Apple iPod nano Logo
Posted on Feb 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you charge your ipod on your computer - Apple iPod nano
Anonymous
Level 3:
  • Master 11,896 Answers
  • Posted on Feb 08, 2010
Anonymous
Master
Level 3:
Answers
11896
Questions
Helped
3735581
Points
36074
Just plug usb cord into ipod and into computer. Make sure you have the drivers downloaded and installed for pc to recognize your ipod.
I have an ipod model a1199. i was wondering if you can use a newer ipod touch charger for it? and if not what kind of charger does it use?
Charge an iPod Nano Without a Charger
If you've misplaced or broken the charger that came with your iPod Nano, you might think you need to purchase a new one in order to continue using your Mp3 player.
However, there is a way that you can continue enjoying your iPod without having to purchase a new charger.
As long as you have a USB cord and a computer, you can charge your iPod without having the charger.
Locate the USB cord that came with your iPod Nano package.
It is the same cord that you use in order to sync or transfer music.
Plug the small end into your iPod Nano.
Plug the other, larger end into your computer's USB port.
Choose "Do Nothing" when your computer presents the dialogue box to let you choose what to do with the hardware or USB connection.
Leave your Nano plugged into your computer for at least 4 hours to charge.
Unplug your iPod Nano when charging is complete.
Charge an iPod Without the Charger
Many iPod owners purchase a charging unit that plugs into a standard wall outlet to recharge the iPod's battery.
However, the iPod wall charger is not included with new purchases, so consumers must either purchase a separate charger or find a way to charge their iPod using other means.
Here's a simple method to charge your iPod using your computer.
Plug the iPod USB cable into the bottom of your iPod.
Plug the other end of the iPod USB cable into a free USB port on your Mac or PC computer.
Open the iTunes program by clicking on the icon in the Dock on a Mac or using the Start menu on a PC.
Click on the name of your iPod under the "Devices" heading in the main iTunes window.
Click on the "Sync" button to synchronize your iPod with your computer data.
While the iPod is syncing, the power from the USB port on your computer will charge your iPod's battery.
Unplug your iPod from the computer once the battery is fully charged.
http://www.bing.com/images/search?q=images+of+apple+ipod+usb+chargers+&qpvt=images+of+apple+ipod+usb+chargers+&FORM=IGRE - view=detail&id=8DEA58C0DAF392E29FCB03D9C
This one should be ok.
tip
The battery of my iPod is not charging
<p>When you buy an iPod, the device comes with cables that connect the charging device to the computer. When the iPod battery is low, you can recharge by plugging into your desktop or laptop. But sometimes, when you connect your iPod to your computer, the battery charger. According to Apple's site, some problems may prevent your iPod from charging properly. <br /> <p><br /> <p>1. Connect your iPod USB charging cable only one USB port on the computer itself. External port devices, such as a USB hub, do not provide enough power to recharge your iPod. <br /> <p><br /> <p>2. Connect the iPod firewire charging only one firewire port on your computer. Like USB, Firewire ports are not enough of a load to the battery of your iPod. <br /> <p><br /> <p>3. Disconnect the computer from sleep when the computer set to sleep after a certain time. An iPod can only load on a computer that is connected and not in sleep mode. To enable sleep mode on most computers, you can move the mouse or press the power button once. Hold the power button, which usually turns off the computer. <br /> <p><br /> <p>4. Turn the iPod off and on when the unit is frozen. A frozen iPod is not charging. If the unit is still frozen when you turn it on again, restart the iPod by pressing the "Hold" switch to "On" and then back to "Off" and press and hold a "Menu" and "Select" buttons simultaneously or " Start "and" Menu "button. Hold the buttons until the Apple logo appears on the screen. <br /> <p><br /> <p>5. Set the system up-to-iPod charger so that when using a Windows 2000 computer. In preparation for the system to load the iPod device to the unit with the charging cable, launch iTunes and "iPod" in the left pane to "Settings" tab to go, check the box next to "Enable Disk use", and click the "Apply" button. Once the configuration is in place, the iPod will charge as normal. <br />
on Aug 09, 2011 • Apple iPod touch
tip
How can I use my iPod while charging?
