Question about Frigidaire Affinity ATF7000ES Front Load Washer
Leaking from underneath machine - Frigidaire Affinity ATF7000ES Front Load Washer
    Genius:
  • Frigidaire Master
  • 1,474 Answers
Check door boot seal //Grey in colour, may have hole in it..
Posted on Feb 08, 2010
This is an Estate Whirlpool washer. It is leaking water from underneath? Check all hoses on back and they are dry(not leaking). Any suggestions?
could be 2 thigs the outer platic tub is broken or transmission or transmission seals are gone, go on line and see how to fix is very easy work on these machines.
Dec 27, 2015 | Estate Washing Machines
Water Leaks Underneath
You really need too look underneath and see where water is coming from that means raising the machine off floor washing machine quite heavy so need to know what your doing
Nov 09, 2015 | Whirlpool WFW9050XW Washer Front Load...
Washing Machine leak underneath the machine - Zanussi FLS-579C
have checked the door seal
send the 91------------- no this is on a label in the door
Feb 05, 2014 | Zanussi Washing Machines
Maytag washing machine leaking
it could be coming from different sources. Most likely is the hose. You might need to replace hoses that bring water to the machine, but first check that they are not loose or have cracks that could cause these leaks to occur.
Jan 05, 2014 | Maytag Washing Machines
Water leaks from underneath my top load washer
Could be pump with motor.I replace on mine,had water under.
Apr 12, 2013 | Washing Machines
Error code FA
FA is the emergency shutoff switch that detects when water is pooling underneath the machine (a leak)
You may have to remove the back of the machine to check the float switch underneath. Empty any water from the catch tray and check for leaks.
Mar 02, 2012 | Whirlpool Washing Machines
Washing machine leaking from underneath
Check the hoses underneath drum. Sometimes the get disconnected. If still okay? I would take the front panel off and run the machine to see where its leaking from.
Apr 03, 2011 | Washing Machines
Amana top loading super capacity LWD35AW leaking
Hello horshomom
Welcome
You said, You just found out my machine is leaking underneath somewhere and you haven't taken it apart yet. Any suggestions or ideas?
How old is the machine?
How much water leaks and when?
It usually is a leak in or around the drain hose.
I've seen a clamp vibrate loose near the pump.
You should be able to find it!
Let me know. Huuum
Please remember to leave a rating.
Oct 04, 2008 | Amana Washing Machines
Water is leaking from the underneath, at the front of the machine
The drain pump is located at the front, underneath. The drain pump has probably failed and will need to be replaced.
Jun 04, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
101 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
