Question about Kenmore 62602 Electric Dryer
Timer Does not Move
Solution #2 posted on Feb 22, 2008
Harli1960
Rank: Apprentice
Rating: 0%, 0 votes
I have a kenmore dryer. I purchased it brand new from sears in August 2001. I have noticed about 3 weeks ago when I went to dry my clothes that the timer does not move. The dryer still heats up, it takes a little longer to dry but it still works. Can you tell me what may be wrong with it. I am wondering if the repair would be cheaper or should I invest in another dryer!
  • 36 Answers
FIRST CHECK YOUR VENT IS CLEANED OUT THEN SEE IF TIMER MOVES WHEN PUT TO A TIMED CYCLE. IF SO MEANS VENT CLOGGED UP. IF STILL NOT MOVING MEANS TIMER CONTROL BAD. COST ABOUT 80-100 FOR PART. YOU COULD DO YOURSELF IF SOMEWHAT HANDI.
COULD BE ORDERED FROM SEARS PARTS DIRECT BY YOU.
OTHER WISE CALL SERVICER AND MAY COST 200.00 TO REPAIR. HOPE THIS HELPS
Posted on Feb 22, 2008
What do you have to do to become a Wiz in FixYa? I am new and have put in 41 solutions but am still at Master status. When will I be a Wiz and how long until I am a premium expert?
Rank Average Rating Minimum Number of
Solutions Posted guru.gif Guru 85% or higher, 5 votes minimum. 50 wizard.gif Wiz 80% or higher, 5 votes minimum. 30 master.gif Master No Ratings Required 10 expert.gif Guide No Ratings Required 5 nonexpert.gif Apprentice No Ratings Required Rank Average Rating Minimum Number of
Solutions Posted guru.gif Guru 85% or higher, 5 votes minimum. 50 wizard.gif Wiz 80% or higher, 5 votes minimum. 30 master.gif Master No Ratings Required 10 expert.gif Guide No Ratings Required 5 nonexpert.gif Apprentice No Ratings Required You need to visit the Expert FAQ's section to get answers to this, link is http://www.fixya.com/FAQexp.aspx
but here is an extract:
Ranks are calculated by dividing the total value of the ratings cast on an Expert's Solutions by the Expert's number of rated Solutions. Unrated Solutions, Premium ratings, and Live Chat ratings are not factored into Experts' averages.
Wizz needs 80% or higher ranking, 5 votes minumum and 30 solutions minimum.
The help screens are good so just have a look around and you'll find out lots.
Aug 22, 2011 | FixYa Service
Just installed bosch exxcel and light on saying check water. Water is switched on there is no kink in pipe - help please
noavatar_s.gif Nzimpofu
Rank: Apprentice
Rating: 100%, 1 votes
Have been struggling with the same problem. Tipping the machine backwards worked. Many thanks.
Was this helpful? Yes No2 people thought this was helpful
noavatar_s.gif klaudiatombo
Rank: Apprentice
Rating: 100%, 2 votes
I solved the problem, by tipping the dishwasher back about 45degrees, I think this re-adjusted the flood sensor, and it is now working fine. Thank you
Jan 26, 2010 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
New codes 5401 eurovox codes
noavatar_s.gif rarebhird
Rank:nonexpert_s.gif Apprentice
Rating: 97%, 28 votes
new euro-vox codes 07/05/09
5a 01
aa, b7, d1, d9, ce, 8e, 83, af
8e, 80,d7, ef, 44, These codes seem to work
May 10, 2009 | Televison & Video
All my DRC8335 vcr-video system says is hello
X This Problem has been added to the Share Your Expertise Page under "My Work Queue". OK Solution #1 posted on Feb 22, 2009 Asker's Rating 0%20stars_w.png
noavatar_s.gif dvickery926
Rating: 0%, 0 votes
Thanks to the help on this forum, I was able to fix my DRC8335 power supply. C226 was the problem, went to Radio Shack and found the 470uf 35V replacement. It came up and worked like a charm after soldering it in. (See the picture of the cap on the board). It was just slightly swollen when viewed from the top but when i removed it, the bottom was really distorted. Thanks to micro065 and Mike Powellebbca66.jpg
Comment posted on Feb 22, 2009 Thanks to Mike Adams not Powell, sorry. Mike Adams is a FixYa Expert.
May 02, 2009 | RCA DRC8335
CD PLAYER
You may want to reference this solution posted to my problem by rpgnzls: Try removing the radio fuse & wait a while. It should reset when plugging the fuse back in. Hope this helps!!
Solution #1 posted on Mar 19, 2009 Asker's Rating 0%20stars_w.png noavatar_s.gif
rpgnzls
Rating: 0%, 0 votes
Mar 19, 2009 | 2004 Lincoln Aviator
How to change the date and time on this machine Panafax Uf 880?
Now this solution isn't mine, I found it here and we can't even credit the poster since they were signed on as 'Guest' only:
Guest
Rating: 0%, 0 votes
1) select function #7
2) select #1
3) select "set"
4) enter the new date and time (MMDDYYY) (1500 - 3:00 PM) 5) select "set" and stop
Oct 31, 2008 | Panasonic Panafax UF-880 Plain Paper Laser...
Nokia 2630
call the custumercare or reach the service centre for help.
Oct 31, 2008 | Nokia 6300 Cellular Phone
Technical support
slappa71
Rating: 0%, 0 votes
you need to remove the blades and strip it to the bottom of d/w under blades and check if it is blocked. if ok undo drain pipe and blow to check if blocked. good luck SLAPPER
Jun 25, 2008 | Kenmore Dishwashers
Kennmore elite
just pop your model number in this site and look op your parts, problably $100 in parts, shocks easily replaced , they just twist and lock in place, and the pump is just 2 clamps and a screw. be sure to check the pump to tub hose for clocgs as well as your drain hose for restrictions
http://www.searspartsdirect.com/partsdirect/index.action?pop=flush
Apr 14, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 110 45862404
noavatar_s.png marklfixit
Rating: 0%, 0 votes
Replace the front bellow or front seal, as it may be called. It is an inner tube shaped rubber liner that seals between the front of the washer door and the front of the drum. The cost is about $35.00-$40.00 and you will need the kit as it includes the rubber spacers that are essential to doing the job. The job takes about 1 1/2 hours to complete. It is not hard, but it is dedious and requires some basic skills. Directions included in the kit are helpful.
Jan 24, 2008 | Frigidaire GLEH1642DS Front Load Stacked...
Kenmore 62602 Electric Dryer Logo
176 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
