How do you cancel a program once it has started? I f I've started a program and change my mind and switch it off it just goes straight back into it where it left off when I switch it back on. It's annoying
  • Gerry Harvey
    Gerry Harvey May 11, 2010
    Depends on the make and model.....??
  • Washing Mach... Master
  • 3,463 Answers
Depending on the make of washer which you do not specify, most brands now have a cancel button, you press this to cancel the programme, and reselect the new programme., it may be incorporated in the start button.
I cannot be any more specific, as you have not given the make.
Posted on Feb 08, 2010
Why have you not cancelled this program? You said we could cancel any time. I want to cancel this System Mechanic-Pro at this time. Thelma Bigley
sad to say that is not our program . as we have none .check in your control panel and in programs click on that program and uninstall it .
Aug 27, 2015 | Iolo Technologies System Mechanic...
Washing Machine not stopping water flow
in the back of the machine attached to the bowl is a small tube that goes up to the controller in the dash panel. This tube should be straight with no kinks or pinch points. This is pitote tube and conveys pressure to the controller diaphragm that connects to a micro switch that turns the water off and the machine on. As the water rises the air trapped in the tube increases in pressure and pushes on the diaphragm. Sometimes if there is water trapped in the tube it stops working You control the pressure that the diaphragm works at by the water level you select
Jun 10, 2013 | AEG Washing Machines
HOtpoint Fdw 60 goes straight to DEMO mode and refuses to do anything? Any idea?
Try resetting cycle-Push cycle select and cycle start together till you hear a long beep followed by three short beeps.this will cancel previous selection and allow a new program to be selected
Nov 10, 2011 | Hotpoint 24 in. FDW60 Free-standing...
I want to go back to mky old classic mail
try this & see if it works for you
How to change back to Yahoo
Log in to your yahoo mail account
In your web browser go to the yahoo mail home page sign in to your account using your yahoo ID and password, then click the yellow sign in button. Once you've successfully logged in you'll see your email folders on the left and the what's new and inbox tabs in the middle.
Choose the mail classic option
On the upper right side of the page there are three links -- Mobile, Options, and Help. Click Options, and when the drop down menu appears, choose mail classic
Confirm that you want to switch back
A dialog box will pop up with two choices -- switch to yahoo mail classic and cancel. If you're sure you want to switch, click the first option; otherwise, choose cancel to keep the new yahoo mail.
Depending on your computer's speed and your internet connection, the switch may take several seconds. When it's completed, you'll be looking at the old familiar yahoo mail classic interface.
Sep 22, 2011 | Yahoo Mail
I want to switch back to yahoo mail classic
How to change back to Yahoo--try this & see if it works for you
Sep 21, 2011 | Yahoo Mail
1993 Dodge Dakota 5.2 318 4x4, turns over, but no spark. Cat converter shot, removed. Plugs, cap, rotor replaced. MAP sensor recently replaced...will start and run once in a great while.
Try switching the ASD Relay for another relay in the Fuse Box in the Engine Compartment. If the ASD Relay fails it cancels the power to the Hall Effect & Fuel Pump.
If that doesn't change anything, check the wiring harness that travels down the left wheelwell for damage, It actually goes outside of the engine compartment, into the wheelwell where it can be damaged by rocks, road debris or a tire (if you've flexed the suspension, or had the truck off road). If the wiring there checks out, it leaves one other thing.
The Hall Effect Sensor inside the Distributor.
Aug 23, 2011 | 1993 Dodge Dakota
Water pump goes through the whole cycle with door open.
You can replace the lid switch to fix it. The best thing to do is sort your laundry first from all over the house where you left the items. Make a load sized pile and place in washer along with the detergent and then turn on washer. If the switch has been straight wired it will do this. The switch on mine is straight wired and I have no problems with it. The lid switch is on there to keep small children and arms from getting hurt and broken.
Jun 29, 2009 | GE WBSR3140DW Top Load Washer
Need to reset washer it is stuck in mid cycle and wont continue nor start over
doesnt this model have the cancel button by the start button.......if so........switch on then hold cancel for 10 seconds...........
cheers
Jul 24, 2017 | GE WBVH6240F Front Load Washer
The unit fails to turn on, 2day's ago it worked fine i've put it in stand by with my remote. Today it won't start i've disconected everithing, unplugged power sply for halt an hour. Still don't work...
If you don't mind resetting all of your personal parameters you might want to flush everythign and start fresh.
The manual says to Hold TONE CONTROL and PressStanby/On to turn the unit on as if you want to reprogram it.
Press Program </> to select Preset
At this point I would think we would had established that it CAN turn on or not.
If it's ON, Press STRAIGHT until CANCEL appears, then Standby/On to Cancel and turn it off.
Try to turn it on normally.
Apr 10, 2009 | Yamaha HTR-6030 Receiver
I NEED to cancel warning tones...
You cannot cancel the feature but the on-hold recall timer can be increased. This is a system programming feature that will effect all phones. You could change the timer from 60 seconds to say 240 or more. Do you know who is in charge of making programming changes for your system? You may have someone at the office or you may pay a company for adds, moves & changes. As far as programming goes, changing a simple timer is about as easy as it gets but it's still a bit complicated and would require a programming manual for your phone system (not the phone) so the first step is to find out which NEC phone system you have.
Jul 12, 2007 | NEC Electra Elite 32D-1 Corded Phone
Washing Machines Logo
50 people viewed this question
Top Washing Machines Experts
