Question about MSI Wind U100-030US Laptop
Battery won't charge
My netbook won't charge the battery. could it be the battery or is something amiss with the computer?
  • MSI Master
  • 12,061 Answers
Even the batteries have chips in them as such, well they can fail in the blink of any eye and for no apparent good reason. This is a hard problem as the only way to tell is to get another battery, also you must check your Power Supply is working. If it doesn't charge the new battery then your charging circuit is broken, inside the PC.
Posted on Feb 08, 2010
2 Suggested Answers
SOURCE: Netbook charging indicator light won't light
If the battery won't charge and the laptop won't turn on but the ac adapter works with other laptops, then the problem is the port where you plugin the ac adapter. Some of the laptops has it built in to the motherboard. So you might need to have it repaired by a technician. Or if the laptop is still in warranty, you might need to send it to the manufacturer to have it repaired or replaced. But if the laptop works without the battery, or it will turn on but the battery indicator is not lighting up, you're facing one of these problems.
1. The battery itself is dead. 2. the battery bay is loose 3. the battery itself is loose
Hope this helps...
Posted on Sep 15, 2011
Hp mini 110 netbook battery won't charge
If it says battery not detected then you need a new battery that one is done.
Jan 03, 2013 | Computers & Internet
Samsung N145 Plus battery charge failure
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 03, 2012 | Samsung Computers & Internet
Sony Vaio P Series Netbook shows its charging but stills stays at 1percent availabe almost 3hours
Aug 12, 2012 | Sony VAIO VGN-CR205E/P Notebook
My acer netbook batteries will not charge. Any suggestions?
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Nov 08, 2011 | Acer Aspire One D255-2670
Battery is fully charged, but netbook won't turn on unless plugged in.
I would say that you definitely need to purchase a new netbook battery. If it's only turning on when plugged in, then the battery itself doesn't have any more charge cycles.
Oct 10, 2011 | HP Mini 1033CL Netbook
My Asus Eee PC battery light flashes orange all the time. The battery does not charge. What does this mean.
Well it simply means that youre battery needs replacing. Youre netbook can detect it if it flashes on youre indicator and the power is actually going in youre battery but it simply won't charge because it has passed its usable life.
Sep 24, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Netbook charging indicator light won't light and battery won't charge. AC adapter works on other computers
Hope this helps...
Sep 15, 2011 | Gateway LT2021u Netbook
Netbook is dead, won't operate on AC power,is the adaptor dead?
A good chance the ac is bad, try getting another one, the battery may be bad as well, or the charging port on the computer may be bad as well.
Aug 10, 2011 | Gateway LT2021u Netbook
My MSI U100 Netbook won't charge. I purchased a new battery, and it still won't charge. So the battery was not the issue. Can the the AC power cord go bad as well and I should replace it? Or is...
Yes the AC Cord does go bad , you can also look at the power jack at the back of the Laptop to see if it is loose when you plug it in. I always start with the plug they are usually cheaper than a battery.
Nov 01, 2017 | MSI Wind U100-030US Laptop
MSI Wind U100-030US Laptop Logo
1,414 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
