Question about HP Compaq nx6125 Notebook
Hp compaq nx6125 fails to power up with mains or battery, battery led flashes 8 times after power switch is pressed,
    Problem Solver:
  • 7 Answers
I think is your bios battery(it is found on your board i dont know the type of system that you are using but just check for the silver battery and change it
Posted on Feb 08, 2010
My laptop won't start
Does the HD light turns on?
If not, try to open HD bay, disconnect and reconnect disk.
Mar 22, 2013 | HP Compaq nx6125 Notebook
How do I address HP Compaq nx6125 which board powers and graphics display on monitor all for around 5 seconds and trhen power goes off when turned on.
There can be a second reason of battery problem but I assure you that if you will clean your fan and heat-sink, you will be relax and I think that you will have to replace a new battery to overcome completely on this issue.
Best of Luck
Aug 14, 2012 | HP Compaq nx6125 Notebook
How do i reset bios password on hp nx6125
1) dismantle laptop and remove laptop BIOS battery (as per HP documentation)
2) attach power adapter and power on laptop WITHOUT the battery in place
3) reassemble laptop and enjoy the reset BIOS
May 28, 2011 | HP Compaq Business nx6125 Notebook
Laptop hp compaq tc 4400 is not charging , during adapter connected to laptop and turning power/standby led ... it doesnt switches on, instead battery charging led blinks 4 times, and doesnt turns on, so...
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Apr 16, 2011 | Compaq tc4400 Tablet PC
How to manually discharge the battery as it won't charge
to manually discharge the battery, just consume the remanining battery power on your laptop. Once your battery is empty, press and hold the power button for 8 secs to discharge the battery fully. Wait for 2 hours then charge again your laptop....
Dec 14, 2010 | HP Compaq nx6125 Notebook
When i push the power buton the powerled go on and few secons off again i used the powercord suply and the battery suply. Could i be the power suply I.C wiht best regards Andre
Hi
Try this. Remove Battery. Hold power button for 10 to 20 seconds Insert Battery and switch system on. Let me know if this works
Oct 01, 2010 | HP Compaq nx6125 Notebook
The sd card reader in hp compaq nx6125 is not working
dear it is damaged...please replace....when this message show then memory card is damaged and not readable or not writeable.
Apr 23, 2009 | HP Compaq Business nx6125 Notebook
My Compac Armada M700 does not power up.
Had the same problem with My Compaq M700 No Boot Or Post. Battery Light Flashes 8 Times, Have to Wait 24 to 48 hrs sometimes longer to get Laptop to Start. Tryed the DC Converter Board Change No Difference same Problem. Noticed When Laptop Did Start Clock Time Was always a Little Off 2-4 Hours sometimes more. So Figure CMOS Problem With Time Issues. Read About Battery Memory Transitor Voltage spike Detection Issues Corrected With Newer Bios Flash at HP Supports. So I Flashed Bios With Latest 686h. During the First Boot After Reflash Battery LED Did flash No Start, After pushing the power button again it Started. And has Every since.So Far Laptop Now Boots Everytime and CMOS Checksum Seems To Keep Time Correct In Windows. The Bios Flash Corrects a Voltage Spike Detecting Transistor In The Charging Circuit. During First Start after flash Bios will run system test on the charging system and Correct CMOS. Worked for Me Hope this Helps a Few.
Oct 30, 2006 | Compaq Armada M700 Notebook
HP Compaq nx6125 Notebook Logo
438 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
