Question about Lexmark C522n Laser Printer
All my printing has ink spodges all over it. How can I stop it happening. The printer is a Lexmark C522
  • Official Brand Answer
  • 3,344 Answers
The problem could be contamination on your printer, Try cleaning your printer or making sure no residual toner is on top of the transport belt (the black vertical belt) Also check out this article about the different print quality issues that can happen and how to resolve them.
http://bit.ly/d9KAL2
Posted on Feb 13, 2010
  • Lexmark
    Lexmark Feb 13, 2010
    Here you will find a more detailed document about the problem you are having.http://bit.ly/a1JPyi
I have a Lexmark C522 Color Laser printer, all cartridges are showing as ok, no error messages but printed pages have specks of magenta toner on them
It sounds as though you have a leaking toner cartridge. If you aren't using Lexmark brand toner, that is VERY likely.. nobody seems to be able to make a good compatible cartridge. Test by replacing it.
Feb 22, 2014 | Lexmark C522n Laser Printer
Hi.. I have a Lexmark X6180 printer and it stopped printing. The paper goes through, and it sounds like it's printing but the paper is blank when it comes out of the printer. There's plenty of...
It could be that your cartridge needs cleaning. On your computer, go to Start menu > Programs / All Programs > Lexmark 6100 Series > Lexmark Solution Center. Go to Maintenance tab > select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through the cartridge nozzles and clean them. Try to print your document again and determine if the problem is fixed.
Jun 24, 2011 | Lexmark X6180 Printer
My lexmark is giving oerro 83 it is a C522
Error 83 indicates a problem referring to the transferbelt. Order a replacement transfer belt. When print quality is reduced, installthe new transfer belt using the instruction sheet that comes with the replacementtransfer belt. For further assistance, please contact LexmarkTechnical Support.
May 10, 2011 | Lexmark C522n Laser Printer
I have a Lexmark c522 color laser printer and I'm getting a 113.02 print head error. What does that mean and how can I clear it? Thanks Steve steve@westcoastphoto.net
Please click on the link http://bit.ly/qJtlDdto see instruction on how to go about the procedure. For additional assistance, please contact LexmarkTechnical Support.
Apr 15, 2011 | Lexmark C522n Laser Printer
I have plenty ink but i cant get anything that has blue in it
The issue might be caused by a defective or improperly installed supply. Here's an article on Colors Missing on Pages Printed on a Lexmark C520, C522, C524, C530, C532 or C534. Just click on this link: http://bit.ly/aR3uRB. You can also try swapping the supplies, however, if the problem continues it's a possible EP driver assembly or printhead assembly issue. If you're having difficulty following the instructions, don't hesitate to contact Lexmark technical support or your authorized service provider for further assistance. Thanks.
Aug 30, 2010 | Lexmark C534N Printer
Light yellow horizontal lines on C522
Remove the supplies and clean the yellow printhead. For instructions on how to clean the printheads, click on this link: http://bit.ly/bCoz92. Just follow the instructions. If that doesn't help, might need replacement. If issue remains after printhead has been cleaned and the supply has been replaced, I suggest you contact Lexmark Technical Support for further assistance. Thanks.
Jul 11, 2010 | Lexmark C522n Laser Printer
I have a Lexmark C522 When I print to it...the image that should be a full page prints really small on half of the page. How can I make it print what I send it?
this problem would indicate that the printer thinks the paper is smaller than it is. check the paper size settings on the drawer if the settings are right the replace the paper size pcb
Dec 03, 2009 | Lexmark C522n Laser Printer
I have a brother HL-5140 which has some nasty ink spodges on each page. Have carefully cleaned wire as recommended . Is there anything else I can do?
if they are evenly spaced, it will be 1 of 2 things, either the fuser or the drum, if you want to check the drum, take it out, take the toner out of the drum, and rotate the drum by turning the gear, be careful not to touch the drum not have it in direct sunlight or incandescent light and see if you can find the spodges on it.
you can also do a test print, print from the manual tray, and open the main cover after the paper goes in almost all the way. open the door, take the drum out and look at the paper, take it out slowly in the direction the paper was going and see if you see the splodge, if you do, again you will know its the drum.
thanks adi
Jun 27, 2009 | Brother HL 5140 Laser Printer
Lexmark stops printer when refill is detected.
Save your original OEM ink cartridge, when the software prevents you from printing, install it, remove it, then install the generic ink cartridge. You'll be good for a couple weeks, then just rinse and repeat.
Apr 26, 2009 | Lexmark X5495 All-in-One &USB...
My printer, a Lexmark 1300 series USB printer, will not print in black ink. It has plenty. The ink is proper lexmark ink. It just appears to not be looking at it's black ink cartridge at all as when I put...
Check your printer preferences and be sure that you're printing in the right way. Select grayscale and see what's happen.
Delete all printer pending jobs.
Take out the cartridge, turn off the printer and wait 5 min.
Turn on the printer, insert the cartridge and try again.
If nothing happens, replace the cartridge
You will find more info here:
http://www.lexmark.com/lexmark/sequentialem/home/0,6959,204816596_652569478_0_en,00.html
Oct 09, 2008 | Lexmark Office Equipment & Supplies
Lexmark C522n Laser Printer Logo
222 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
