Question about Microsoft Xbox 360 Console
Xbox 360 wireless controller battery pack
How long do you have to charge the rechargeable battery pack as i have just bought and it has no instructions
thank you
trevor
    Genius:
  • 1,019 Answers
these can take between 4-12 hours to fully charge.
And will only charge with the lead connected from the controller to the USB Port on the 360 Console.
Mike @ Compurepair.
Posted on Feb 22, 2008
Where can I get a manual for and a rechargeable battery pack for model number F260B ?
there is none made that are direct replacements for 2 single batteries.
Aug 05, 2017 | Flip Video Video Cameras
Card indicates memory error what can be done to correct this problem and also save dictation already on there ?
Hi cazpell,
If you're encountering a memory error, it is often caused by the battery pack. Battery packs included with the DS-4000 are rechargeable battery packs. This problem is likely to happen on the DS-4000 when a NEW battery pack is being used. The battery pack out of the box does not hold enough charge to power up the recorder through its initial start-up procedure.
1. Please turn off the recorder.
2. Remove the battery pack and memory card for 20 seconds.
3. Install the memory card in the card slot.
4. Install new AAA batteries before you turn ON the DS-4000.
5. Your battery pack may also not be fully charged. All new battery packs must be fully charged from 2.5 to 3 hours before first time use.
6. For the first week to 10 days of use, it is recommended to recharge the battery pack as often as possible. This will exercise it and improve its charge-hold capacity.
Hope it helps.
Thank you for using FixYa.
Jun 21, 2011 | Olympus DS-4000 Digital Voice Recorder
HOW DO YOU RECHARGE THE BATTERY
I'm glad to provide the instructions to charge the battery pack of the Camcorder. Please follow the below steps to charge the battery pack:
I hope the information helpful. If you require any clarifications, please let me know.
Thanks for understanding.
Jun 10, 2011 | Sony Handycam DCR-TRV30E Mini DV Digital...
HELLO: OUR MILWAUKEE 48-59-2401 BATTERY CHARGER IS NOT CHARGING OUR 48-11-2401 BATTERY PACKS. WHEN YOU RUN THE PACK DOWN TO 1 OR 2 LIGHTS & PUT IT IN THE CHARGER BOTH RED & GREEN LIGHTS FLASH....
If both lights are flashing after you put a cool battery on the charger, the battery is bad. It could have a bad, worn or shorted cell or other problems inside and the charge will not charge it as long as it reads it as a bad battery. Rechargable batteries do have a finite life determined mainly by how many times you recharge them.
Jan 20, 2011 | Garden
How to charge Panasonic lumix DMC-FS4
hello there use your USB cable for charging your camera battery. No need to take out the battery from camera. Some Tips.
  • You may choose our Smart Charger (0.5A,UL listed) for 3.7 V Li-Ion battery Pack to recharge this battery pack. Must charge the battery pack with correct polarity. The estimated charging time is 2.76 hours .
  • You may connect two 3.6v 920 mah pack in either series or parallel connection for making a higher voltage and higher capacity pack.
  • Hope you have those staff with your camera. use that for charging. Follow the link.
    http://www.batteryspace.com/smartcharger05afor37vli-ionpolymerrechargeablebatterypack--ceullisted.aspx
    Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
    Jan 31, 2010 | Panasonic Lumix DMC-FS4 Digital Camera
    Kodak Easy Share Printer dock plus. Original
    you're not completely right. Kodak printer docks normally only charge the Kodak KAA2HR battery pack. It not charges normal Ni-MH rechargeable batteries of any brands.
    Jan 12, 2010 | Kodak EasyShare Thermal Photo Printer
    I can figure out how to charge my GE A835 camera
    I dunno, but I bought a pack of rechargable batteries. I don't think you can recharge it.
    Oct 11, 2009 | General Electric A835 Digital Camera
    Microtalks won't charge
    I have the Cobra Microtalk 4100 FRS radios with charging base. After changing the batteries with new nimh rechargables the charge light would not illuminate and the unit would not charge. I noticed the original batteries had a metal band around one end. This band makes a small connection inside the battery compartment on the first battery. Seems to be a cheap way to ensure you dont try to recharge the unit with non-rechargable batteries installed. I rapped a small piece of tinfoil around one end of the first battery in the new set then popped it back in and now they will charge correctly again. Dont try this with non-rechargable batteries! I would recomend buying original replacement batteries.
    Nov 28, 2008 | Cobra Microtalk 100 FRS Walkie Talkie...
    New Haier 7.2V rechargeable NI-MH battery pack for a new Haier Portable DVD player was stored in a drawer for 2 years until recently. Attemped to recharge battery pack via electrical outlet. Obtained...
    the battery pack is charging but not holding charge beacause it was not used for a long time as you said.try to recharge and completely drain the batteries a couple of times and the batteries should start holding better the charge.Another thing you may want to check is if there is power coming out at teh battery pack connectors(you will need a small volt meter)
    Oct 02, 2008 | Televison & Video
    Pocket Vsmile
    Maybe you have to buy a new rechargable battery pack. I have had one before and for some reason it no longer charged well. It too would hold a charge for only a small period of time, definately not long enough to appease my daughter! :) Try giving vtech a call and see what they say. At the very least they can help you get a new pack. Here's the number! 1.800.521.2010 :)
    Aug 24, 2008 | Vtech V.Smile Pocket
    Microsoft Xbox 360 Console Logo
    54 people viewed this question
    Top Microsoft Video Game Consoles & Games Experts
    Martin Murray
    Stu Morris K
    Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
