Question about Samsung Computers & Internet
My samsung r60plus laptop keeps overheating and shutting down.how can i fix this
  • Samsung Master
  • 32,281 Answers
This problem is caused by a faulty cooling system. The fan is probably faulty and or the heat-sink assembly is clogged with dust.
Failure to correct this problem will cause the CPU to fail.
Check the fan to see if it spins freely, if not replace the fan. Also check the heat-sink assembly/fan and remove the dust clogging these components.
If this does not fix the problem and the laptop has vents on the bottom of the laptop, then you can purchase a fan assisted cooling pad. Place the laptop on this pad and this will provide addition cooling to the laptop.
Posted on Feb 08, 2010
Whenever I play a video on my laptop it shuts down after a few minutes?
Many laptops don't cool as well as they should - try elevating the rear of the laptop - heavy video usage could be causing the shutdown.
How to Fix Overheating and Shutting Down Laptop
Feb 18, 2015 | Computers & Internet
My Lenovo ideapad z370 keeps shutting down and booting up for no reason?
dude .,, its due to overheating caused by busted heat sink... maybe you should replace it to fix this thing...
Jan 02, 2013 | Lenovo Computers & Internet
Need a dvd-rom/rw driver for my laptop samsung r60plus win7
Usually they are plyg n play. If it don't work go to syetm and rollover driver. If it doesn't you could have a bad DVD player.
May 28, 2011 | Samsung Computers & Internet
I have a ACER 5735 . The laptop shuts down suddenly while its on and sometimes im not able to switch on the laptop and even if i switch on , then once again the power goes off immediately . What would be...
The reason for the sudden shut down of your computer is because of overheating of the 'case', where the CPU is mounted. Overheating can be due to dust accumulation on the heat sink, which prevents dissipation of heat. The possible solution to combat overheating issue is to keep the laptop dust free by cleaning out debris at the vents frequently. Note that a laptop has a much smaller cooling area in comparison with desktops and hence laptops tend to accumulate dust a lot quicker than desktops. This is because all the dust/debris, in the case of laptops, accumulate in the cooling fins.
Get more information to fix Acer shut down issue :
http://supportforacer.iyogi.com/aspire/shut-down-2.html
Hope this information helps you.
Aug 28, 2010 | Computers & Internet
L have a Samsung R60plus which keeps turning off
Go to the Contol Panel, select System and Maintenance, select Power Options, select (both) to make changes: Computer Sleep, and Power button. I hope this Fix it
Jan 21, 2010 | Computers & Internet
My laptop keeps shutting down at random times. I
Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage.
If the smart person keeps turning the notebook back on and figures out a way to foil the protection, the laptop is probably doomed. Once a laptop shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot.
The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated laptop is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down.
Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning.
Good luck
Oct 03, 2009 | Toshiba Satellite A100-S8111TD Notebook
Shuts down
Hi..
If the laptop shutdown maybe it cause overheating.
Laptop shuts down? Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage. If the smart person keeps turning the notebook back on and figures out a way to foil the protection, the laptop is probably doomed. Once a laptop shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot. The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated laptop is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down. Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning.
Good luck !!!
Regards
PCmania
Jul 15, 2009 | HP Compaq Presario V6000T Notebook
Samsung r60plus laptop
ctl alt del not functioning why?
Mar 03, 2008 | Samsung Computers & Internet
Laptop shutting down
A quick fix is to blow back into the vents to blow dust out.
May need to dismantle though and clean fan and maybe even remove heatsink and renew thermal paste.
Jan 06, 2008 | Computers & Internet
Computers & Internet Logo
1,305 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
