Question about Electrolux Washing Machines
Hi, I need help my front loader washing machine ewf1481 stopped at spin during a cycle. I turned off machine and tried to set on spin only but only I could only hear a humming sound and the circuit board goes from displaying draining to spin. Nothing is happening. I also tried to start another full cycle but the same thing happened. My husband cleaned the pump/filter, checked the hose didn't have a blockage but no success. It just sounds like the the motor is churning. Is there anything else we can try or do you know what the problem might be?
  • kayel30 Feb 09, 2010
    Thanks for your help. Unfortunately after doing all suggested still not working. Will now contact Electrolux. Thanks again.
  • Electrolux Master
  • 19,396 Answers
Hi.
It is the drain system. What you are experiencing is a drain problem. The machine won't advance to spin until the drain problem is fixed.
The first thing to do is accessing the drain pump hose and emptying water in there.
You will need to disconnect power, either unplugging power cord, or tripping circuit breaker. Then open the door located on the front right hand side , below the door. In there unscrew the hose cap, and be ready to collect the water that will flow with a big container.
The procedure is also illustrated on the owners manual.
If that does not fix the problem, or if there is no blockage in there and no water is flowing, then the problem is either a faulty drain pump, or a bad pressure switch, that is the device that is used to detect water , and decide when to stop drain pump.
If there is a fault, then parts must be tested. In that case I would suggest contacting Electrolux at the number listed on the owners manual, to get a technician at home.
Regards.
Posted on Feb 08, 2010
The door on LG front loader washing machine won’t unlock
hi Margaret.
If the washing machine malfunctions or you need to stop the cycle and retrieve the clothing, you can force the door to unlock.
  • Open the door after the "Door Lock" indicator turns off. ...
  • Press the "On/Off" button, if the washer is not already on.
  • Select the "Spin Speed" button to turn on the Drain & Speed cycle.
  • or go to this link and have a read up.
LG front loader washing machine wont unlock Google Search
Dec 12, 2017 | LG Washing Machines
Simpson esprite 650 front loader washing machine. Electricity trips on programs b & h wash, can't complete cycle. Spinning and draining cycles OK. Why ? thanks sally
Hi Sally.Now in your posting you mentioned the machine trips the safety switch during the main wash.Is this correct?Does it trip as soon as the barrel stars to turn or a little later.Could you explain what b& h wash is.If the machine spins and drains and fills but trips during the cycle then from working on this model of machine I think the fault is your heating element.Have you tried a cold wash without any temp setting?Please reply with additional information on the questions and I am sure I can help you.Looking forward to your reply.
Sep 12, 2010 | Washing Machines
Front loader washing machine is not draining
Hi Is this a whirlpool? Sounds like something is in the pump or the pump is bad.
Get me model # and I can help you further. Thaks
Vic
May 16, 2009 | Washing Machines
During spin cycle washer spins fine but toward the end of the cycle it spins out of control like it is out of balance? Any help is greatly welcomed.
Some front loaders have a super high speed at the end of the spin. Front loaders don't like small loads, the laundry does not spread out evenly enough for a balanced spin.
May 08, 2009 | Frigidaire ATF6000ES Front Load Washer
Maytag washer/front end loader
HI...mine has just started dong the very same thing. I unplugged it to reset the computer and tried
just the 'spin' setting....still...the water is still in the machine....not sure what to do. I thought a blockage too.
abby
Sep 08, 2008 | Maytag MAH6500 Neptune Front Loading...
AWM8121 Drain/Spin cycle stops
it seems to point to blockage in drainage pipe from drum likely to be a lost sock remove pipe and check
Jul 05, 2008 | Whirlpool AWM6120 Front Load Washer
Danby washing machine noisy only during spin cycle
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Jan 13, 2008 | Danby DWM99W Top Load Washer
Whirlpool washer front loader model LHW0050PQ
This is not a Malber machine but the following fix has worked for the Malber washer. Try unplugging the machine for at least 2 minutes. Do not just turn it off as there is still current going to the machine .This should clear the computer. If this does not work, the imbalance may have overloaded the circuit board requiring replacement.
Nov 15, 2007 | Malber WD1000 Front Load Washer/Dryer
Indesit wg1130t front loader washing machine
maybe the drive belt is off/broken. Take the back off to check
Oct 09, 2007 | Indesit W 123 Front Load Washer
Kenmore elite front loader washing machine
has the fuse blown, if so replace this to ge the machine up and working to start with, set to drain only if you have the option, if the machine empties then the door may open, if its set to spin and the electric trips then there is a motor fault,, not much information given but now you have somewhere to start from
Sep 23, 2007 | Hotpoint WD52 Front Load Washer / Dryer
Washing Machines Logo
61 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
