Question about Bugaboo Cameleon - Tailored Fabric Standard Stroller
Brake on my chameleon keeps releasing too easily. When the brake is applied and you push the pram it releases too easily, so basically doesnt work. any ideas?
  • 419 Answers
This sounds like the cogs within the braking system are broken, If you visit www.bugaboo.com you will be able to make contact and purchase a new brake repair kit that should solve the issue.
Hope this helps.
Posted on Apr 03, 2010
I just bought a 2008 hyosung comet and when applying the rear brake it locked up and will not pads will not release
Its usually possible to release the calliper by loosening the bleed screw to relieve pressure then carefully push the piston(s) back with a screwdriver or similar... Careful not to scratch the piston though.
Dec 08, 2013 | 2005 Hyosung GT 650
Manuel Parking brake release the parking brake is stuck and we are trying to get it released how do you do it?
Foot Park Brake...
There should be a release lever(not the main release) up at the top of the park brake arm, under the dash. Its small, 1.5 to 2 inches long. I recommend using a screwdriver to "flip It", keeping your fingers and hand and your face for that matter, away from the arm. It is spring loaded and will release/move very fast. Also it could just be that someone unitentionally stepped on the pedal really hard, and it will take the same amount of foot pressure to release it while pulling on the release handle.
Hand Park Brake...
Again the same principle applies. It will take the same pressure applied to release it. Push in ******* the release while pulling up ******* the handle. This one can also be released by using a screwdriver to pop the the locking tab.
Aug 18, 2011 | 2003 Buick LeSabre
HANDBRAKE ON 2006 VW PASSAT WONT RELEASE
try pulling up and at the same time push the button
May 06, 2011 | Volkswagen New Passat Cars & Trucks
Push down the parking brake now where is the release lever
The ebrake releases automaticaly when you put it into drive, if the brake doesnt release when in drive then the vacuum release valve may be bad but theres an arm to release in manually, look under the dash where the e brake pedal is and on the side of the braket for the ebrake pedal is a small arm that will release it, good luck hope this helps,
Jan 14, 2011 | 1995 Cadillac DeVille
My brake lights don't turn off, even when the engine is off.
Most vehicles brake lights work whether the engine is on or not. Check that the brake pedal is returning properly. See if there is a sensor under the dash that is engaged when pushing on the brake pedal. It may be on the pedal mechanism or on the front firewall. It may need to be pulled on. This will probably require a repair to correct the issue as it will probably happen repeatedly.
Mar 13, 2010 | 2005 Dodge Grand Caravan
The brake button on my bugaboo chameleon is jammed and won't release therefore the brake won't work , what an i do
Your best bet is to contact www.bugaboo.com for a brake assembly replacement. If the break is permanently in the 'on' position, then gently push it forward (as if to put in on) whilst pushing the white release button, this should release the mechanism. If this is still within it's warranty, see your retailer for help.,
I hope this helps.
Sep 01, 2009 | Bugaboo Cameleon Jogger
FUSES ARE GOOD, whichfuse works on windows door locks & sunroof
go to the trunk latch release solenoid and have someone push the release while you check to see if the solenoid gets 12 volts at its connector in the trunk, make sure the parking brake is on while you do this as it will not work unless parking brake is applied (manual trans only), let me know what you find.
Jul 28, 2009 | 2002 Volkswagen Jetta TDI
Parking brake assembly diagramneeded
Item Part Number Description 1 2553 Rear Disc Brake Caliper 2 4234 LH Axle Shaft 3 2C026 Rear Disc Brake Rotor 4 383609-S Push Nut (2 Req'd each side) 5 2C189 Rear Brake Anti-Lock Sensor Indicator 6A 3912205-56 Nut (4 Req'd) 7 2C220 Rear Wheel Disc Brake Adapter 8 1177 Inner Wheel Bearing Oil Seal 9 390317-S190 Bolt (4 Req'd) 10 1225 Rear Wheel Bearing 11B 2B296 Disc Brake Caliper Locating Pin A Tighten to 27-54 Nm (20-40 Lb-Ft) B Tighten to 26-35 Nm (19-26 Lb-Ft)
The automatic (vacuum) release-type is standard equipment on all vehicles. The automatic vacuum-type parking brake system contains the following features:
  • A parking brake release control motor (2A843) with mounting bracket bolted to the parking brake control .
  • The vacuum-actuated diaphragm within the parking brake release control motor which is connected by a rod to the upper end of the parking brake release vacuum hose (2B653) .
  • The parking brake release vacuum hose which connects the parking brake release control motor to the engine manifold through a vacuum release switch at the steering column tube (3514) .
  • The parking brake release control motor which is actuated to release the parking brake whenever the engine is running and the transmission is in a forward-driving gear.
  • The automatic parking brake control which has a manual release feature that releases the foot parking brake control by applying force to the parking brake control pedal in the "apply" direction to the point of initial application.
  • The parking brake control will return to the full-release position after removing the force.
Apr 14, 2009 | 1994 Lincoln Town Car
I have a 3 series yr2001 that has sat up for a while and the hand brake has seized. any suggestions
if you can release the handle but the brakes are still applied.try reversing the car fast then pumping the brakes.if that doesnt work after 2 tries, you have to manualy release it at the wheels.if this makes no sense to you please clarify
Mar 27, 2009 | 1994 BMW 3 Series
Parking Brake problem
2000 S-10: brake functions properly while pedal is held down, but when I remove my foot, the brake is released.
The following is not a repair so much as a solution to the basic problem and I guess it won't pass scrutiny of any state inspection. Nevertheless, this idea may skip around the automatic pedal stop malfunction and buy you some time while a proper part replacement is arranged.
The release cable ends at the ratchet assembly by the pedal and the lever which receives it can be pushed forward before depressing the pedal thereby engaging the stop which will hold the pedal down and keep the brake engaged. There is no click, or catch evident when the release lever is moved forward and it only moves a little bit.
Not the easiest reach from the driver’s seat. Also, the release cable is likely to jump out of its place if you just reach blindly and push.
From what I've read on this site, there are some design issues with the ratchet mechanism that commonly lead to failure of the pedal stop function.
Hopefully this will help those who still want to park on a hill.
Jan 21, 2009 | 2000 Chevrolet S-10
Bugaboo Cameleon - Tailored Fabric Standard Stroller Logo
115 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
J.D. Browning
J.D. Browning
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
