Yamaha RX-V2700 won't turn back on
I was taking out Yamaha RX-V2700 out of the cabinet to check one of the speaker connections and accidentally clicked the MASTER button into the off position. Now it won't turn back on at all?? I have checked all cables are connected etc but it simply won't turn back on?
  • threekellys Feb 09, 2010
    Thank you ever so much but that all sounds way to technical for my liking :) i'll just wait until the service tech from where we got it from can come around and check it out because I don't want to do any further damage!!
    Cheers
  • 5,807 Answers
a ) You may need to open the unit to check inside or have someone to
do it for you.
b ) It could be from a microprocessor failure to a bad low power supply
regulators.
c ) You may need to start from the standby circuits and work all the
way to the main amp and check also for possible DC voltages on the
output stages.
d ) It is best checked by disconnecting all cables and speakers
disconnected.
e ) if ever it power up you may need to reconnect it one by one till
you found the cause .
f ) Same principle applies inside, you may need to check where the
supply rails go and have them reconnected one at a time.
Posted on Feb 08, 2010
  • Rommel Cana
    Rommel Cana Feb 09, 2010
    here is additional info
Yamaha RX-V595 receiver won't stay on
check ur speaker wires, try disconnect all wires from back of unit and then try to turn on unit .
if it stays on whit no wires attached than u have short connection at speaker wires .
if doesn`t come on then try to fasten screws at back of the unit ,
may sound like BS but if amp board don`t have good ground connection it can go in protection mode happened to me on RX-V592
Dec 23, 2012 | Yamaha RX-V595 Receiver
Connecting a YAMAHA RX-V2700 receiver to my TV and cable box
why not you use a normal AV cable
instead of hdmi cable
May 22, 2008 | Yamaha RX-V2700 Receiver
Check SP cable for my Yamaha V365?
This means wrongly connected speakers. Check the receiver without speakers to eliminate any failure. The error should go away.
Now carefully connect the speakers again, take care not to short-circuit the receiver. Also check the impedance settings on the receiver to match impedance of your speakers (either 6 or 8 ohms).
Jul 08, 2009 | Yamaha RX-V2700 Receiver
Yamaha RX-V2700 no sound from any speaker outputs
Make sure that you have the correct input signal selected.
Also, check if the sound is not muted.
If you have a multi-room speaker switch, make sure it is set correctly to main speakers.
Apr 28, 2009 | Yamaha RX-V2700 Receiver
Yamaha RX-V2700
Have you tried to see if there is a fuse connection on the back of your receiver?
Sep 20, 2008 | Yamaha RX-V2700 Receiver
How do i connect the bose 901 system to my yamaha rx-v2700
how about you connect your pre-amp out to eq-in and eq-out to aux ?
Mar 07, 2008 | Bose 901 VI Main / Stereo Speaker
Getting to work your pc music files through the usb connection
how should i connect my yamaha rx-v2700 to my desktop pc and which software i should install on my pc and where to download this software
Feb 12, 2008 | Yamaha RX-V2700 Receiver
Yamaha RX-V2700 skipping when playing a DVD on Toshiba D-R400
Sounds like a poor grounding issue between the units OR maybe they're not as compatible as the Mfg's say.
Could be a bad HDMI cable also. Most are made in the land of Nanking
Jan 18, 2008 | Yamaha RX-V2700 Receiver
The subwoofer preout is not working
does sub woffer have speaker wire in and outs run the fronst throw ther back up to front speakers pass throw it that would work
Jan 06, 2008 | Yamaha RX-V2700 Receiver
E01 no front speaker detected
Have you tried another known good speaker?
If you have,then the amp for that output is probably bad.
Dec 04, 2007 | Yamaha RX-V2700 Receiver
113 people viewed this question
 Grubhead
Grubhead
