Question about Garden
Chain stops under load. adjustment is o.k. sounds like it's slipping but resumes turning when not cutting.
  • dontbother10
    dontbother10 May 11, 2010
    How old is your saw? It sounds as though the clutch faces are abraded. A model number would be helpful (RY7400numberletter?) perhaps.
  • Kelly
    Kelly May 11, 2010
    Make and model number please. It sounds like the "Flying clutch" pads are worn substantially on your chain saw. If you provide a make and model number I can probably provide part numbers for you. Thanks for using Fixya
    President:
  • 2,220 Answers
No reply to clarification.
Posted on Feb 16, 2010
Starts but stops under load
Use sharp Chain. If saw has changed climates since previous use, adjust carburetor to accommodate the change, ensure proper fuel mix ratio, check spark plug, and if you still have problem inspect / replace piston rings.
Sep 21, 2014 | Poulan Garden
Chainsaw runs fine but the blade slows down to stop when i cut
too much load (too large a cut), dull chain, no lubrication oil on chain, slipping clutch.. lots of reasons.. need more information and you need to check all the points I mentioned. The clutch is RPM dependant- once the RPM drops- the clutch will start to slip. Look for oil or grease on clutch shoes also
Aug 01, 2014 | Garden
How to adjusted the high and low in a ryobi rcs3535c4
The initial hi and low jet settings are in the owner's manual or sometimes stamped on the side cover next to the carburetor. If you do not have a manual go to lawnandgarden.manualsonline.com to get one.
Oct 04, 2013 | Garden
My Homelite ZR10926 16-Inch 33cc Ranger it is starting, idling, it dies when I accelerate it. I assume is the carburetor, maybe ? thank you.
It probably is not getting enough fuel. Check the filter in the tank. If it has been sitting with stale gass this filter plugs up.
Try running the engine with some choke. If this helps, try adjusting the carburetor high speed screw.
Jun 04, 2011 | Homelite ZR10926 16 Chain Saw
Manual chain hoist keeps slipping load chain when under load (lifting and lowering). It will hold when you keep tension on the slack side of load chain. Any ideas?
sounds if the motor brake is not holding , this is a wear part and will require adjustment/replacement over its life time , the brake is located under the motor cover , but if your not sure what to adjust ,then im gonna suggest for safetys of you and the people around it' s sake you get a profesional to service this hoist
Aug 19, 2010 | Jet Equipment Chain Hoist 1TON 10 Ft Lift...
Chain slips
Your problem statement seems to be chopped off, but apparently, when you go to cut something, the chain just stops turning. Assuming that is so, remove the bar and chain, then wash out the interior of the clutch mechanism with spray carburetor cleaner. Let dry and re-assemble the bar and chain. Make sure the chain is being properly oiled by running the saw at speed with bar tip near some cardboard--it should leave thin line of oil after several moments. Make sure the chain teeth cut toward you on the bottom run of chain. Hope this helps!
Jul 07, 2010 | Husqvarna 18" 502cc Prosumer Chain Saw ...
Starts, idles and runs but quits after a few seconds of cutting
Check the air cleaner and muffler for plugging. One screw adjusts the idle stop (idle speed) position and the H and L jet screws set fuel mixture for high speed and idle speed mixture respectively. Turn both jet screws CW to stops (lightly) then back each out CCW 1-1/2 turns. This is a basic setting and should allow the engine to start and run. Start the engine and allow to warm up. Pull the throttle full on and adjust H CW until the engine starts to speed up, but 4-strokes. Correct adjustment is when the engine 4--strokes running free, but immediately 2-strokes when cutting. Release the throttle and adjust L needle CW until the engine idles fairly well, but allows the engine to 'follow the throttle'. Adjust the idle speed screw so that the chain stops turning, but the engine will continue to run. Hope this helps!
May 17, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
My chain sounds like it keeps slipping
It is not slipping unless your sprockets are SHOT.
There should be about 3/4 inch play in the center bottom of your chain when the bike has a normal load on it (read YOU).
Now then, your clutch could be slipping ... have you adjusted it?
I hope this helps you
a
Oct 12, 2009 | Yamaha G5 Motorcycles
Chain stops under load ms 660 stihl
your centrifical clutch need to be replaced there is no adjustment,I hope this helps you?
Oct 01, 2009 | Garden
When i use the electric saw and put a load on the chain it stops
The problem you have isnt adequately explained.
  1. You may be tripping a thermal overload.
  2. The chain may be to agressive and overpower the motor.
  3. The chain may be excessively tight, that combined with the load may be the cause.
  4. Limbs as the cut progresses, pinch the bar and chain.
  5. No bar oil or defective oiler.
  6. If equipped with a clutch it may be slipping.
There are other causal factors too. Read your manual, limbs require 2 cuts, the first from the bottom about ½ way through, then offset a couple of inches toward the trunk from the top . HTH
Lou
Sep 24, 2009 | Remington Polesaw Wizard
Garden Logo
43 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
