Question about Ryobi Laminate Trimmer Kit
Using a Royobi ERT241200 plunge router to make a channel in Rafiata pine. After some 3 m of succesful cutting, toolf drops down, thus making a deeper cut. Second occurence,and I am no expert. Can not see any defect in either chuck on 6mm simple cutting tool. Any advice please. Andrew at patand@smartchat.net.au
  • 142 Answers
Could be a couple of things
1. too deep a cut could pull too hard on the bit and make it lower
2. bit not all the way in the chuck. put bit in as deep as possible, then pull out about 1/16 inch, then titen
hope this helps
Posted on Feb 08, 2010
Testimonial: "Router now does its job, I did as you suggested. I used the other cutting tool that I have. Thank you."
How to change the channel on router
You have to login to the administrator part of the router to make the change. There will be a section that says "Channels" and you choose the one that you want. To login type 192.168.1.1 in your web browser.
May 08, 2016 | Computers & Internet
Dropped internet and NAS access
Try changing the channel.
you'll have to logon to the router - best to google the make/model for IP address etc.
Jan 23, 2014 | Computers & Internet
Router bogs down when starting to work
Several possibilities--- Are you using a short and stout extension cord plugged into a robust outlet? Is the bit dull? Are you taking too heavy of a cut? If you are cutting a wide or deep slot you should probably take it in 2 or 3 passes making the slot deeper each time.Good luck.
Aug 16, 2012 | Porter Cable Tools & Hardware - Others
Router bit keeps coming loose and cuts deeper into the timber
i have found that most times there is a slight bit of rust on the bit
buff it down with some 150 paper,and also buff inside the collet
Aug 22, 2010 | Black & Decker 11A 1 Router
How do i get a nice finish on the end of my worktop using a worktop jig ?
i have this router and it is the nicest one i have ever used. setting up a jig take time and if you are only making a straight cut then put a straight edge along your top and clamp it down. you only need the distance from the roller on your bit to the back endge of the router fence. set the straight edge that distance from the front of your top. I suggest tryinng it on a scrap piece of wood to make sure the distance is exact and the profile being cut doesnt need adjusted
Dec 19, 2009 | Bosch Plunge Router
I just received a 693 plunge router via internet order. As soon as i took out the plunge part out of the case and moved the lever it pupped up and now will not move up or down > Is there something I am...
The plunge base is spring loaded. When you move the lever is springs to the up position. To lower it place the base on a flat surface, press and hold the lever down and push down on the handles. The router bit height should be set on the depth rod with the base in the down position. Then release it to the up position. When you have positioned the bit where you want it on the work piece, press the lever and "plunge" the bit down into the workpiece. The depth rod setting will stop the bit at the depth you set it for.
Oct 21, 2009 | Porter Cable 6931 Plunge Router Base For...
Ryobi RE600 plunge router binds on the posts
Are you cleaning the area that contains the springs also and if so I would use something like a dry lubricant so that it won't attract more dust and dirt but we both know that eventually it will. Coat the posts with this and allow to dry and then push up and down on the motor to lube the bushings and you might have to do it again. You can also try a small amount of 3 in 1 oil but use sparingly.
Feb 16, 2009 | Ryobi Tools & Hardware - Others
The plunge lock "slips" when the router is used in a table
You can try to adjust the lever that moves the plunge and see if that helps, but a plunge router isn't made for upside use. If you have the option and use the router upside down often, you may want to get a fixed base.
Jan 01, 2009 | Bosch Plunge Router
Disconected again
Unfortunately, by FCC regulation, your phone and wireless device have to accept interference. Sounds like it's a proximity issue. Try moving the phone base to another part of the house - different room. That will cut down on the power level from the phone over the router.
Also, try a couple other tricks on the router by encrypting the wireless signal to the router.
The WEP ENCRYPTION encoding scheme by default will cut down on the interferences but may slow connection speeds.
And by changing the operating channel in the router to the highest one - channel 11.
Most routers will tell you what the frequencies are of the 11 channels. Try to find out the frequency of the phone and then move the router channel as far away from that freq as you can - up or down.
Stacey
PC REPAIR
www.wvpcrepair.com
Oct 13, 2008 | NetGear WGR614 Wireless Router
Ryobi Laminate Trimmer Kit Logo
186 people viewed this question
Top Ryobi Tools & Hardware - Others Experts
Mike
Jay Finke
Jay Finke
Are you a Ryobi Tool and Hardware - Other Expert? Answer questions, earn points and help others
