Question about HP Pavilion dv6000z Notebook
Black screen checked memory battery etc to no avail
  • 56 Answers
Take a external monitor and plug into the side of the laptop if you get a display then your lcd is bad. if you are going to replace make sure to get a new cable just in case that was the problem. if you do not get any display *********** board is bad.
Posted on Feb 10, 2010
Was fiddling with car stereo, accidently touched black and yellow wire, think I've blown something cos now neither stereo or central locking works! Please help.
Black is ground, yellow is battery constant power for memory (clock, station memory, etc...) you burnt the fuse for that constant battery power. Just check for burnt fuses
Mar 22, 2015 | Cars & Trucks
Ga-g41m-es2l xp install problem
do you have enough memory (RAM) ? .freezes means to little memory.
Jun 09, 2013 | Computers & Internet
Packard bell easynote M5284 - black screen after installing new RAM
Sounds like the memory is incompatible with the laptop. Remove the memory and install orginal memory and boot again to see if every works correctly.. If so then either a memory module is bad or motherboard wont support the new memory (size or type)
Mar 14, 2013 | Packard Bell EASYNOTE M5284 COMPATIBLE...
How can i check if memory is faulty on an hp pavilion laptop
may be remove memory and give a good blow lots of dust gets in
Nov 27, 2012 | HP Pavilion dv6000z Notebook
Purchased 1g ram to add to my computer and now i have a black screen replaced with old ram and still have black screen. what should i do
Hi!
First of all, check if the RAM module(s) sits firmly in the slot(s).
Now try this:
With the power cord disconnected and with no battery attached, press the power button several times, short pressings. Now reconnect the power cord and try powering up normally.
You can also try using 1 memory module at a time, with each one of the available slots in the laptop.
Pelu.
Mar 14, 2010 | Sony VGN-FS740/W Notebook
Cannot start up the laptop
Hi there.
That really quick flash of a blue screen is the blue screen of death and there is a possibility that the error could be memory related.
What you have to do is remove and clean the system memory and the slots the memory goes into.
Take out the battery and the AC power (if attached)
The memory will be located behind a panel underneath the laptop, unscrew the panel unclip the memory, clean the brass contacts and the slots with a clean, dry, soft paintbrush, then reseat the memory making sure it clips into place, replace the memory cover and reboot the laptop, see if it lets you into windows.
Please post back with the results and more help if needed, good luck and thanks for using FixYa!!
May 20, 2009 | Toshiba Satellite A105-S171 Notebook
Screen black in all lighting. Icons and menu show and can view photos already on card, but screen black in all modes. Can take picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Hello, I went and researched a few points in the manual and hope this helps to some extent. If this doesn't help, try resetting your camera by removing the batteries for 30 seconds, then reinstalling them and turning on the camera again.
Monitor is blank:
• Camera is off.
• Batteries are not correctly inserted or battery-chamber
cover is not properly latched.
• Batteries are exhausted.
• EH-62B AC adapter (available separately) is not properly
connected.
• Camera is in sleep mode. Press shutter-release button
halfway.
• Monitor is off.
• USB cable is connected.
• AV/Video cable is connected
No picture is taken when shutter release button is pressed:
• Camera is in playback mode.
• Red (!) lamp flickers: flash is charging.
• Green (AF) lamp flickers: camera unable to focus.
• Message "CARD IS NOT FORMATTED" appears in
monitor: memory card is not formatted for use in your
camera.
• Message "OUT OF MEMORY" appears in monitor:
insufficient memory to record picture at current Image
mode setting.
Dec 02, 2008 | Nikon Coolpix 4600 Digital Camera
HP 3600n Cartridge Memory Tag
Check the latch on the right side of the black cartridge. They have a problem with them breaking. There is a new style available.
Oct 18, 2008 | HP LaserJet 3600n Printer
No image output on screen or viewfinder
If you can see images in play mode, previously taken pics, then check to see if iris is opening and closing, could be seized vanes on iris motor. Tap on the lens(just not on the glass) repeatedly, this might help jog the vanes open. remove batteries, reinsert them after an hour, or a cup of coffee. If it persists press the reset button . all your settings will be cleared. Check to see if there's a second internal battery used for function memory, if there is, remove that one too for a while. Sounds a lot like the global CCD sensor problems that most manucturers had last year, but I don't remember anything regarding panasonic in that context. Use your warranty if valid Good luck
May 21, 2006 | Panasonic Lumix DMC-LC1 Digital Camera
HP Pavilion dv6000z Notebook Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
