Question about Samsung RS2630WW Side by Side Refrigerator
The freezer side of our Samsung SR-2026CVW is unable to hold a steady temperature, and some times the temperature rises to 0. Unpluging the mains for a few moments seems to cure the problem for a short while. Sometimes this occurs every day, sometimes once every few weeks. Thanks.
  • 4,793 Answers
You do not say how full/empty you keep the freezer.
pad out empty spaces with any spare foam (stops air movement when you open door) could be faulty temp sensor...or auto defrost sensor .......rare.
Posted on Feb 08, 2010
Refrigerator temperature does not hold temperature and comes on 59 degrees. Freezer side holding 0.
you need a repairman to check the coolant it might need recharged .freezer should be below 0 like -15
Apr 15, 2016 | Samsung RS2630SH Side by Side Refrigerator
The freezer is fine steady at 0, but the refrigerator temperature keeps rising currently at 67 degrees.
Check the freezer make sure you do not have frost build up. Defrost problems choke out the air flow and if it happens the refrigerator will not cool.
Sep 15, 2015 | Frigidaire FGHS2342LF Gallery 22.6 Cu. Ft....
Why is it beeping?
if temperature is rising, you will get a beep. you need to find why the temp rising. Clean condenser coils and make sure that condenser motor is running art full speed.
Sep 01, 2015 | Samsung RS275AC Refrigerator
Hi. I own an older Samsung SR-S2028CSS fridge/freezer. The temperature control setting and ice mode selection buttons were ineffective and the fridge and freezer had increased in temperature, but...
blank display with segment flashing is a fault code samsung appliances use this method for displaying faults ...
samsung fridge freezer trouble shooting videos are available on youtube ..
have alook at this video and see if its the same segment that you have
Jan 20, 2011 | Samsung RS2534 Side by Side Refrigerator
About every two or three weeks the temperature rises to about 15 F in the freezer. Temperature also rises in the main part.
Defrost timer/control board is sticking...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 30, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
How do i change my auto tranny oil on 1991 subaru
THere is a dran plug on the left side of the tranmission oil pan. These transmission hold alot of oil and it could be very hot, so be careful. You need to change the filter too and these are quite expensive. When re-filling
I Use care not to exceed the upper limit level.
I ATF level varies with temperature. Remember
that the addition of fluid to the upper limit
mark when the transmission is cold will result
in the overfilling of fluid.
4) Fluid temperature rising speed
I By idling the engine
Time for temperature rise to 60°C (140°F) with
atmospheric temperature of 0°C (32°F): More than
25 minutes
<Reference>
Time for temperature rise to 30°C (86°F) with
atmospheric temperature of 0°C (32°F): Approx. 8
minutes
I By running the vehicle
10 minutes
5) Method for checking fluid level upon delivery or
at periodic inspection
Check fluid level after a warm-up run of approx. 10
minutes. During the warm-up period, the automatic
transmission functions can also be checked.
From my Subaru TSB's
Mar 31, 2010 | 1991 Subaru Loyale
Temperature 0 The digital display switches from normal 5 to 0. Resetting works occasionally
There is likely no problem. The temperature inside a freezer will charge incrementally during the day as the refrigerator goes through various cycles. For example, during the defrost cycle, the freezer temperature will rise significantly due to the heat from the evaporator heater. This temperature rise is temporary and should not cause a problem.
Oct 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Fridge freezer samsung model no sr-s2028cvw
fridge side should only be around 36 to 40 degrees freezer side around 0 to10 below
Apr 13, 2008 | Refrigerators
SAMSUNG SIDE BY SIDE FRIDGE FREEZER
these appliances are a pain in the butt. fault with water dispensor is oprob that the water bottle at bottom of fridge is frozen. rise in temp is prob that defrost not taking place. not a diy unless you are experienced
Mar 14, 2007 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2630WW Side by Side Refrigerator Logo
261 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
