Fax machine problems
We ran out of paper during a fax. the moniter reads paper jammed. after paper has been replaced we still can't get the fax to print. I need the fax that is being stored in the memory of the machine!
  • Anonymous Jan 15, 2009
    first said paper jammer and fax in memory i checked the paper and everything its ok and i press start but dont print the fax in
    memory
    Scholar:
  • 159 Answers
I need to know if it still reads "paper jam?" If so, there must either be some piece of paper that is triggering the paper sensor, or the paper sensor actuator has become misaligned.
Posted on Feb 25, 2008
MESSAGE : RECORDING PAPER JAM
Dear
The paper jam is a common problem, you need not to replace to ink cart.
Check the plain paper inserted properly or there is no paper inside, Put power OFF and ON. Also some model needs to press OK or START key to remove the paper jam message after removing the jammed paper.
Thanks.
Mar 06, 2015 | Office Equipment & Supplies
Paper jam
Sir/Mam
The problem mite be dirty rollers that feed the paper, try cleaning with alcohol or worn out replace. Problem is the paper roller is miss feeding not taking up the paper instead of hitting something in the machine paper jam.
Apr 18, 2010 | HP 1010 Plain Paper Inkjet Fax
Brother Intellifax 2920 Error "Unable to Print"
Check the flux capacitor, those usually go out on brother faxes.
I just replaced mine last week, same problem.
Jan 05, 2010 | Brother IntelliFax-2920 Fax
A paper jammed during a fax. i removed it. now,
When you removed the paper jam did the paper tear? mit have left piece of the orgnial document. Also open document feeder where you place the orginal check to see fot any problem. As for the cover does it look like something on the the door is broke, The actuator on the door Slab of plastic , that goes into a slot on the machine to accurate the door close sensor, if the sensor is not activated then the copier thinks the door is open even if it closed
Aug 26, 2009 | Office Equipment & Supplies
Fax will shows a Paper jam but no paper found in machine.
Are the all sensor flappers whole?Or it may be an PCB problem
Jan 26, 2009 | Canon LaserClass 9000L Plain Paper Fax
Machine reads "document jammed"
its the problem of the rollers which pulls the papers they r worn out.I've seen this before repairing computers and asked about fax machines while I am there. There are rollers that cling on to the paper and move it through the machine. When the rollers are worn down they do not grip the paper. For a short fix you can get something rough like sandpaper, brillo pad, etc, and gently scratch the rollers to give them some traction. This will temporarily solve your problem until you can get the rollers replaced.
Jan 07, 2009 | Panasonic KX-FL541 Plain Paper Laser Fax
Jammed paper message
I get a Jammed paper message on the read out, I have cleaned out all the paper and pressed stop/cancel button but it still keeps saying that there is a paper jammed in it.
May 04, 2008 | Samsung SF-330 Plain Paper Inkjet Fax
Unplug the device from the AC power for about 30 minutes to allow it to reset the circuity.
Hope this helps.
UX A460 Paper Jam during fax reception how do I prinmt from the memory
open the machine and clear the paper jam and then closed.The machine will start printing again.
Oct 17, 2007 | Sharp UX 108 Roll paper Thermal Fax
83 people viewed this question
jasbo
jasbo
