Question about Electronics - Others
My ex1000 runs only with the choke on -put in fresh fuel and cleaned the carby -please help
    Champion:
  • 243 Answers
Make sure there comes enough fuel out of the tank. check fueltap and filters in tank or in tap if thats all good clean carb again with special attention for little fuel restrictors. blow out with airgun. good luck.
Posted on Feb 12, 2010
How do I tune a carby for a Mitsubishi PM 1500 L Scorpion generator
pull the carby and clean it out
the indication is that there is a blockage in the main jet or not enough fuel flow into the carby
check filter in the tank above the fuel tap, check the fuel tap for flow
there is no tune up points as it is a basic carby to run the engine at set rpms
Jul 05, 2016 | Electrical Supplies
I have put a reconditioned carby on my eh holden it wont start cold with out pourig a small amount of fuel down the throughtof the carby onece running it starts each time perfect sit over night no go
fix the choke to work properly for starters next if you still have the original cast iron manifold then get the butterfly in the exhaust to work as well. It heats up the inlet manifold which helps to vaporise the fuel
Dec 31, 2013 | 1964 Holden EH
Troy built TB2040xp cranks but won't consistently run. I can barely run it pretty much on full choke. I've put new carb on it, cleaning muffler, etc. It's only 2 years old, my fuel lines everything is...
it is a fuel related issue in that the carby is not getting enough fuel
check fuel tap is flowing fuel, needle and seat /float level is correct , filters in tank and at carby are not blocked
check main jet for blockage /water
this is all indicated by needing the choke on for it to run
Apr 23, 2017 | Garden
My 5.5 honda engine on my lawnmower will start but wont stay running already cleaned the carb out didnt help there is no restrictions in the fuel lines im lost please help
it sounds like a fuel problem.
first drian fuel out of tank.
i know you have already cleaned the carby but dis assemble carby and clean with carby cleaner.
re assemble carby & fill tank with fresh fuel.
also clean air filter & check oil level & check spark plug,if the spark plug is black and the tip is blocked with oil build up, then replace.
Oct 22, 2010 | Honda Garden
I have an Excell model XR2600 pressure washer that will not start. I have had it stored for 3 years. I drained the gas tank and carb and put in fresh gas. Is there a fuel shutoff on this model ? It has a...
If it's been sitting for 3 years most likely the carb is gummed up. If it's getting spark, you could try a small shot of starting fluid into the carb. If it runs on this you know it's a fuel problem. Best bet would get all the MOTOR data, and buy a carb kit from you local lawn and garden equipment parts supplier. . Remove carburator and clean and install kit. Use sta-bil when you put it away next time, but even that only works about a year or so.
Jul 05, 2010 | Karcher 2500 PSI Pressure Washer
Why does my motorcycle stall when i slow down and dies when im riding normal speed after like 15 sec into the ride and it doesnt seem like its getting all of its power when u gag on throttle
Your fuel petcock (on/off tap) may be restricting fuel flow and the carbies may need to be cleaned.
To maximise fuel flow thru a dirty fuel filter or restricted fuel flow thru a contaminated carby jet, disconnect fuel hose from tank and drain remaining fuel in carbies into a glass and inspect for contaminates. Take off float bowls and spray ($8 retail 400g aerosol spraycan carby cleaner) cleaner down fuel line/hose until it pours out of carbies. Allow to evaporate. Replace fuel filter (there may be a cylinder of white mesh gause inside of fuel hose) and check bottom of tank for rust, scale or debris. Try fresh fuel, new sparkplugs (0.8mm gap) and ensure choke is functioning correctly. Check camchain tensioner is not loose. Keep battery fully charged, replace if the bike can't achieve this when running with no lights..
http://www.cmsnl.com/honda-cx500-79-us_model7377/partslist/ This link will give you diagrams to help you out.
Cheers.
May 08, 2010 | 1979 Honda CX 500 A
I have a firefighting pump with a honda engine it
above the startercord there are 2 handles. top one is grey is choke , bottom is black, is fuel tap. first open fuel tap put on choke, start, after 5 or 10 seconds put choke off. if its not starting on choke, gets no fuel. under fueltap is chamber with 10 mil bolt. open and clean. also drain or take off floaterchamber of carb. this is the round cup under the carb. good luck.
Feb 12, 2010 | Honda 8 HP Engine
Wont run on ldle with out choke
Hi there
Sounds like the air pilots systems could be blocked.
That's if it has cabies, not fuel injected. Answer is to clean the carbies. Make sure you blow the cabies out with a air compressor. Also check your fuel filters, may need cleaning or replacing.
Regrades Lighten
Apr 26, 2009 | 1996 kawasaki ZX-7RR
Yzf 250 wont run without the choke
Hi mikelapt
You will have a carby problem. When the choke is one, and different fuel circuit is used. When you turn off the choke, you go back to the idle circuit of the carb is used, when under throttle, main jets kick in. You probably have a blockage in one of these circuits. Strip the carb down, clean with carby cleaner, blow out all air circuits and jets with compressed air, then setup the idle mixture and tick over speed. Always work with fresh fuel, and drain off, discard any fuel older than a couple of months. It goes off, and turns to a gel  like substance that blocks up your carby. Hope this has explained your problem. Happy to talk to you more about it. A FixYa vote is a great reward for for my time taken to explain this to you. Cheers
regards robotek
Feb 08, 2009 | 2004 Yamaha YZ 250 F
Daewoo Lanos 1999 Not starting
Usually this is because the carburettor dries out and there is a needle and seat (internal on carby) that can get stuck and not let fuel in. Usually from a little dust water and general **** that comes with the fuel. Id spray the carby out with carby cleaner, remove the fuel line from it and spray out the fuel bowl. Possibly even open up the carby and completely clean it, but only if you are confident on putting it back together. But try just spraying it and cleaning it first, then tip probably a quarter (1/4) of a cup of petrol in the hole in the carby and try starting it, this should make it run. Maybe a little rough at first, but you may need to clean the carby a couple of times, and will need to pump fresh fuel from the tank. So good luck and hope it helps.
Dec 21, 2008 | 2000 Daewoo Lanos
Electronics - Others Logo
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