<p>If your iPod and it gets low on battery, you can continue to enjoy your music while charging your iPod. To charge your iPod, you can choose from one of two ways: Use a computer to add power to your iPod, or use an electrical outlet to charge the device. Either method will allow you to use your iPod while charging. If your iPod is so low that it does not turn, you may need something to load before you can use while charging. <br /> <p><br /> <p>Charging the iPod using a computer <br /> <p>1. Connect the USB cable to your computer and connect the other end into the iPod port. <br /> <p><br /> <p>2. Make sure your computer is on and not sleeping. <br /> <p><br /> <p>3. Open iTunes and choose the iPod that you connect to the source list to access the settings to get the iPod. <br /> <p><br /> <p>4. Open the menu "Options" and "Manually manage music" checked. If you change the settings to manually manage music, iTunes lets you listen to your iPod while it is connected to the computer and load. <br /> <p><br /> <p>5. Click "Apply" manually manage music, then use the iPod as you want on your computer while charging. <br /> <p><br /> <p>6. Eject the iPod once it is loaded by pressing the 'Eject' button in iTunes. Remove the USB cable from your computer and iPod. <br /> <p><br /> <p>Charging With USB Adapter <br /> <p>1. Connect the USB adapter for the iPod and an electrical outlet. <br /> <p><br /> <p>2. Continue to use your iPod as you want while charging through the USB adapter. <br /> <p><br /> <p>3. Unplug the USB adapter and plug the iPod and the iPod is charged. <br />
Why isnt my ipod charging?
iPod's battery doesn't charge
Several things could keep your iPod's battery from charging. The major causes are listed below in logical order. Check each one to see if it's what's keeping your battery from charging.
Low-powered USB port
iPods that connect to USB ports require a high-power USB port.
Keyboards and some USB hubs will not charge iPod. Connect iPod directly to the computer or to a USB AC power adapter. Click here for more information.
Connect directly to computer
If you connect iPod to something that connects to the computer (like a USB hub or FireWire drive), connect iPod directly to the USB or
FireWire port on the computer.
FireWire port on a Windows PC
The FireWire (IEEE 1394) ports on some Windows-compatible computers may not be powered, and consequently won't charge iPod when you plug it in. Check here to see if the FireWire port on your PC can charge iPod.
Your computer goes to sleep
Your computer can only charge iPod when it's turned on and not asleep. Make sure your computer is on and not set to go to sleep when you want to charge iPod. Tip:
Some Macintosh computers can charge iPod even though they're asleep.
If your sleeping computer doesn't charge iPod, don't worry, just wake it and let iPod charge.
hope this helps
What could be the problem if my iPod Classic won't charge?
Be sure to connect the charging/sync cable directly to the computer, not a USB hub. Most hubs are don't provide enough power to the usb ports to charge the ipod. If you need a method of charging the ipod while away from the computer connect your sync cable to a device like these: Even the USB port on Apple keyboards is not able to charge the Ipod.
If you're using the computer to charge the Ipod, be sure it stays on, when computers go into sleep or standby modes they stop charging your ipod. You may want to use one of the options below to charge your Ipod when the computer is off or in a different location than the Ipod.
For use inside: Best prices for a Belkin brand power adapter for Ipod click here
For use in the car: Best prices for a Belkin brand car power adapter for Ipod click here
1helpful
I want my ipod to charged without my computer
What you need is the wallwart that (Sometimes) comes with the iPod. that way you can charge it without connecting to the computer, Check the iPod shop for one or there are some generic ones available on google shopping.
2answers
Apple ipod not getting charged
First, please check your connection (I'm sure you have already done this). Make sure that the cable is plugged in and working on both ends.
If that is fine, I would recommend taking it back and getting a new one. If you just recently purchased it, you should be able to return without a problem. It sounds like you might have a defective product and you don't want to get stuck with it after the return period.
Good news is that when you get the new one, if you use iTunes, it will automatically sync up and you wont have to manually load songs.
Hope this was helpful but if you still have questions, let me know.
Have a great day
2answers
Infitek shuffle ipod
Greetings bernince24,
Generally when an Ipod is charged, it is off and connected to a usb port with your computer. It simply draws power off the computer. It is all pretty intuitive, plug and play. Meaning the once you hook the ipod to whatever charging device you are using, it will charge on it own from there.
I hope this helps.
Dorothy
Go Ahead. Use Us.
5helpful
5answers
My ipod will not charge on the docking station
my ipod wont charge. it shows the charging icon, but when i take it off the charger it dies like it didnt charge at all
2answers
Ipod not turning on or charing with computer
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod.five_rs/
If that is not able to fix your problem, contact apple or your dealer for more assistance or repairs.
If you need more assistance let me know. Good luck.
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
