Question about Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV
I have a Sony Grand Wega 55in LCD projection TV, that was turned on and copped a power spike. The TV now takes ages to turn on and then the whole screen is covered with narrow multi-coloured vertical lines, the remote will only turn the power on and off, the audio is ok but all the video is obscured behind the lines. The TV is an American model running through a transformer, to drop voltage from 240 to 110. Cheers
SOURCE: SONY GRAND WEGA KDF-60WF655 - VERTICAL LINES
check standby power supply caps (elec. type probably swollen) after that then it's the q box
Posted on Jun 29, 2008
electronick
  • 505 Answers
SOURCE: 6 red blinks wont turn on sony rear lcd projection
thermal fuse. it sits below the lamp and has popped. replace with new fuse or just short (eliminating fire protection) let me know if you need instructions.
Posted on Dec 09, 2008
  • 179 Answers
SOURCE: 60 inch Sony Grand Wega
no, it is not the lamp,the DIC 2 board is bad.in this case it is best to have a sony certified technician come out to give you an estimate. the board is expensive and the lvds cables attached to it are verrrry
fragile and expensive also.
Posted on Feb 06, 2009
  • 1619 Answers
SOURCE: SONY GRAND WEGA TURNS PICTURE DISPLAY ON AND OFF
bulb is dirty remove and clean if it persists replace bulb.
Posted on Jul 09, 2009
  • 556 Answers
SOURCE: Sony Grand Wega 60 inch LCD Projection TV goes dark.
most likely, buy you a lamp and install it yourself, the owners manual tells you how to do this.
Posted on Sep 11, 2009
55' sony grand wega will not turn on. The green light blinks 5 times and then red light blinks 6 times. red light cycles 6 times again. What is the problem? Can I fix it myself?
power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Take care.....
Dec 07, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony LCD Grand Wega 55in keeps turning off then on. It is on for about 1-2minutes before it turns off again - then automaticly turns on. The red light at the bottom of the TV never turns on - the green...
Have you ever tried to clean the air intake filter that sits behind your speaker grill. Have you ever replaced your lamp before either?
Blessings,
A/V Media Tech Guy
Dec 19, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Problem for Sony Grand WEGA KF-42SX300 42 in. LCD TV Only goes from red to amber on led
hello try a factory reset. turn on the tv while holding the reset button on the remote control, press the power button on the tv, the tv will turn itself off and back on again release the reset button
shaun
Nov 02, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
Is it okay to hook up my playstation system to my projection tv?
It's OK as long as the picture keeps moving. Besides, that is for projection televisions not for LCD or DLP's
You should be fine.
I hope that this helps.
asnowman
Oct 01, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
My Sony LCD projection TV - not turning on easily
The flashing is a diagnostic code that should be listed in the owner's manual. It may indicate a lamp failure or fan failure. Check there. If you can not find the manual, please post here what light(s) is/are flashing and I'll look it up.
Thanks,
Dan
Sep 14, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
My sony grand wega lcd tv does not have a picture when turned on. the power/standbylight flashes constantly but the lamp does not come on
How old is this TV? Did you replaced its lamp?
Symptom shows TV needs new lamp as existing lamp is weak and unable to provide back light.
Thanks.
Sep 12, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
Bluing at bottom of picture.
take away if there was any speaker near the tv Unit. you need to demagnetize the screen using a magnet or demagnetizer.
Jun 13, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
