Question about VeriFone (M19755014US1) Magnetic Card Reader
POS IP isn't configured correctly with model Omni 5150
We were using software that was installed normally on previous versions of VX510 but after using new versions from vx510 we got error : ATIIP?..
4 Suggested Answers
  • 42 Answers
SOURCE: troubleshooting verifone vx510le defaulting back to system mode menu 1
You need password reset software to access the sysmode menu1,
psoftware109@gmail.com
Posted on Aug 24, 2012
  • 113 Answers
SOURCE: my verifone vx510 won't print
Receipt Feeds,
But Nothing Is
Printed On It Not using thermal paper. Ensure thermal paper is being used. Thermal paper loaded upside down. Ensure thermal paper is being fed from underneath the roll, as it will only print on one side of the paper.
Posted on Sep 06, 2012
  • 113 Answers
SOURCE: I have a VeriFone Omni
If the printer does not work properly:
• Check battery status or terminal power connection. The printer will not print if
there is an insufficient charge remaining in the battery to complete the print
operation. (For Vx610 terminals only.)
• Check if the printer is out of paper and that the roll is properly installed. Open
the paper roll cover and install a new roll of printer paper or ensure that the roll
is feeding from the bottom.
• Verify that the printer roller and paper roll dust cover are properly installed.
• If the problem persists, contact 775-358-2922 hope this help : - )
Posted on Dec 03, 2012
Need to set a VeriFone Vx510 to Dial Primary from the start.
Verifone programming is different between countries and even between versions. In New Zealand the setting for internet or dial comms is in UTILITY/COMM CHANNEL. It will have a setting for IP, or DIAL, or IP/DIAL if using both where it will try internet and then use the dial if the internet is down.
Jan 18, 2014 | VeriFone VX510
I need a VeriFone Vx510 to start with Dial Primary first.
Using AVAYA IPO 500 R6 V2 IN 1616 and 1608
Check the IPO software is installed correctly and see if the most up to date software is installed, current software version 6.1 for this model.
Uninstall previous version or current version. Then Reinstall the newest version.(6.1)
Should take of any problems you are having with the phone. Since you have replaced it once, the problem lies in the software not hardware.
Mar 16, 2011 | Avaya 1616 IP Phone
Can verifone vx510 (Omni 3730 work on a digital line?
It's really hit or miss. Some days they will work, some days they will not. You will only really run into a problem when your doing downloads or batching the terminal out. You will sometimes have problems running cards, but make sure you hit the reports key if you get a disconnect to make sure the transaction didn't go through already before running the card again.
Sep 18, 2010 | VeriFone VX510
I have 5 used Verifone Omni 3730 vx510 terminals that I would like to sell on Ebay. How do I remove all my bank information from them and reset them?
At the sales screen hit F2 & F4 together password is 1 Alpha Alpha 66831.
Then hit the button under the arrow on the left of the screen one time.
choose flash files the clear all files password again same as above.
Then clear Ram files clear all files and confirm and then you are on easy street.
www.greenlightpayments.com
Jul 23, 2009 | VeriFone VX510
How do i use high speed internet on Vx510
To use high speed on a Vx510, you need to have a unit that has a high speed connector. Early version of that box do not have the physical connector for a high speed line. If it has a connector, it will be under the back of the unit.
Second of all, your application software has to have the options for using high speed. You need to contact your processor's support line to find out if you have to simply set some options or get a new load of the software.
Apr 06, 2009 | VeriFone Omni 3700
Verifone vx510 showing "no master key"
it message show in the pinpad or in the point of sale??? if it is in the pinpad you must re-enteder the master key number into a pinpad.
Mar 15, 2009 | VeriFone Omni 3700
I have verifone vx510
GO ON LINE
VERIFONE OMNI 3700 SERVICE MANUAL
OR
VERFONE VX510 SERVICE MANUAL DRIVERS
ENTER
OR
VERFONE 3700 VX510 FLASHING LIGHTS
ENTER
ROD
Feb 10, 2009 | VeriFone Omni 3700
Verifone VX510 Terminal
If you cant use analog lines then you have a problem..What you need to do it replace the comm equip. to a DUAL COMM with IP services.. That should fix your issue
Jan 04, 2009 | VeriFone Omni 3700
VeriFone (M19755014US1) Magnetic Card Reader Logo
480 people viewed this question
Top VeriFone Televison & Video Experts
AliennoisE
Andrew Taylor
Andrew Taylor
Are you a VeriFone Televison and Video Expert? Answer questions, earn points and help others
