Question about Microwave Ovens
My microwave oven as stoped heating up my food allthough the built in grill and the convection oven are still working normal what as gone wrong and is worth getting fixed or will it be cheaper to buy a new one.
  • 28 Answers
Put a cup of water in micro and turn on to full power listen for a buzzing noise coming on and off if this noise is not there there is a good chance chance the magnatron has failed and will need replacing which is more likely to be more epensive than a new microwave
Posted on Feb 08, 2010
  • Microwave Ovens Master
  • 12,061 Answers
In all likelihood the mangnetron has failed, or perhaps even the Power Supply. You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Sharp - Food not heating up but all is lit up and turn table turns
Hai my friend, if its not heating you must open it at the back and check your fuse on top for contuinity using amultimeter it must be on abuzzer and if its fine there is other fuse covered with normal black cover connected to the cspacitor also check it, if this two fuses are fine check your capacitor if its fine check your magnetron for contunuity of 0,2 ohms but normal if its not heating its fuse, thx
Sep 13, 2014 | Sharp R959SLMA 900 Watts Convection /...
After many years of good service my Dimension 4 does not microwave. It goes through all the motions but doens not heat the food. the convection and grill functions are working fine. HELP!
Hi Michael,
i think something wrong with its high-tension circuit or your magnitron is bad.
the minor fault is open of therm stat for protection.
or burnt fuse in circuit.
regards,
nuwan.
Jan 09, 2014 | Panasonic NN-T888S Convection/Microwave...
GE Advan 120 micro not heating food. Unit runs and turns normal
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 20, 2011 | GE Advantium 120 Convection/Microwave Oven
On microwave mode the oven makes light buzzing noise and does not heat food. Convection oven and grill functions work perfectly. michaelchrys@yahoo.com
The magnetron (the part that heats the food) may be bad or the circuitry to the magnetron may have burned out. Basically my advice is that if you have no electrical expertise, it isn't worth fixing. The magnetron if bad, costs almost as much as a new microwave. If you open it up (make sure it has been unplugged for a few hours and don't seen any obvious burnt parts (including a fuse and the diodes), then most likely the magnetron is done and a new microwave is the way to go.
Let me know how this works out for you.
Benjamin
Aug 17, 2010 | Panasonic NN-A811A Convection/Microwave...
My LG MICROWAVE OVEN IS MODEL MC-7836M CONVECTION MICRO GRILL IT IS RUNNING BUT NOT HEATING and GRILL ALSO NOT WORKING
Basic Microwave Oven Troubleshooting Tips
heatman101
Jul 27, 2010 | LG LRM1230W Microwave Oven
Sharp carousel convection/grill/microwave maybe R990
Hello :
This happens because of a bad door switch . The plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door .
Check also the turntable . It could be out of it's right place .
WARNING :
1:Don't slam your microwave door because this may cause the fuse to blow and this is the reason of bad door switch problem .
2: A microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck .
Jun 03, 2010 | Panasonic NN-S254BF Microwave Oven
GE Profile Performance Convection/Microwave Problem Heating
Either magnetron, capacitor, diode pack or transformer has failed causing a fuse to blow.
Jul 13, 2017 | General Electric Microwave Oven
Microwave Ovens Logo
71 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
