Question about Saeco Royal Professional Espresso Machine
My saeco royal has ventilate on the screen and is not working. what does this mean?
  • 1,089 Answers
Hi That means the pump needs to be primed by running water through the wand. Push the water. You will hear the pump change tone when it primes and the light or message will disappear. If you have a restriction in the intake line the message will not go away. There is a flow meter inside the machine that measures water flow. If the flow meter does not spin when the pump is running, the computer thinks that the pump is not primed. Coffee grounds will get into the intake and restrict the flow meter. If you get a restriction in the water intake (below the water tank, on the machine) the pump may run and water comes out, but the flow meter does not create the jet of water to spin the turbine wheel to send impulses to the computer. You get the ventilate message. One thing to remember is when you are working on the water system (have the water tank off) do not fill the bean hopper and visa versa. Keep them covered when working on the other. Cross contamination will damage a machine fast
Posted on Feb 08, 2010
Saeco Royal Machine says "ventilate", but when we
Hi
For the Royal Pro there is a button that has a drop sign(water drop) on it. You have to push the drop button to flow water from the steam wand. This should clear the ventilate but if it doesn't check my other tips for "Ventilate"
Aug 02, 2011 | Saeco Royal Professional Espresso Machine
What do you do if the word ventilate appears on the screen?
HI
Ventilate mean to run water through the wand to spin the flow meter.. On some machines you just twist the knob but on higher end machines there is a button on the panel that will dispense water. It depends on your machine.
Jan 21, 2011 | Saeco Royal Digital Plus Coffee...
We have a saeco royale coffee machine that is telling us to ventillate what does this mean and how can we do it
Ventilate means there is an air lock in the hydraulic circuit, to release it run the hot water cycle for a few seconds.
Jun 23, 2010 | Saeco Odea Giro Plus Coffee Maker
Saeco Royal Professional is stuck on "Ventilate"
Hi
There are possibly 2 things that it could be.
1. Check that the tip of the wand is not plugged.
2. Your solenoid valve that controls the water is bad or stuck. That means a trip to the service center.
Apr 17, 2010 | Saeco Royal Professional Espresso Machine
VENTILATE appeared on the screen. machine stoped working?
Try open for steam, it could be that there`s an airbubble inside the fluidsystem. Or maybe check the manual if ypu need to empty the system after using the steam, I know some older models has to be ventilated after the steamprocess.
Jul 07, 2009 | Saeco Royal Cappuccino Espresso Machine
Ventilate!
Can you get water out of the machine by pushing the hot water button?
This is how you would remove the ventilate message in the first place, but if no water comes out then the machines electro-valve is not opening and you will not be able to remove the ventilate message. You will have to get the machine serviced.
I would also give descaling the machine a try before servicing the machine.
You can also find the user manual for the royal professional on our website: http://www.cerinicoffee.com/Saeco_User_manuals_free.asp
We are a Authorized Saeco Service Center based out of New York.
For Saeco Parts and Cleaning supplies visit www.CeriniCoffee.com
May 29, 2008 | Saeco Royal Professional Espresso Machine
New Royal espresso machine
It means you have an airlock in the water system. It can occur when you refill the water tank also.
Quite often you can run the hot water nossle untill the airlock clears. You will hear it splatter and then it should be sweet to go.
Jan 25, 2008 | Saeco Royal Professional Espresso Machine
Saeco royal espresso machine
Ventilate just means that the system has senced a lack of water flow and shut down. Push the button to have water come out the wand and that should reprime the unit. If however no water comes out and the message stays on then you have another problem If water does come out but the message stays on then you have another problem. If in either of these cases you should google "saeco repair" and send it to an authorized saeco repair center to have it fixed.
Aug 26, 2007 | Saeco Royal Professional Espresso Machine
Saeco Royal Professional Espresso Machine Logo
296 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
