Question about Sony VAIO VGN-SZ320P/B Notebook
Fn key doesn't work - Sony VAIO VGN-SZ320P/B Notebook
    Problem Solver:
  • 7 Answers
Hi do driver update
Posted on Feb 08, 2010
2 Suggested Answers
  • 497 Answers
SOURCE: fn key
Try installing the "Sony Shared Library" and the "Sony Notebook Control Device Drive".
First install the Sony Shared Library, restart the Computer and then install the "Sony Notebook Control Device Driver" (restart the Computer again).
NOTE: Sony Shared Library is the system component which makes the download and installation of Drivers and Applications compatible with the Computer. While "Sony Notebook Control Device Drive" is utility which will enable the Function keys in the Computer.
Check this Link to download these Utilities.
http://esupport.sony.com/US/perl/swu-list.pl?mdl=PCGFRV27
The Sony Shared Library will be listed under "System Components - 1 file(s)" and Sony Notebook Control Device Driver will be under "Notebook Control and Utilities - 1 file(s)".
Good Luck!!!!!!!!!!!!!!
Posted on Nov 18, 2009
Testimonial: "thanks for your guide"
My function keys doesn't work in my laptop toshiba satellite c660-a047
The function key, labeled "Fn" and located in the lower-left corner of your keyboard, is a useful feature. By pressing "Fn" along with one of the numbered function keys at the top of the keyboard (F1 through F12), you can adjust your screen brightness, enable and disable your touchpad or wireless modem, lock your computer and complete a variety of other tasks. These keys will not work if the "Fn" key is not pressed along with them. While the "Fn" key itself does not turn on and off, there are settings that can make it behave differently, or seem to be disabled.
Click "Start," then "All programs" or "Programs," then "Toshiba." Select "Utilities," then "Accessibility." Place a checkmark in the box to make sure the "Fn" key will work whether you press it simultaneously with the F1 through F12 keys or immediately before pressing those keys. Customize the other options on the screen, then click "OK." Test your "Fn" key. One of the easiest ways to do this is by pressing "Fn" and "Esc" at the same time. This toggles the sound on your computer on and off, and will show a speaker icon on your screen if it works. Press "Fn" and "Num lock" at the same time if the "Fn" key still does not work. Use the "F11" key if your laptop has no "Num Lock" key. Test the "Fn" key again, using the same method as in Step 4. Locate a licensed repair technician if the key still is not working. A hardware issue may be at fault. Hope this helps.
Jan 09, 2013 | Toshiba satellite c660
The fn keys dont work in my asus except for the fn+f7 one. when i press fn+f2 the led light goes on and off but it doesn't seem to work??? what should i do??
Hook a external keyboard to the laptop, if all functions checkout. The keyboard in the laptop will need to be replaced..
Mar 30, 2012 | ASUS Computers & Internet
Lenove ku-0989 fn key
  1. Numerous folks indicate that Windows doesn't register the Fn key as a keypress but using a tool that gives the ASCII value of a keypress I see the Fn key returning FF (perhaps FF in this case means 'not registered'). I also see that keys like Ctrl register with one ASCII code when pressed alone and another when pressed in combo with another key. Fn will only register when pressed alone, so Windows definitely isn't seeing the combo. This took a solution like AutoHotKey off the table.
  2. I ran KeyTweak (which shows you the hardware scan codes of a keypress and the Fn key registerd as 57443). Using this program I remapped Fn to the Ctrl key; this worked perfectly. However, I suspect that because of the issue in #1, the combo of, for example, Fn + C did not execute a copy.
Nov 22, 2011 | Lenovo Keyboard
Tuchpad doesn't work on my vaio VGN-NW17GJ
There is Fn key that is used to enable or disable the touch-pad
It changes from laptop brand to other,
Try Fn + F6 ( A symbol on the F-key indicates the proper function key.
Please tell us your results.
Good Luck
Sep 09, 2011 | Computers & Internet
My computer laptop model is Toshiba satellite P750. The FN key doesn't work. Nothing happen when i touch it.
The "Fn" key is a function key, it works with the top row of F1 to F12 keys.
By pressing and holding down the "Fn" key, then pressing one of the top
row "F" keys,
I'v provided a link for you to go to for the full list of "F" functions and what they
do for you as well as how to operate them on your Toshiba Laptop.
http://www.ehow.com/list_5941452_laptop-keyboard-functions.html
Aug 27, 2011 | Computers & Internet
How do I activate the wireless if fn + f9 doesn't work when pressed at the same time?
Hi
can u please try to hold the FN key And press The F9 key once and wait a couple of seconds
Aug 18, 2011 | Samsung R519-53S Notebook
Hello\ my\ keyfboard\ is\ messijng5\ up.\ (as\ you\ ca\ see)\ it\ types\ extra\ keys\ wh6ejn\ i\ just\ hit\ one.\ i\ h6it\ NMLK and\ FN'-SCRLK...please\ h6elp
Maybe you've activated the number lock in the letter keys, try to push another time Fn+NumLock or (try) to tell us the model of the notebook; if that combination doesn't work check the color of "Fn"on the key and search for a block num symbol on the others keys, then push both together.
Aug 05, 2011 | IBM ThinkPad R51 Notebook
Hi I have just bought an Acer Aspire Z5710 all-in-one PC. I find the screen too bright when working for long, and want to adjust the brightness. But i am not able to figure out how to do so. And there...
http://support.acer.com/acerpanam/Manuals/acer/2011/ServiceGuides/SG_Aspire_Z5700_Z5710_20100907.pdf
If the keyboard doesn't have a Fn key often the Scroll Lock key is used, try Scr Lk + Down arrow to dim the display.
The manual indicates and Fn Key to the right of the Left Alt Key but that doesn't mean you have that keyboard eitther
Jun 30, 2011 | Computers & Internet
I have a Satellite L505LS5014 and my fn key is not working. Please help.
If the Fn key is not working you can try to clean out under the key with a compressed air can. If that doesn't help the only way to clean the key and get it working again is to take off the keyboard and clean the mechanism directly.
Apr 11, 2011 | Toshiba Satellite L505LS5014...
There is no on screen display for Fn keys
The Fn keys are usually used with other keys for different functions. Like it is used with the up arrow key to increase the brightness of your display. Fn alone doesn show up anything.
If you meant that Fn key along with other keys dint work, then reinstall your keyboard driver. This might help.
~regards,
Jegan
May 09, 2009 | IBM ThinkPad T30 2366 Notebook
Sony VAIO VGN-SZ320P/B Notebook Logo
281 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
