I have 4 year old Hotpoint washing machine with hot feed and cold feed. have moved to new house with only cold feed. Will it still work? Do I need to plug the blank hot feed on back of machine?
    Genius:
  • Washing Mach... Master
  • 1,467 Answers
It Will work ...However you will need a Y piece connector both hot and cold hoses connect to this costs around £2.. ..A cheap fix..
Posted on Feb 08, 2010
Testimonial: "Thank you for the prompt response with what seems a sound practical solution"
Can i use my hotpoint first edition washing machine with just a cold water feed under sink it has a hot and cold feed but i only have a cold water feed under sink
you can of course but set the temp control to cold only . normal is not from under any sinks tho . have a plumber come and add a hot water outlet for you
Apr 28, 2015 | Hotpoint Washing Machines
In a previous house, we had both a hot water feed and a cold water feed. My new house only has cold water feed, can i still use this washing machine?
In a word- YES!
You will need to purchase, from a hardware (?) store, a 'Y' adapter. Upside down the single end screws into the cold water supply and the hot and cold washer pipes screw into the double end. The washer is fooled into thinking it has hot and cold! When it expects hot, it opens its hot valve but instead gets the cold water and has to heat it up. It will therefore take longer for the machine to do the washing. When it wants cold for rinses, it opens its cold valve and gets the same water! Simple ;-0)
Good luck,
John C
Mar 16, 2011 | Indesit W 123 Front Load Washer
Does the wma76 hotpoint need a hot water feed? Is a cold water feed enough?
Hi from retired Englishman in France (it's 21:29!),
If your washer has 2 pipes for feeding water then one is for hot and the other is for cold naturally.
All washing machines have a water heating element in them- in case any hot water supply is not hot enough for its wash.
If you only have a cold tap you will need to purchase a 'Y' connector. This screws onto the cold tap supply (single end) and the hot and cold feed pipes connected to the washer screw onto the other two ends. The machine will now be fooled into thinking it has two separate feeds!
The machine opens the valve for the 'hot' water supply (which of course is cold) and the heats it up to the required temperature for the wash cycle. Afterwards, when the machine requires cold water for rinsing, it opens up the 'cold' supply (which is the same supply as for the hot water!) and is happy.
Hope this answers your question.
John C
Jan 26, 2011 | Hotpoint WMA76 Front Load Washer
Im instaling a 2 yr old zanussi aqua 1000,it has a hot and cold feed,there is just a cold feed at the house
http://www.4ourhouse.co.uk/cgi-bin/product.pl?PID=213690&brand=&model=&part=y-piece&style=washerhelp
Washing machine is a hot and cold fill, but I only have a cold water supply You can use a Y Piece connector (external link 4Washerhelp spares) to connect the hot and cold fill hoses to a single cold water supply. The washing machine will then work OK. Simply screw the Y-Piece onto the tap, and then screw the hot and cold fill hoses to the Y-piece and connect the other end of the fill hoses to the washing machine. (You may be able to buy this part also from a DIY store like B&Q)
Oct 21, 2009 | Washing Machines
Hot point aquarius 1100 - does this have a heating element for cold water feed ? or does is need direct hot water feed ? (there is a inlet at back for both hot and cold so presume no heating element ?)
All Hotpoint washers have heater element regardless of whether they are cold fill only, or hot and cold fill.
if 2 connections at rear, then it is hot and cold fill, if only 1 connection, then it is cold fill only.
Please rate my solution.
Thanks.
Jul 24, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint BWM129
hi there,
try the following, it may help:
Some washing machines allow hot water to enter only during certain cycles. Others intermittently
allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual
if you are unsure about whether the machine is acting abnormally.
If you're sure the machine isn't working the way it used to--or should--try these tests:
* Is the hot water turned on? If not, turn it on.
* Is the washer getting cold water but no hot water? If so, check to see if the control panel
settings are correct.
Apr 18, 2008 | Hotpoint BWM12 Front Load Washer
Washing Machines Logo
53 people viewed this question
Top Washing Machines Experts
