he would leave the problem open.
That evening a young ATT guy called. He tried a number of different settings and changes - he was really determined! He called Kentucky and Minnesota and part of the advice was "give up and don't call the customer back"!
Finally he found a configuration option in the central office switch (exchange) for the line called CWMI (Call Waiting Message Indicator). Apparently this option was originally active but was changed when the local trunk was upgraded to fibre over the last year or so.
Once he enabled this option (we have call waiting and caller ID on call waiting on this line), the message lights on all the phones turned off and have worked normally since (10 days), including the one that was "broken" for over a year!
I really credit the tech with persistance on the issue.
Hope this helps someone else out there.
Regards, Hugh
Posted on Aug 25, 2008
SOURCE: voice mail light
You have to press the delete and up button at the same time.
Posted on Nov 02, 2008
SOURCE: voice mail - red light does not work
Contact your phone company to make sure the stutter tone and/or feature for Voice mail notification is on. I too had the same problem many years ago with AT&T (Then SBC) to correct this.
Posted on Jul 14, 2009
Kx-t7433 how to turn on fwd/dnd does not work
What happens when you dial 165 on the intercom? If you get voice mail, then try dialing 7104 165 # on the intercom. That sets CF-No Ans to voice mail for your set and the FWD/DND button should light solid (or not, it's a program option) or flash. If you dial 7101 it should turn on Do Not Disturb (7100 cancels). In DND, the FWD light should flash.
Once you have set these two conditions up, the FWD/DND button has 3 states, FWD, DND, and OFF.
Carl
Jul 10, 2012 | Panasonic KX-T7633 Corded Phone
I receive a call from outside, press flash and dial the extension but it the person to whom I direct the call can not get the call and if I try to return to the call, it is disconnected.
The FLASH button is for outside calls. Try the TRANSFER button. If the inside party doesn't answer, press the outside line button that's flashing green. If you have a Panasonic brand voice mail, you can also transfer the call to voice mail with another button.
Carl
Apr 13, 2011 | Panasonic KX-T7730 Corded Phone
How do i stop the blinking blue light on my ge 6.0 phone?
hi... first of all clear all voice mails from the provider (Comcast digital voice service allows you to do it via web),  and ur dial tone will returne to normal sound and ur light indicator will stop flashing....
thank u rate me
Feb 09, 2009 | Uniden Cordless Phone
CD445
i still have flashing red light and the message now reads phillips
new message
how do i get this message
what number do i use to set up voice mail since i do not subscribe to voice mail? When i activate voice mail i get the operator
i still have faith that we can solve this problem
peace
robert barnes
Jul 04, 2008 | Philips CD4451S/05 Phone
Panasonic tvs-100 voice mail beeping and flashes red power light four times
I'm having an issue with the same unit. But the blinking light is NOT on my phone it's the power light to the actual unit in my server room. It will flash 4 times and then stop. Flash 4 times again... I have looked through the manual to see what 4x power light means and I have found nothing!
Jun 21, 2008 | Lands Phones
press "mute" key to access menu, press the up or down arrow key labeled "caller ID- volume" until you get to "handset setup", press the "mute" key again, press the down or up arrow until you have "defaultsetting" selected, press "mute" key, press "1", then press "mute" once more. At this point your handset will reset clearing the indicator for all the handsets. I've had to do this twice on my phones and it worked every time.
May 10, 2008 | Uniden Cordless Phone
New voice mail
put a piece of electrical tape over the light. I cant turn my blue light off either.
Apr 13, 2008 | GE 28111EE2 Cordless Phone
I hope this helps!
Apr 05, 2008 | Uniden Cordless Phone
Displays new voice mail and VMWI constantly blinking when no voice mail
Subscriber is T-Mobile@Home. First, cleared all messages from T-Mobile voicemail.
Now to fix your GE phone:
Push the program key. Select Handset Setup Push the program key Select Default Settings Push the program key Select 1 Yes. Push the program key
Hope this helps.
Mar 06, 2008 | Uniden Cordless Phone
Voice mail light
Apr 28, 2007 | BellSouth 8867BK Corded Phone
Clarity C4210 Amplified Digital Crodless Caller ID Phone Logo
350 people viewed this question
Top Clarity Lands Phones Experts
Andrew Taylor
Andrew Taylor
Are you a Clarity Lands Phone Expert? Answer questions, earn points and help others
