Question about Konica Minolta magicolor 2300DL Laser Printer
Minolta 2300DL Magicolor printer
Despite changing all of the toners, the message window on our printer is still telling us that the Cyan, Magenta, and Yellow toner are empty, and will not allow the printer to leave the change toner message. These are brand new toner drums, this problem has been an ongoing issue however it seems to be getting worse and we have found no way to fix it, HELP.
  • geraldhemel Apr 08, 2008
    We have the exact same problem, but we don't refill the toners we buy new one's Can someone give me a anser?
    I'm trying to clean the printerinside.
  • samjacwalk Sep 02, 2008
    We are having the same problem. It just started out of the blue-- with no warning. 1st it said Change Yellow Toner. Now it's all Toners except black even after not being able to print anything. I know that Cartidge are not empty--as we do not print that much color. I tried changing all the cartridges with ones from another 2300 that I have but the printer didnt acknowledge the change. I purchased new ones and plan on installing those tonight. But this is not cost effective, if the used ones are not low. What's is this all about? Can this problem be resolved by simply cleaning the inside of the printer?. Do I need a new or updated driver? Thanks, SWalker.
    Problem Solver:
  • 7 Answers
EAch cartridge has a small ( about 1/4 inch square) stainless steel color metal tab at the end of the cartridge opposite the refill cap end. The surface of this little tab is visible when the cartridge is "low" on toner and this causes the machine to give the message to change the cartridge. As the cartridge gets older I've noticed that this tab moves to the exposed position more readily, which causes the message to appear. If you google how to reset the position of this tab, then the message will not appear. EVerytime I refill the toner of a cartridge I check to make sure to reset the position of this little metal tab.
It is difficult to describe how to reset the position of the tab. You have to stick a small regular screw driver into the slot below where the metal tab appears and find the lever which can be pushed to reset the position of the tab. You can likely find photos of this procedure on google.
Posted on Sep 28, 2008
They are chipped...if you refilled them you will need a new chip
Posted on Feb 27, 2008
Message states i unit low/ just replaced black i unit, which unit is it requesting
Will tell you CMYK
cyan yellow magenta and black or the toner is low for the black
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 16, 2014 | Konica Minolta magicolor 4750EN Laser...
Magicolor 3730DN toner not installed
I had something similar happen with a Magenta cartridge. My only option was to call Minolta. After hours on the phone they finally agreed to replace the faulty cartridge.
I suspect that from time to tame we receive a cartridge with a faulty chip.
Aug 21, 2012 | Konica Minolta magicolor 3730DN Color...
Keep Getting Error Message "(Colour) Toner Not Installed"
I think in the menu you have to select replace cartride.. then new or same with new toner...
each toner cartridge has connections and you must make sure all are tight... or you get alot of errors.
Sep 10, 2008 | Konica Minolta magicolor 2300DL Laser...
I have replaced the toner but am still getting the replace toner message.
My message error was sepcific for magenta after I removed it to refill it. After refilling, cleaning metal contact points, resetting the metal tab which prevents message of "low toner", I put the cartridge back in and received the "magenta toner not installed" message. I turned off the printer (safety first!) , I then pushed the button left of the hole where you slide the cartridge in, There is a squarish hole with a circular or cynlinder shaped button in that squarish hole. Use a small screw driver to push and hold it in. While the button is held in I gently rotated the cartridges so that my magenta cartridge was no longer in view, (rotate them counter clockwise). I released the button, shut the door, then turned on the printer.
Sep 09, 2008 | Konica Minolta magicolor 2300DL Laser...
Problem Magicolor 2300DL
How do I rotate drum to access and remove the black toner? Printer ends with the Cyan toner, but I need to replace the black cart.
Feb 06, 2008 | Konica Minolta magicolor 2300DL Laser...
Cartridge Removal 2300DL QMS Minolta
magicolor 2300 DL procedures
a)From the display, select the menu “Engine”.
b)Select “Replace Toner”.
c) Select each color toner cartridge from this
menu to remove it.
Nov 26, 2007 | Konica Minolta magicolor 2300DL Laser...
How do i change a black cartridge ona Magicolor 2300DL? The black toner is shown as empty but the menu only allows me the options of changing one of the color cartridges. Black is not mentioned
Black is listed as K. CMY (Cyan Magenta Yellow) K (Black)
Easiest way ids to open the fron door, remove the toner bottle and poke a screwdriver in the small round hole near the toner opening. This will free the carousel so you can move it to whatever colour you want to remove.
Sep 04, 2007 | Konica Minolta magicolor 2300DL Laser...
Konica minolta error
I had the same problem and found that one of the toner cartridges must have not been seated properly. I removed the black toner cartridge and re-fitted it. The printer now works fine again with no errors. 17H is a code relating to a fault in the rotation ......... possibly one or more toner cartridges need checking. Use the menu on the printer to turn it to the appropriate position (i.e. engine menu then select replacement of whichever toner you are checking).
Hope this fixes your as well.
Chris
Aug 27, 2007 | Konica Minolta magicolor 2300DL Laser...
Minolta CMS magicolor printer 2300W
there should be a light flashing on the printer. try pressing the button nearest to it to see if that will move the print head out in order that you can replace the cartridge
Jul 18, 2007 | HP Printer Cartridges (Complete List): ,...
Toner problems
A couple of suggestions. 1. make sure there is not any plastic shipping tabs that need to be removed from the cartridge. 2. try reseating the cartridge. 3. Try replacing that cyan cartridge. It may be defective. Also make sure you use Minolta brand toners!
Apr 07, 2007 | Konica Minolta magicolor 2300DL Laser...
Konica Minolta magicolor 2300DL Laser Printer Logo
500 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
