Question about Sharp AL-1655CS Laser Printer
NEW SHART COPIER- NOT PRINTING DOWN THE MIDDLE OF SHEET
Middle of copied sheet from top to bottom not copying. This is a new copier. Not sure what to do.
    President:
  • 2,072 Answers
1. Check the toner cartridge and be sure nothing is blocking the ink flow.
2. The drum cartrudge may also have something on it blocking the laser light from getting to it.
3. There may be something in the laser window blocking part of the light path.
4 Something in the scanner blocking the image.
5. A defective scanner, yes even if new.
Posted on Feb 22, 2008
If I Have a streak down the middle of my copies, is it the roller? If not, what do I do ?
if its not the cartridge then its the fuser. buy a new copier, cheaper than fixing it.
Feb 10, 2015 | Canon PC170 Black and White Copier
Error code 66-02
66:02:1 warning code (applicable to HP Designjet 130/130nr only)
Explanation
Horizontal clipping. May happen when the roll ends in the middle of printing an image. Could also happen when multi-pick occurs and two sheets are loaded together and they do not completely overlap.
Recommended action
Make sure the image size is within the selected WIDTH of the sheet.
top
66:02:2 warning code (applicable to HP Designjet 130/130nr only)
Explanation
Vertical clipping. May happen when the roll ends in the middle of printing an image. Could also happen when multi-pick occurs and two sheets are loaded together and they do not completely overlap.
Recommended action
Make sure the image size is within the selected LENGTH of the sheet.
Oct 21, 2014 | Office Equipment & Supplies
Sharp AL-2020 - Copier Producing Copies with Faint portions at Top Middle and Bottom of Page
This if often a faulty toner issue. If you are refilling it might be time for a replacement carrier. Alternatively have you checked your transfer belt for areas of damage
Jun 30, 2014 | Sharp SF 2020 Copier
Not printing in the middle of the page, suspect a paper jam. How to get whatever is in the middle out!! when you open the front door - not sure what screws to take out.
a paper jam will not stop this from printing only in the middle? make sure it is the same for all colors , not printing in the middle. if all colors are not printing in the middle. you may need your mc cleaned. **** glass cleaned, pcu replaced, transfer belt unit replaced. also make sure the problem occurs from memory as well as copies, you can ruleout hdd and scanner then.
Oct 29, 2009 | Ricoh Aficio 1232C Color Copier
How do i print envelopes on this copier
Most copiers have a stack bypass or single sheet bypass with adjustable walls. hit the paper select key to choose the bypass and run a test sheet to see which side it copies on. Some copiers copy on the top while others copy on the bottom.
Good Luck
Apr 17, 2009 | Toshiba E-STUDIO 650 Copier
Al1540cs problem
check the toner and cartiga
Sep 05, 2008 | Sharp Office Equipment & Supplies
Canon PC941 Copier: Wide white bar down middle of copies
Try replaceing the cartridge the toner has run out.
Any problems please get back to me.
Thank You
Mar 25, 2008 | Canon PC-940 Black and White Copier
Canon PC850
Yes try change the print cartridge its probably done its life.
If the problem persists please get back to me
Thank You
Feb 22, 2008 | Office Equipment & Supplies
HP 610 Color Copier
Can you copy from the glass top? The feeder asm should be easy to purchase from ebay or HP.
Aug 08, 2007 | HP 610 Color Copier
Sharp AL-1655CS Laser Printer Logo
43 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
