Question about Car Audio & Video
How do I locate the audio fuse on a Ford Galaxy?
How do I locate the audio fuse on a Ford Galaxy TDI?
I have Ford Galaxy 2010 Tdi, and the indicator on my dashboard does not flash on one side when a use the control stalk. I have checked the fuses, condition of the fuse box, and looked at the wiring.
Hi, Sound like a wire has come loose behind the dashboard, requires taking the dashboard out very carefully & re-solder the cable back one there are lots of wires behind the dashboard so if you don't think you can do this take to a vehicle electrics place or person. Hope this helps give me feedback please. Thanks, Malcolm Campbell.
Sep 03, 2017 | Ford Cars & Trucks
Where is the fuse located for the sidelights..
I think what you need to locate the fuse box is located at the website in the link provided.
Ford Galaxy Gaining Access to Central Junction Box Fuses Relays Mk2...
Hope this helps
Feb 05, 2016 | 2011 Ford Galaxy 2.0
How to remove a cat from a mk3 galaxy 2006 tdci
it probably is not a bolt on cat but one that is welded into the pipe . they do not want us fixing this stuff anymore seems like
Sep 23, 2015 | 2006 Ford Galaxy TDI
How do I locate the horn fuse box on 2007 a ford galaxy
Ford Galaxy? Or Ford Galaxie? I thought they quit making those in the 1970's. My first car was a '66 Galaxie 500.
Mar 02, 2015 | Ford Cars & Trucks
Is there a fuse for the fuel gauge on a galaxy 2001 tdi?
no fuel sending unit is inside the ghas tank
Apr 19, 2010 | 2001 Ford Focus
1986 galaxy 1900 tdi wipers working washers not fuses ok relay?
check for power at the pump when someone pushes the switch if it has power pull the hose off and blow if you cant replace the hoses if it is clear replace the pump
Feb 01, 2010 | 1978 Ford Granada
Ord galaxy 1998 tdi 110 radiator over heating but
you need to flush the radiator out.
With the engine cold, remove coolant bottle cap to release pressure.
Drain engine coolant from drain plug on radiator.
With the drain plug removed disconnect the highest hose connected to a radiator.
use an hosepipe and put it in place of the disconnected radiator pipe.
turn on the water to the hose pipe and let it flush out any sludge accumulated in the radiator. after a few minutes turn off water supply, reconnect radiator hose and drain plug and refil using recommended coolant mix for your galaxy (purchased at most autofactors and garages).
Also check your thermostat as if this is faulty it would stop the flow of coolant running around your engine.
hope this helps
Dec 11, 2009 | 1998 Ford Club
Heater problems ford galaxy.
replace the heater core. its leaking
Jan 22, 2009 | 1996 Ford Taurus
Car Audio & Video Logo
378 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
