Question about Fujitsu Heating & Cooling
Water is dripping inside the house from the aircondtioner. this happens while we try and use it.it is a reverced cycle aircon and heater
  • 1,420 Answers
Your condensation drain could be plugged. Find out where it drains to and using a wet vac, vacuum out the drain tube.
Posted on Feb 09, 2010
I have a Kenmore he5 steam dryer that is dripping water out of the steam nozzle on the inside of the drum. This happens on any drying cycle and causes clothes to not dry. How do I fix this?
Does it drip just when the unit is operating or do you find water in the machine when it is not running? Try shutting the water off to the dryer and see if the dripping stops. If it does the water inlet valve needs to be replaced.
Feb 12, 2016 | Kenmore Dryers
Hi I HOPE SOMEONE CAN HELP I HAVE AN AUDI A4 1.9TDI AVANT ON A 2000 X PLATE IN THE PASSENGER FOOTWELL UNDER THE DASH IT IS DRIPPING WATER INTO THE FOOTWELL ANY IDEAS? REGArds..
If your car has a sunroof, one if the sunroof drains runs down through windshield post down through to bottom of the car. If it gets plugged it will back up into car. If it's coolant you're finding (sticky and smelling like coolant) your heater core is leaking
Apr 04, 2011 | 2000 Audi A4
My split system R/cycle air con is dripping water drops from the inside unit.
hi,
If this happens just recently, most probably the cause of dripping is that there is something that blocks and restricts the condensate line and it causes the water to overflow and drips.
Try to check the line if it is free from any obstruction.
Hope this help you.
Don't forget to rate me. Thanks...
Regards,
John
Jan 12, 2011 | Heating & Cooling
Water leaking out of hose on a fujitysu split system ast24rga
Normally, an Air Conditioner removes water from the air and that water condenses on the coils of the inside section that does the cooling. The water condenses on the cooling coils just like moisture condenses on the outside of a glass of ice water.
This excess water drains out of the cooling section through a "drip tube" and is supposed to drain outside of the house, or a drainage system. Your "drip tube" has either not been installed (if it is a brand new installation), has separated and water is now dripping into the house instead of outside of it. Or it is clogged. This happens when algae builds up inside the "drip pan". If that is the case, you can purchase "algaecide" tablets which kill the algae that is clogging the drip pan and preventing water from draining out through the drip tube. These tablets can be found in many hardware stores, refrigeration supply companies, or even Walmart. You can put a tablet inside the pan. (You will have to remove the cover of the unit). You can often use a little bit of Bleach and that will act as an algaecide. Hope this helps,
Best, Mark
Dec 26, 2010 | Fujitsu Heating & Cooling
What could be wrong with my aircon unit? Water dripping sound
Your coils need cleaned, and change the filter too. make sure drain is not cloged also.
Jul 04, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Kelvinator aircon is dripping water from air vent in house
Sounds as if unit is freezing over----typically a response to lack of proper ventilation-----check all filters and access panels to unit and clear or clean as needed-----if unit has a drip pan make sure unit has been positioned properly so as to catch excess......properly ventilating unit should resolve issue though
Jan 15, 2010 | Heating & Cooling
Ford Fiesta 2003 1.3 If I run the aircon water leaks onto the floor of the drivers side (by the pedals, alot of water.
In the dashboard,set down low is a driptray.It collects water that comes off the aircon.It has a hose (sometimes 2) that drains the water out of the car via the firewall so it drips onto the road.This is blocked or the tray has a buildup of gunk.The hose is about 1/2 inch thick.If you lay on the floor where it leaks with a torch you should find it.Or look in the engine bay,just to the left or right of centre(which side leaks?)and backtrace it into the car.You may find the inside hose has fallen off allowing the water to drip inside.Hope this helps you
Jan 01, 2010 | 2007 Ford F
WATER LEAKING FROM MY SPLIT TYPE LG AIRCON
1. Do not set the aircon too low temperature in overcast weather, this will cause ice ups and water dripping. Optimal comfort zone temperature is 24c.
2. You need to open the grill cover on the front of the aircon which unclips either end left and right with a finger pressure. You will find two filters which can slide out and should be cleaned. First tap them together to remove dust, then you can wash them with mild soap and cold water.
3. There is the third possibility that an insect has made a nest in the drainpipe. You should look on the outside of the building and locate a plastic drainpipe. You can either blow into this pipe with your mouth or get a blower. This will unblock any restriction in the drainpipe.
Goodluck and ratemeplease.
Mar 19, 2009 | LG LSC121PMA Split System Air Conditioner
My window air is leaking on the inside of my house
usually because the drain hole/duct/tube, on the outside is blocked, or the aircon is mounted leaning Into the house, condesate that is supposed to drip into the outer casing and run out the hole is funneled over the lowest point of the casing, the house side.
check and unblock the drain,
and ensure the aircon is mounted tilted back.
Aug 02, 2008 | Haier hwr10xc6 Air Conditioner
Heating & Cooling Logo
184 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
