Question about Acer Computers & Internet
Typing errors when using keyboard. letters missing when typing
    President:
  • 1,216 Answers
these are the basic reasons for this problem
  • if you are using the Wireless Keyboard, then try to change the Batteries. Many times when the Batteries get weak this type of keyboard issues while typing occurs. So try to insert new batteries and check whether the problem is recurring. If it is coming again then it is the Hardware fault.
  • This can also happen because of the Virus. There are some virus or spyware that are the causes of this issue. So I would like to suggest you to scan your system using the updated Anti Virus. Once the Virus gets removed that are causing this issue than problem will get fixed up. Don't forget that your Anti Virus should me latest with proper updates. Simple way to check that your Keyboard is working properly, by connecting to some other system. If the same problem is coming that means there is an Keyboard issue and you will have to change the keyboard. And if your keyboard is working properly on another system that means there is fault in your system. Then try to scan your machine with the Anti Virus. Doing this will exactly know you what was the issue and you can troubleshoot that.
  • if PS2 port was having some issue, that was lead to missed and repeated letters on the keyboard. Hope that you are not having any PS2 issues because then you will have to fix your motherboard.
first you had to identify the cause in your pc by connecting it to other systems and then proceed to fix the cause
REGUARDS
Posted on Feb 08, 2010
I have missing letters and numbers on my Sony Veio laptop keyboard when I type
Keyboard damage? Try a USB keyboard to check it before buying a new one.
Apr 22, 2014 | Sony Computers & Internet
Acer keyboard for ASPIRE 7741Z-4485
Acer may have "said" the keyboard is fine but I wonder how they could determine that over the phone. You may have a defective keyboard
Jun 14, 2013 | Computers & Internet
I can`t get any upper case functions to work on hp 2011 keyboard what key do i press
1.Make sure the "Caps Lock" key is not on. Though this will be obvious to most people, if your keyboard is typing in only upper-case letters it can't hurt to check. Look at the "Caps Lock" indicator light on the top right corner of your HP keyboard. If the light is on, strike the "Caps Lock" key on the left side of your keyboard. This will turn the "Caps Lock" off, allowing you to type in lower case letters again.
2.Make sure the "SHIFT" keys on your HP keyboard are not stuck. Dust and dirt can build up on a keyboard over time, which can cause certain keys to stick. If either of your keyboard's "SHIFT" keys get stuck, your computer will type in only capital letters. Use a toothpick or cotton swab to remove the gunk from the key, which should help it return to its normal position.
3.Unplug your HP keyboard and then plug it back it. This will remove the device from your operating system and then automatically add it back in. This can have the same effect, essentially, as restarting your computer. If your keyboard was typing in capital letters due to an error being stored in your operating system's memory, that error will now be cleared and the HP keyboard will function as normal again.
4.Update your HP keyboard driver. Click "Start" and then right click on "Computer." Click "Properties" and then "Device Manager." Right click on the listing for your keyboard and then click "Update Driver." This will update the computer software that is associated with your HP keyboard. If your keyboard was typing in all capital letters as a result of an error with this driver, the error will now be fixed and you can use your keyboard normally again
Mar 01, 2011 | HP D8597A Keyboard
What is the work of insert key of keyboard.
The insert key is used to toggle between overtype mode and insert mode while typing.
In overtype mode, any letters typed will replace those infront of the cursor.
In insert mode, any letters typed will be inserted where the cursor is. (Useful for if you miss a letter or word out)
Dec 17, 2010 | Microsoft DA900013 Keyboard
Using Acer keyboard and Acer Veriton desktop. Keyboard misses out letters I type and doesn't seem able to keep up with me when I am typing. Hence, trying to do a typing test will result in a decent speed...
Try connecting the keyboard to a different laptop.
If the "lag" and the "missing" letters still occur,
the keyboard is the problem.
If not, try a different keyboard with your computer, to see if this "other" keyboard has the same problem. If so, then your computer, not your keyboard, is the problem.
Sep 24, 2010 | Acer NSK8458AN Keyboard
Keybord misses out random letters
absolutely TAKE IT BACK! why put up with faultry merchandise ? The longer you leave it the harder it wiull be to exchange
Please rfate our help to keep the FREE srevice online++++ Thanks for using FIXYA
Sep 14, 2009 | Dell 0Y3740 Keyboard
Can't type some letters
sounds like either there is something stuck under keys ie (kids toys, food scraps, stuff) or keyboard is bad
Jul 20, 2009 | Logitech 9675020403 Keyboard
Not all keys will operate when pressed once at times
If not of the chord, some dirt under your keyboard tuts or loosening screw.
  1. Try to unplug and plug your keyboard.
  2. Try using Onsceen Keyboard in start/allprograms/accessories/accessibility/onsscreen keyboard. If you use virtual keyboard without error, your real keyboard is your problem. Two way to solve it is
  3. a. Buy a new one
  4. b. Opening your keyboard carefully and try to clean the inside keyboard.
May 09, 2009 | Computers & Internet
TYPING ERRORS
Did you check driver issues?
Oct 17, 2008 | Logitech 967437-0403 Keyboard
Dynex Keyboard
My keyboard misses letters when I type my email
Dec 20, 2007 | Dynex Multimedia Keyboard DX-MKB101
Computers & Internet Logo
300 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
