Question about Refrigerators
Samsung fridge freezing the contents
My Samsung fridge occasionally freezes the contents of the fridge (the freezer works fine). What is the cause; is it easily fixable or do I need a technician?
Thanks, Shimon.
  • 4,793 Answers
Is ther much frost in the fridge?if so, defrost (no hot water)
if not just turn down the thermostat to no 2. on scale of 1-5 poss cause... ambient air temp change from summer to winter i.e. turn it up in summer down in winter....
Posted on Feb 08, 2010
On my Hotpoint FFA90 fridge freezer occasional leaks occur at the bottom of the freezer where ice accumulates. The fridge section above is fine. Any suggestions?
There is one in the freezer section as well. It's a small white tube. I've had the same thing happen with mine. I just took everything out of the freezer, and used hot water. It's caused by condensation buildup in the drain tube, which then freezes, obviously because it is a freezer after all. Hot water usually does the trick. Just be sure to clean it up, and dry it off really well so it doesn't re-freeze and cause the same issue.
Aug 26, 2016 | Hotpoint FFA90 Bottom Freezer Refrigerator
Fridge section keeps freezing up.
Hi,I had trubble with my fridge so done a bit of reserch the main reason for the fride freesing up is,
fridge not set at right temp (3 to 7 c ) or vent where water drains blocked,shelves not in right place as in manuel,and if you put veg that has alot of mosture content can also course freezing at the bottom of the fridge,hope this was some help,maybe buy a fermomiter to test.
Jul 03, 2016 | Refrigerators
My Samsung RL39WBMS fridge on m fridge freezer keeps freezing food. Why is this happening all the time and how can I prevent it?
maybe the fridge is set on a colder setting and if that's not it then stick it on the lower shelves and that might help from not freezing because are fridge is the same way when it is stuck by the coolant fan
Nov 02, 2014 | Refrigerators
Freezer is causing fridge contents to freeze..... cont.
Do you see any ice buildup on the back wall of the freezer?
Oct 21, 2012 | Maytag PTB1954GR Top Freezer Refrigerator
THE FRIDGE PART OF MY FRIDGE FREEZER ,FREEZES ITS CONTENTS.IT IS A HOOVER FRIDGE FREEZER MODEL NO.HNMF2805A-80
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 26, 2011 | Hoover Refrigerators
Freezer temp turned down but still freezing everying
just look for a better fan to buy to prevent the compressor from having problem . thanks.
Feb 15, 2010 | Freezers
Freezer not Freezing
the air flow is blocked betwen fridge and frezer or even the small fan is burnt out
Jun 22, 2009 | Magic Chef CTF2125 Top Freezer...
Samsung RB215BSSB refrigerator freezes up
I had a similar problem where my evaporator coil was freezing into a block of ice, which caused my fridge to warm up due to a lack of air flow. I fixed this by doing a few things. I replaced the circuit board ($100) which was easy to do. Unfortunately, this didn't fix my problem so I took the inner fridge cover off to view the evaporator/heater coil assembly. I checked my thermo fuse and found it to be open (failed). I ordered the thermo fuse and the thermistor and replaced them both. I then plugged the fridge back up and put a regular thermometer inside the fridge to get an accurate reading of inside temp. A few days now and everything looks good. The board, fuse, and thermistor were all pretty easy to replace.
Apr 09, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Fridge of Fridge/Freezer keeps freezing contents.
all the food going to ice temperture at 2
Oct 24, 2007 | Refrigerators
Refrigerators Logo
168 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
