Question about Gateway 960 Series (gtwy960) Server
Constant beeping My Gateway 960 Server just started beeping. It continues to function, but the beeping is annoying, and indicates a problem, but what? When I shut the machine down, the beeping stops. When I start it again, the bootup process gets about halfway and starts beeping again, and finishes the bootup and goes into Windows 2000 Server and seems to work fine. What does the beeping mean? Please help!
  • NormJ4 Feb 22, 2008
    Thanks for the info, Nitrotrike. I'll give it a look.
  • Anonymous Mar 13, 2014
    my server is continuously giving a beep sound as soon it is started.i have already once shut down and restarted the system but the problem continues
  • 589 Answers
I would first check that all the fans are turning when you first power it up. It may have fan speed sensors on them, and one or more fans aren't coming up to speed. I would check the CPU fan(s), as they are usually smaller, and tend to go bad before the other larger ones.
Posted on Feb 22, 2008
Server beeps continuously can not read monitor ,keyboard
you should start by re-seating the RAM first as this is a common problem. if that does not work re-seat the processor. If all that fails remove all add on cards and memory only leaving the processor and see if the beep codes change. Replace the components one-by-one to find the problem piece of hardware. HERE is a guide from Dell to tell you what the beep codes mean and also some troubleshooting tips.
May 08, 2012 | Dell PowerEdge 2500 Server
System up and running and getting a constant beeping.
Clean Dust inside the server & update with latest bios ,room temperature should be 18 degree Celsius
Dec 28, 2011 | HP ProLiant ML370 G4 Server
I tried to upgrade my 614GE Gateway from 512 Mb to 2 Gb, the system indicates I only have 960 Mb, I orded another set and now the system will not turn on, I swaped the old and new now I have 1.43 Gb, what...
First make sure you have the right modules (DDR 1 or 2 and the speed 400mhz or something similar).
Then when you insert the new modules, does the computer beep?
Of not then you ok, if it gives you al log beep there is a memory error.
And if you have a integrated GPU it takes some memory for its own use.
Or maybe the computer cannot handle 2GB.
Hope this helps!
Mar 01, 2011 | Gateway 614GE PC Desktop
When I turn on my Gateway M-series I get a long loud series of beeps. once the windows loading screen comes up they stop how do i get the beeps to stop
Beeps usually indicate a problem with your hardware memory chips or keyboards or other items that are not functioning properly. I suggest if it is still under warranty send it back if not take it to a good shop for repair. Or try reinstalling the original software I would do this first. Most likely it is a memory module the way to test this is remove one of the chips and try starting the computer. If this continues place the one you removed back in the computer then pull the other one if it boots you have found your memory module that is bad if this is the issue, make sure that you have everything plugged in. John
Jan 15, 2011 | Gateway M-6834 Notebook
System Fault indicator light on in a Gateway 975 Rackmount Server
If it is on steady and green, the server is operating normally.
If it is on steady and orange, the server is "in a critical or unrecoverable condition"
This is according ro the manual located at http://support.gateway.com/s/Manuals/Servers/8510289.pdf
If it is orange, for further diagnostics, you should see POST error codes, or hear relevant audible beep-code patterns, which can be interpreted by checking the tables in the PDF Server manual linked above. (Pages 125 and 128 respectively.)
If it's green, of course, you dont have a problem.
Feb 19, 2010 | Gateway 975 Rackmount (gtwy975) Server
Does not bootup and top light on power supply is blinking
Replaced the Gateway Power Supply, 450W.RDNT and the Gateway Power Distribution Board, 960/980 Servers. When the top light is blinking on the power supply, there is a power problem.
Mar 18, 2009 | Gateway 960 Series (gtwy960) Server
Trying ti upgrade the memory in a 960 series server. Used PC2100 and all i get is a beep at startup. Is there a setting i have to change to be able to use more memroy? Configured with 2 512 chips at the...
if its for a server you will defenatly need ECC registered ram, if its not ECC it wont work try this program, it will tell you about your memory. download the program and run it.
http://www.crucial.com/systemscanner/
Oct 28, 2008 | Gateway Computers & Internet
Our bosch diswasher on auto wash will stop functioning in middle of the cycle start beeping and there is an icon of a faucet on the display. What does this mean?
Hello zeviemail
Welcome
You said, your Bosch dishwasher on auto wash will stop functioning in middle of the cycle start beeping and there is an icon of a faucet on the display.
What is your model number and the year of the dishwasher?
Oct 04, 2008 | Bosch Dishwashers
Computers & Internet Logo
941 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
