Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Windows XP shutdown
I recently built a new computer and installed XP on a 250gb SATA HD. Running AMD X2 5600 with 2gb RAM. XP boots tremendously fast. However, when I try to shutdown by hitting START>TURN OFF COMPUTER there is about a minute delay before the actual shutdown icons appear. Never had this issue before. I checked the processes running at the time and all it shows is 99% Idle during this delay.
  • Craig Nelson Feb 22, 2008
    So what you are telling me is this is a hardware function of my MB and not an issue with XP
    Sergeant:
  • 319 Answers
The computer is just doing it's internal diagnostics before it shuts down. This uses fairly little amount of physical memory. Every computer handles it differently depending on your configuration. If the computer does shut down on it's own....there is no real problem present.
Posted on Feb 22, 2008
  • radarman19 Feb 22, 2008
    exactly....there is no problem with your setup. Shut down times varies from computer to computer....no 2 are exactly the same.
Windows xp does not install
If your hard disk is a SATA disk then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Jan 23, 2013 | AMD Phenom II X2 Processor 560 (3.3 GHz)...
My desktop computer keeps freezing about 3-5 mins into start up with windows 7 ultimate 32 bit. I attempted to install windows 7 pro 64 bit, formatted the hard drive, then started to install and my...
a custom built computer check every connection a computer needs current and data to travel up to and through every device for a computer to work properly
check the cmos battery make sure the seat is cleam this will apply to the ram as well make sure the sockets are clean and they are seated securely
what sort of ide connections are they do you mean molex power connections?
make sure the leads from motherboard to hard drive sata and electrical are securely seated also check all of the connections to drives cd/dvd floppy and usb
hope this helps
Jun 29, 2011 | HP Computers & Internet
On my GT5220-(Athlon X2 64 3800,4G'S RAM)--I HAVE THE STOCK 250GB HDD/IDE THAT IS RUNNING XP-32 BIT,AND I AM TRYING TO ADD 500GB SATA HDD THAT HAS WINDOWS 7 ULTIMATE 32BIT UPGRADED FROM XP VER. EVRYTIME I...
ok get a windows 7 disk and turn of the computer and ad the hard drive switch on the computer and set it to boot from disk (seems windows is broken on the 500gb hdd) then boot from disk and install windows 7 to the 500 gb hard drive and set in the bios the boot select for the hard drive (if you use win xp more then make that boot primary) then go threw all the rigmarol of installing windows 7 to the 500 gb one and your done it will have bootable hard drives and will offer a choice when first switched on
May 15, 2010 | Gateway GT5220 PC Desktop
Appropriate and complete drivers
go to the compaq website and locate your models drivers
Apr 09, 2010 | Compaq Presario Notebook
HD booting in one PC but not in another
Ubuntu works with RAM and CPU Memory instead of a pc like xp that uses Virtual RAM. If the pc that could not load ubuntu doesn't have enough ram to support the reading of the Hard drive and the Operating System then it won't work and Xp will only run on the computer that xp was installed onto the hard drive.
Dec 19, 2009 | Computers & Internet
New build pc no boot... black screen
Try to remove the battery from the MB, and next time you try to install WIN XP, when you are asked how to format your drive, chose quick NTFS formatting; disable floppy drive in BIOS, because it might try to boot from it (and I suppose you don't have one), and in boot sequence (BOOT DEVICE PRIORITY) set cd-dvd as first, and HDD as second, and turn off any other device as bootable
Nov 17, 2009 | ASUS M2N-MX Motherboard
Ms-7061 msi motherboard will not install win xp with sata drive
The problem is that your version of XP does not have SATA drivers and therefore does not recognise your new drive. Vista does. If you Google the problem you will find many solutions on how to rectify the situation. Basically, you have to make a floppy disc with the correct drivers for your Motherboard's hard drive controller. Then, when you launch your Windows XP installer, it will ask you a question about needing to install 3rd party drivers. Yes is your answer. Tap F6 to ensure that the installer doesn't skip.Insert the floppy disc and then after the drivers are loaded, the installation will proceded normally. The other alternative is to leave your existing XP installation in place and add the new disc. Later you can clone your old disc onto the new drive and then remove your original disc.
Feb 11, 2009 | MSI : MS-7061-020 VIAKM400/A&V&L/SATA...
SECOND HARD DRIVE NOT RECOGNIZED
Change the settings of you IDE drives in your BIOS. Set your secondary boot device to HDD1. Also make sure that your primary HDD is set to master and the secondary HDD is slave. The jumper is found at the back of the hard drive where you connect the power and IDE cables. Try this and post back as to how it went..
Nov 11, 2008 | Seagate 250GB Barracuda 7200.10 ATA-100...
Seagate 160GB SATA Hard Drive Installation.
Hi, Was the original 20Gb HD also a SATA or was it installed as an IDE? Try installing a fresh clean Windows rather than the restore disc. However, you will need the drivers for the SATA 160Gb and press F6 when Windows installers ask you to. Post back how things turn up or should you need further information. Hope this be of some idea/help. Good luck and kind regards.
Sep 08, 2007 | Seagate Barracuda 7200.7 160GB 7200rpm...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
95 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
