Question about Sony DAV-SC5 System
DVD stuck inside sony dav-sc5. Pressed the eject button and nothing happened. Did the usual turn it off and on again and it started to read the disk but then nothing happened. Tried to eject it and nothing happened just kept flashing eject. The DVD is due back today at Blockbusters and is still stuck!
  • clairrhill Feb 08, 2010
    I have turned the whole thing off whilst i am at work today so will try again this evening when i get home - i guess if it doesnt work i will have to try and take the thing apart?
    President:
  • 788 Answers
Have you tried to unplug the unit for 1 or 2 minutes to see if it can reset the computer chip inside of the DVD player?
I have had great sucess with this trick.
I hope that this helps you out of this situation.
asnowman
Posted on Feb 08, 2010
  • John Snow
    John Snow Feb 08, 2010
    If my suggestion does not work then please reply to this post and I will try to help you further to eject the DVD without damaging it. I work nights, but I will check in once in a while.
    Best of luck, and I hope you have a good day at work.
    asnowman
  • 4,234 Answers
When you attempt to eject the disk, listen carefully, do you hear a motor running at all? If so, then the load belt is slippnig. Increased force is required to release the disk from the clamper assembly which clamps the disk to the motor table. If hte belt has dried up a bit, it will slip and not release the disk. This is a relatively inexpensive repair that only requires replacing the loading belt.
Dan
Lost remote
check the following links for you answer
http://www.ebay.co.uk/itm/Replacement-Remote-Control-For-Sony-DAV-SC5-/271034128605?pt=UK_AudioTVElectronics_Video_RemoteControls&hash=item3f1ae498dd
http://www.ebay.co.uk/itm/Universal-Remote-Control-to-DVD-SONY-DAV-SC5-easy-to-use-TV-/110829587705?pt=UK_AudioTVElectronics_Video_RemoteControls&hash=item19cdf54cf9
http://www.ebay.co.uk/sch/i.html?_trksid=p5360.m570.l1313&_nkw=Sony+DAV-SC5&_sacat=0&_from=R40
if this does not help then no matter what you can always get a new one from SONY
ALSO PS*** check in your owners manual for info on how to program your new remote to work with your system
if you no longer have owners manual then follow this link
http://www.manualslib.com/manual/247682/Sony-Dav-Sc5-Instruction-Operation-Manual.html
Oct 20, 2012 | Sony DAV-SC5 System
Sony DAV-SC5 not playing 5.1 through the optical input from sky/blu ray
The DAV supports Dolby Digital® DTS 5.1 audio. Make sure your blueray movie has 5.1 track and is outputting to the DAV.
Jan 26, 2008 | Sony DAV-SC5 System
My dvd player is stuck on one dvd and wont let me eject, change disc, or even stop the current dvd. display reads "locked" whenever i press any buttons. can only turn on and off the device.
Hi, For some reason the disk will not play. You push the eject button over and over again, but the disk slot will not open. Here's one solution...
* 1 Turn off the DVD player. Wait a few minutes, turn the DVD player back on, and
then press the "eject" button. If this does not work, turn it off and unplug
the DVD player...while you keep pushing EJECT button plug the DVD and turn it on (your hand still on the eject..) is should come out..
* 2 ..if it does not eject , unplug the DVD player again, Remove the screws off DVD on the sides and take off the DVD casing.
* 3 Look for the DVD holder inside the DVD player. This device holds the DVD in
place while the DVD player reads the disk.
* 4 Push the stuck DVD disk toward the front of the DVD player until the DVD
ejects. Remember the DVD player is not on and some force ( gentle ! ) must be applied.
* 5 While it is open,plug it on and place a DVD disc just to see if mechanism works properly..
* 6 Replace the casing and the screws. Plug the player in and turn it on. Put
another DVD in to test whether the player is finally working ..
Hope this helps!..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
Jul 09, 2011 | Televison & Video
Sony, Compact AV System DAV-SC5 DVD says ready, but Can't play
My player was working fine till today. When any DVD is inserted it say "PROTECTED" and won't proceed further ! what could be the problem?
Aug 18, 2009 | Sony DAV-SC5 System
Sony 5 disc dvd player says c 31 00
C31 usually means a motor error. In your case, it sounds more like the loading sequence is not completing. Can you please confirm that the model is the DAV-FX10 system?
Thanks,
Dan
Mar 02, 2009 | Sony DAV-FX10 System
Sony dav dz100 won't eject dvd
Press standby button to turn on the set, select dvd function then press and hold STOP and EJECT button for five seconds or more to UNLOCK cd slot. You will see UNLOCK in display.
Jan 02, 2009 | Sony DAV-DZ100 System
How to connect other dvd or HDMI player into dav-sc5 for amblification
If your alternate DVD player has digital audio out you can make this connection via the 'optical digital in' port on the rear of the unit which corresponds to the Video 2 function. I have done this myself because the inbuilt DVD function in the Sony unit is dead (fixed once under warranty, problem recurred about a year later, same issue as other unsolved posts on this board, DVD function hangs, system won't switch off, etc. common problem with this unit, crap product).
Oct 18, 2007 | Sony DAV-SC5 System
DVD Function Not Working
Help me!
Dav sc5 problema:dvd player no pictures scart and rca out,but have sound(rca out)
Sep 17, 2007 | Sony DAV-SC5 System
Sony DAV SC5 Home Theatre System - NO picture only sound when DVD / VCD played
Have you set the tv type (PAL/NTSC/Multi..) or the component type (RGB, YUV, etc.) suitable for your tv? If not, go to the main menu of your Home Theater System then check it out.
Apr 19, 2007 | Sony DAV-SC5 System
Sony DAV-SC5 Home Theatre System problem playing CD-RW's
Hello, your home theatre system is from the year 2003. Maybe a cleaning the optical can solve the problem. There are cleaning CD kits on the market, but better option is if a pro does it (the cleaning) for you. If you need more assistance please advice. Arpi
Mar 22, 2007 | Sony DAV-SC5 System
Sony DAV-SC5 System Logo
496 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
