Question about Apple iPod nano
Its not holding a charge and when connected to the computer it says do not disconnect and thats all it does i hold center and menu button down it resets and then goes right back to do not discon. sign
    President:
  • 1,871 Answers
Your battery is dead [ Lifetime is ended ] . It will never be recharged again .
Have new one .
good luck .
Posted on Feb 08, 2010
HOW TO UNLOK THE A1136 IPOD
click start control panel scroll to folder options tick in the box to show hidden files and holders
connect your Ipod to your computer
click start click click on you Ipod to open
then go Ipod controls device there should be a folder saying locked
right click select rename to open or delete the folder your Ipod should now be open
or you might do a factory reset
The iPod A1136 is the fifth generation iPod from Apple that uses a click wheel to scroll through your device's media library, and may occasionally lock up when you attempt to play a song or display a photo.
This error error occurs when the hard disk is unable to access the information and stalls while opening a file.
A reset of the device usually corrects the problem, as it clears the device's memory and any errors.
Check your iPod's buttons to determine if the cause is due to a hardware error before resetting the device, as the problem may be due to the iPod's hold switch.
Slide the hold switch at the top of the iPod to the right, and slide it back to the left to ensure the switch is in the off position.
Hold down the center button in the click wheel, and at the same time hold down "Menu" on the click wheel.
Continue to hold the iPod's buttons until the device's screen shuts off, turns back on and shows the Apple logo.
Plug the iPod's connector cable into the dock connector on the bottom of the iPod.
Plug the other end of the cable into your computer's USB or FireWire port to charge the iPod.
Wait at least two hours for the iPod to charge. Launch iTunes on the computer, and click "Controls" of the iTunes menu.
Click "Eject iPod" in the sub-menu to disconnect the device.
The iPod takes four hours to completely charge its battery.
hope this helps
Oct 18, 2012 | Apple iPod MA446LL/A MP3 Player
Tip
To get your 4GB iPod Nano to be recognized by your computer
I found the solution to this problem:
To get your iPod Nano 3rd Generation (4GB video) to be recognized by your computer, you will need to manually get it into "Disk Mode" here's how:
  1. Verify that it has a full charge, if not, you need to either charge the iPod before continuing or connect it to a high-powered USB port, or simply connect it to the Power Adapter that plugs into an electrical outlet. (just not connected to your computer)
  2. Toggle the Hold switch on and off once. (Set it to Hold, and then turn it off again. Just slide back and forth.)
  3. Press and hold the Menu and Select (center) buttons at the same time for at least 6 seconds until the Apple logo appears.
  4. When the Apple logo appears, release the Menu and Select (center) buttons and immediately press and hold the Select (center) and the Play/Pause buttons until the ‘Disk Mode’ screen appears.
  5. Disconnect your iPod from the power adapter and connect it to your computer;
  6. Now the screen on the iPod will change and say "Do not disconnect" and should be recognized by your computer.
I hope this helps you; I had a hard time finding a solution and thought I'd share the wealth once my stress was relieved.
on Sep 11, 2009 | Apple iPod nano
Froozen and wont do ANYTHING
  1. Toggle the Hold switch. To do this, slide the switch to Hold (an orange bar appears) and then slide it back (orange bar is hidden).
  2. Reset the iPod by holding down the Menu and Center buttons for 10 seconds.
    • If the Apple logo appears on the display, connect the iPod to a computer and verify that it appears in iTunes and can play music. If the iPod appears in iTunes and can play music, no further troubleshooting is needed.
    • If the Apple logo does not appear or the iPod is not seen in iTunes, connect the iPod to a power source by either plugging it into an Apple iPod USB Power Adapter or directly into a computer's USB port.
  3. Let the iPod charge for at least 20 minutes. Note: If the iPod is connected to a computer, make sure the computer does not sleep, standby, or hibernate during the 20-minute charging period.
  4. After the iPod has charged for at least 20 minutes and while it is still connected to the power source, toggle the Hold switch again as in step 1.
  5. Try resetting the iPod by holding down the Menu and Center buttons for 10 seconds.
    • If the Apple logo does not appear or the iPod is not seen in iTunes, try putting the iPod into disk mode and restoring.
  6. Try putting the iPod into disk mode.
    • While in disk mode, connect the iPod to iTunes and try to restore.
    • If the iPod is still not recognized by iTunes, the iPod should be serviced.
    • utting iPods with a Click Wheel into disk mode
      1. Before placing the iPod into disk mode, you should verify that it is charged.
      2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
      3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
      4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.ht1363_2.jpg
      5. Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
      If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
      If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
Jun 05, 2010 | Apple iPod nano
My SANSA e260 froze up. I can't shut it off. Has a blank screen was trying to charge it.
Make sure the player is fully charged. 1. Connect the player to your computer. 2. Make sure the computer detects the player. NOTE: If needed, switch the player to MSC mode, 1. Turn device OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC. Next Be sure the battery is charged 1. Leave the player connected for approximately 2 hours to charge. 2. Disconnect the player from the PC. 3. Verify if you can turn on the player. 4. Reset the player if necessary. To reset the player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player. If that does not do it, re-seat the battery: Then try and see if it will come on with out the battery hooked to your computer, which I see you have done but did you change modes MSC to MTP . next delete the song it keeps hanging on and re-copy it back on to the player from a different folder or re-rip it from the CD and copy it into a new folder then re-copy to the player.
Feb 03, 2010 | SanDisk Sansa e260 MP3 Player
It froze up
  • 1. Connect the player to your computer.
  • 2. Make sure the computer detects the player.
  • 1. Turn device OFF.
  • 2. Slide the Hold switch down to Lock (orange color showing).
  • 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC. Next Be sure the battery is charged
  • 1. Leave the player connected for approximately 2 hours to charge.
  • 2. Disconnect the player from the PC.
  • 3. Verify if you can turn on the player.
  • 4. Reset the player if necessary. To reset the player:
  • 1. Press and hold the Power/Menu button for approximately 20 seconds.
  • 2. Release the Power/Menu button.
  • 3. Press the Power/Menu button again to turn on the player.
If that does not do it, re-seat the battery: Or try and see if it will come on with out the battery but hooked to your computer.
Feb 02, 2010 | SanDisk Sansa e260 MP3 Player
Mp3 player froze when plugged into pc. screen is blank but lit. is charged. what do i do?
If that does not do it, re-seat the battery: Then try and see if it will come on with out the battery but hooked to your computer.
Feb 02, 2010 | SanDisk Sansa e250 MP3 Player
I charged my ipod from the computer and i disconnected it and now the ipod is stuck
if its frozen and no moving just hold menu and center ok button and wait till reset
Nov 12, 2009 | Apple iPod MA446LL/A MP3 Player
Ipod nano 4gb will not connect to my pc
Jul 11, 2009 | Apple iPod nano
Ipod nano trouble
just keep on clicking it. hold the center button and menu button at same time. flick hold swith on and off
Jan 28, 2008 | Audio Players & Recorders
Hour glass frozen on screen
hold the "menu" button & the "center" button together for about 6 seconds & let it restart
Mar 29, 2007 | Apple iPod nano
Apple iPod nano Logo
67 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
